Niko Luthieria Posted April 7, 2025 Report Posted April 7, 2025 Hello guys ive creat a logical sequence for studying the violin and used chatgpt to translated to keyboard(eletronic organ) What do you guys think? what can be changed? STUDY SCHEDULE – ELECTRONIC ORGAN “Have I not commanded you? Be strong and courageous...” The time you dedicate to your studies shows how much you’re willing to grow: LITTLE · A LOT · EXCELLENCE (references in color to the sugested time) 1. Stretching | 1 min - 2 min - 5 min Stretch your neck, shoulders, arms, wrists, fingers, and even your legs (since the organ uses the feet). Wash your hands well before touching the keyboard to avoid dirt or grease on the keys. 2. Hand Independence Exercise | 1 min - 2 min - 5 min Practice different rhythms in each hand (e.g., one hand plays eighth notes, the other plays quarter notes). Or try contrary and parallel motion scales — right hand going up while left hand goes down. 3. Articulation and Legato Technique | 1 min - 2 min - 5 min Practice perfect legato (smooth connection between notes) and non-legato, which is more typical of organ technique. Use intervals (thirds, sixths) and simple chords to develop control and precision. 4. Sound Control and Expression | 1 min - 2 min - 5 min Choose a basic register or pad sound and practice volume control using the expression pedal (if available). Practice smooth crescendos and decrescendos, even on electronic organs, to train your musical ear. 5. Pedalboard Technique (if applicable) | 1 min - 2 min - 5 min Practice only with your feet: simple scales or pedal tones along with a hymn. Focus on heel-toe technique, balance, and hitting the correct notes cleanly. 6. Scales in the Key of the Lesson | 1 min - 4 min - 10 min Start with hands separately, then together, and add pedalboard if possible. Practice with different rhythms (eighths, triplets, sixteenths) and pay attention to articulation and hand position. 7. Study the Lesson from the Method Book | 5 min - 10 min - 15 min Use a good method such as: Gleason’s Method, Roger Davis, John Stainer’s Primer, or Bastien Organ Book (for beginners). Practice hands separately, then together. Always read the music first and listen to recordings if available. 8. Scale in the Key of the Hymn | 1 min - 2 min - 5 min Same approach as in point 6, but now specifically preparing for the hymn to be studied. Combine this with excerpts from the hymn to connect the scale practice to real music. 9. Study the Hymn | 5 min - 6 min - 10 min Listen to a recording of the hymn to internalize the rhythm and harmony. Practice the right hand (melody), then the left (chords), and then the pedals (bass line), if applicable. Focus on phrasing, musical breathing, and appropriate registration for worship or liturgical use. 10. Clean the Instrument Wipe the keys, panels, and bench with a soft cloth. If using a pedalboard, clean the pedals too. FINAL TIPS Keep a practice journal: note what you practiced, what improved, and what still needs work. Use a metronome and audio recorder to monitor tempo and track your progress. Always practice with musical intention — don’t just play notes, express worship, emotion, and beauty.
