Brad Dorsey Posted June 30 Report Posted June 30 6 hours ago, LCF said: ...I...use 0.8mm ( 1/32") carbide cutters to make bridges... Thank you for sharing your experience with cutting wood with small end mills. 56 minutes ago, fiddlecollector said: ...I clamp the bow head using...often just 1/2" packing foam glued to a wooden backing... I like the foam idea. I have never set up a bow head in a milling vise. 56 minutes ago, fiddlecollector said: ...A good illustration of similar repairs on an FX Tourte bow with similar corner crack to the OP's bow is shown in this link ,carried out by Pete Oxley... Very interesting.
jezzupe Posted July 1 Report Posted July 1 I tend to agree with lots of that, but Bob Smith epoxy for exotics is quite thin, comes in slow,medium or fast set times,clamps well and is like 50 bagillion times stronger than ca for permanent repairs. It is the only epoxy I would use for such things, particularly the slow set
fiddlecollector Posted July 1 Report Posted July 1 6 hours ago, jezzupe said: I tend to agree with lots of that, but Bob Smith epoxy for exotics is quite thin, comes in slow,medium or fast set times,clamps well and is like 50 bagillion times stronger than ca for permanent repairs. It is the only epoxy I would use for such things, particularly the slow set Never heard about this brand, which one is for exotics, as i can only see slow medium and fast?? I use Hxtal NYL-1 optical epoxy but it takes ages to dry in the UK unless the weather is very warm and it is about the thinest epoxy ive tried. It will wick into cracks especially if you warm the joint a little.
jezzupe Posted July 1 Report Posted July 1 8 hours ago, fiddlecollector said: Never heard about this brand, which one is for exotics, as i can only see slow medium and fast?? application ca I use Hxtal NYL-1 optical epoxy but it takes ages to dry in the UK unless the weather is very warm and it is about the thinest epoxy ive tried. It will wick into cracks especially if you warm the joint a little. It's now called "oak and teak"....the application calls for an initial application {you get lots of time} you apply, pinch the crack, maybe use a pallete knife or a boar hair to work it in, then you apply a second application, the first soaks in,It's so strong, works well on oily exotics
jezzupe Posted July 1 Report Posted July 1 Just now, jezzupe said: It's now called "oak and teak"....the application calls for an initial application {you get lots of time} you apply, pinch the crack, maybe use a pallete knife or a boar hair to work it in, then you apply a second application, the first soaks in,It's so strong, works well on oily exotics check amazon
