Nürnberger bow
uguntde
I have a Nürnberger bow here, which I assume to be from the Nürnberger family. Silver mounted, 58-59g. From which time is this? 1900-1920? Thsi would be Franz Albert Nürnberger II. It has not been played much, hardly any wear, but nevertheless plays very well. Makes a bright tone, strong stick.
Nurnberger2.thumb.jpg.3904b188db021db40e7cd49ea12e3d60.jpgNurnberger4.thumb.jpg.807fe4f40cabb53b50ffd310bbfd95bf.jpg
IMG_6838a.thumb.jpg.6693e84e413ea9d015b85f66679f1650.jpgIMG_6852.thumb.jpeg.6cc18202267fdb9566cf168c8b1ec9ff.jpeg
IMG_6845.thumb.jpeg.6ba96e46b7d259f3e1cb388e2584314b.jpegIMG_6847.thumb.jpeg.724e1e80b5e29101db9560853137ef19.jpegIMG_6839a.thumb.jpg.26e1d9a94dec45afb9744c2e9b8c46eb.jpg
It fits the stick perfectly from front to end. No indication that it would not be original.  I have another goldmounted Nürnberger with a frog of almost exactly the same dimensions but without eye.
Has the adjuster of the gold mounted bow an U-channel collar? This would put it also more early. Or is it a trick of the photo?
Not sure I understand what you mean with U-channel. The shape of the ring that has been lathed into the button at the screw end is different between the two bows. The silver mounted one has this double-ring, the gold mounted one has what you could call U-shaped (red arrow). Or do you refer to something else? The nut is skightly different, but same thread, same shape of the spindle (if these are at all relevant indicators).
Yes, that's the "German" U-collar. That's very unusual at a 20th century Albert Nürnberger junior. Grünke shows an also gold mounted August Nürnberger-Suess, made in New York, with this feature, but without a date.
Grünke In his book?
So is the other adjuster (the silver one) more typical for the 1920s?
I may ask him for a certificate of the undamaged silver-mounted bow. The silver-mounted is the better stick, but this is a matter of taste, makes a bright tone, feels strong, healthy flexibility.
9 hours ago, LCF said:
I'm sure it will continue to hold but the thread in the eyelet of that gold mounted one is very close to the outer surface.
This one was played a lot.
What  learned is that one can now get very detailed stamp analyses, considering all the faults and imperfections of these stamps. This has become a science of its own.
  • 1 month later...
I showed the silver mounted bow to several German experts who all agreed that it was certainly not made by a Nürnberger family member. I had my own doubts when I saw tool marks and shellac on the stick. Grünke just looked at pictures and said it was none.
