I don't think I've seen anything like this before.
The face with the relatively short and angled ffs seems to ring a bell, but I can't place it. The upper eyes are only 37mm apart.
The arching (which would be difficult to see in the photos) is ever so slightly "pinched" in an Amatise way.
Blocks are spruce, linings are willow, but not let in. The blocks are also closer to unilateral and certainly don't look anything like Fuessen diaspora. However, rib joints are mitred as they would be with inside mould construction.
There is a half-cut pin outside (!) the purfling, which makes me wonder if the lower one is just fully covered.
Plate overhang seems large all around both plates. When I first noticed it I though composite, but its fairly consistent all around and on both plates.
And here is a possibly decisive clue: I caught a tiny bit of fluorescence in a corner where purfling is not covered by varnish.
Any help appreciated.
Here is the corner with the black light fluorescence under magnification. It's possible that the tip of the purfling is actually missing and the area filled with glue. Also, the blacks seem to have some grain structure. So, probably no whalebone after all.
1 hour ago, Delabo said:
Nice violin. Have you determined what the two pins in the button are made from?
I'd think ebony. Just had another look under magnification and the one through the button looks like the third (!) pin in this place. If it came together with the half-cut one (as they look similar), then the purfling would not be original to the violin.
Yes, this is what I was thinking about the pins,are they original? And why would someone put a half pin in? Unless of course a full pin is under the purfling? Is the middle purfling strip Maple?
13 hours ago, Guido said:
I though composite
That's my guess, too. The purfling, especially the corner joints, looks quite different from belly to button. Or the bottom started without real purfling and got this (comparatively crude) purfling later. I'm also not aware of any school using original ebony pins, except the later Mnk/Schb cottage industry.
The scroll looks old French, are you sure it belongs?
Any internal pictures?
At first, I wondered if the back and ribs may be English, but the mitred rib joints would not fit with that. Scroll may be from another instrument, and a belly made later when it was all put together.
Instrument in hand, I'd say the purfling back and front is consistent.
And this is how the story would come together: the back started unpurfeled. Pins in the button and block were added later (as a repair effort). Then the violin got a new top and the back was purfeled with the new top. This is how we end up with a non-original half-cut pin and consistent purfling back and front in a composite violin.
If the head belongs is difficult to assess if we don't know what it is that it is attached to. Certainly, the narrow throat looks French, but the volutes maybe not so much. If the back was originally unpurfeled that seems to point more towards English or, you know, the I-word, but maybe less likely French.
I was hoping to get away with the description above: close to unilateral spruce blocks, willow linings, not let in.
Its guess the Guarneri time. Your scroll (left) pegbox walls are too thin, and the walls are to long, and the edges are rounded. No idea what Guarneri scroll we are looking at though. I am sure someone on here will know.
Both the blocks and linings (from these limited views) look much neater than I would have expected, judging them against the exterior.
After lots of flicking pages and chasing ideas, the only things that somewhat come close to the OP violin are wonky Italians, like this one.
You know well, that far more violins were made outside of Italy than in it.
While it is always tempting to think one might have a valuable masterpiece from there, wonky violins were made everywhere. Some due to the techniques used, and some on purpose.
Of course. And the wonky ones from outside Italy usually don’t make it into any reference books…
But it is tempting. The maker of above half cut pin also made narrow throats. See below.IMG_5676.thumb.jpeg.baf5094d6bab4a98bf7a55c3fc79c482.jpeg
