reguz Posted September 10, 2023 Report Posted September 10, 2023 the arching is what makes your stringed instrument sound and function the way that it does. Without those curves (that is, with a flat top and back) your instrument wouldn't be able to stand up to the pressure of the strings. What would you say by reading these lines?
jacobsaunders Posted September 10, 2023 Report Posted September 10, 2023 A prejudice, belied by decades of restoring antique violins which perpetually surprise
FiddleDoug Posted September 10, 2023 Report Posted September 10, 2023 Tell that to a guitar. It’s also a stringed instrument.
Don Noon Posted September 10, 2023 Report Posted September 10, 2023 I would say it's bait for letting you expound upon your theories... again.
Andreas Preuss Posted September 10, 2023 Report Posted September 10, 2023 3 hours ago, reguz said: the arching is what makes your stringed instrument sound and function the way that it does. False. Then you could use paper ribs. False. Then you could use ANY string angle.
Wood Butcher Posted September 10, 2023 Report Posted September 10, 2023 3 minutes ago, Don Noon said: I would say it's bait for letting you expound upon your theories... again. And after several years of evasiveness, we finally discovered he has made no violins (which I guess many had already realised).
David Alex Tricot Posted September 10, 2023 Report Posted September 10, 2023 The sentence is false as the arching is one important factor but not the only one to the sound and function. Good demonstration from Andreas
Anders Buen Posted September 10, 2023 Report Posted September 10, 2023 The main function of the arching is the stability it provides the instrument for its rather thin plates. Moreover, the arching makes it possible for the bowed instruments to go through humidity cycles through the year and with travelling A to B in climate C, like a dry airplane cabin. The tonal aspects of the arcing is a secondary effect. But it is probably there.
Marty Kasprzyk Posted September 10, 2023 Report Posted September 10, 2023 33 minutes ago, Andreas Preuss said: False. Then you could use paper ribs. False. Then you could use ANY string angle. I found that if the string angle is too shallow over the bridge (approaching 180 degrees) that there isn't enough downward string force. The strings can be pushed out of their bridge notches with heavy bowing.
martin swan Posted September 10, 2023 Report Posted September 10, 2023 3 hours ago, reguz said: the arching is what makes your stringed instrument sound and function the way that it does. Without those curves (that is, with a flat top and back) your instrument wouldn't be able to stand up to the pressure of the strings. What would you say by reading these lines? I would say that I'm suddenly feeling very sleepy ...
MikeC Posted September 10, 2023 Report Posted September 10, 2023 I would agree that good arching is important to the sound and that flat plates on their own would not hold up well to string pressure. Guitars have bracing under the sound board to provide support. Also on a guitar the strings are usually pulling up on the sound board not pressing down on it, with some exceptions. Obviously the strings have to be on an arched bridge to be able to bow one at a time, that wouldn't be possible on a flat bridge like a guitar. If you want to see an example of bad, or at least unconventional arching check out this VSO build on youtube. I don't know if he is purposely making it rustic for the old sailing vessel Tally Ho or just clueless about the architecture of a real fiddle.
reguz Posted September 10, 2023 Author Report Posted September 10, 2023 1 hour ago, Don Noon said: I would say it's bait for letting you expound upon your theories... again. Don. The sentense you were able to read are not written by me. It is copied from the internet. But as always from you, you have nothing to contribute. No Don, it is just for you to let us know your opinion. You seem to be unable
reguz Posted September 10, 2023 Author Report Posted September 10, 2023 1 hour ago, martin swan said: I would say that I'm suddenly feeling very sleepy ... Try to wake up and give a proper answer please. Other expect you to do
reguz Posted September 10, 2023 Author Report Posted September 10, 2023 1 hour ago, Wood Butcher said: And after several years of evasiveness, we finally discovered he has made no violins (which I guess many had already realised). Once again NO ANSWER on the question. UNABLE thus ?????
reguz Posted September 10, 2023 Author Report Posted September 10, 2023 1 hour ago, David Alex T. said: The sentence is false as the arching is one important factor but not the only one to the sound and function. Good demonstration from Andreas This is no answer on the question. You can do better , or???
reguz Posted September 10, 2023 Author Report Posted September 10, 2023 1 hour ago, Anders Buen said: The main function of the arching is the stability it provides the instrument for its rather thin plates. Moreover, the arching makes it possible for the bowed instruments to go through humidity cycles through the year and with travelling A to B in climate C, like a dry airplane cabin. The tonal aspects of the arcing is a secondary effect. But it is probably there. Yes, yopu could of course look at the problem from that aspect but the question remain why is it from a technical aspect? How does the arching shape start behave? What is it we like it to behave?
reguz Posted September 10, 2023 Author Report Posted September 10, 2023 1 hour ago, Marty Kasprzyk said: I found that if the string angle is too shallow over the bridge (approaching 180 degrees) that there isn't enough downward string force. The strings can be pushed out of their bridge notches with heavy bowing. This is an answer related to the behavior of the string and the bowing action. It is not about arching shape. I belive you can do better.
reguz Posted September 10, 2023 Author Report Posted September 10, 2023 53 minutes ago, MikeC said: I would agree that good arching is important to the sound and that flat plates on their own would not hold up well to string pressure. Guitars have bracing under the sound board to provide support. Also on a guitar the strings are usually pulling up on the sound board not pressing down on it, with some exceptions. Obviously the strings have to be on an arched bridge to be able to bow one at a time, that wouldn't be possible on a flat bridge like a guitar. If you want to see an example of bad, or at least unconventional arching check out this VSO build on youtube. I don't know if he is purposely making it rustic for the old sailing vessel Tally Ho or just clueless about the architecture of a real fiddle. Sorry but I did not find any about arching shape.
Marty Kasprzyk Posted September 10, 2023 Report Posted September 10, 2023 1 hour ago, Anders Buen said: The main function of the arching is the stability it provides the instrument for its rather thin plates. Moreover, the arching makes it possible for the bowed instruments to go through humidity cycles through the year and with travelling A to B in climate C, like a dry airplane cabin. The tonal aspects of the arcing is a secondary effect. But it is probably there. I started making my top plates like the wood floors of buildings which have thin flat plywood backed by many deep floor joists. If you drop a barbell on the floor it can produce a loud sound and its various mode frequencies can be adjusted by using different spacings, widths and heights of the floor joists and their cross bracings.
David Burgess Posted September 10, 2023 Report Posted September 10, 2023 2 hours ago, Don Noon said: would say it's bait for letting you expound upon your theories... again. Yup. Most of us have learned to no longer take that bait, after having already heard his theories too many times. 2 hours ago, martin swan said: I would say that I'm suddenly feeling very sleepy ... Me too... 56 minutes ago, reguz said: No Don, it is just for you to let us know your opinion. You seem to be unable Being unwilling is not the the same thing as being unable.
reguz Posted September 10, 2023 Author Report Posted September 10, 2023 You are right David. But why giving such answer. Is this forum's ides not giving understanding on difficult questions. Those how could help should do. I am sure with your experiences you have much to tell us. So, just go on.
Anders Buen Posted September 10, 2023 Report Posted September 10, 2023 1 hour ago, Marty Kasprzyk said: I started making my top plates like the wood floors of buildings which have thin flat plywood backed by many deep floor joists. If you drop a barbell on the floor it can produce a loud sound and its various mode frequencies can be adjusted by using different spacings, widths and heights of the floor joists and their cross bracings. Yes, relevant observations there for e.g. concert hall floors, sound insulation properties of walls or ceilings made of plates on stiff studs or absorbing wall or ceiling linings of a similar construction.
martin swan Posted September 10, 2023 Report Posted September 10, 2023 1 hour ago, reguz said: Try to wake up and give a proper answer please. Other expect you to do Sorry I didn't manage it, I just fell asleep in the garden for 2 hours and now I've forgotten the question.
Anders Buen Posted September 10, 2023 Report Posted September 10, 2023 1 hour ago, reguz said: Yes, yopu could of course look at the problem from that aspect but the question remain why is it from a technical aspect? How does the arching shape start behave? What is it we like it to behave? The arch is likely to come from empirical means. Some stringed musical instruments are made of natural cavities from seed containers, or the like. Some are simply hollowed out. By the answers here I can see that you are likely to have the "answers to all this" yourself, and do not pay attention to what I have written. Moderately curved plates work better because they can be made thinner and the design, if it is of the right type, will resist and survive humidity cycling better than the less good designs, like too high arch and too fast changes of the curves. Arch suppress the low frequency response and does little to the highs. Maybe a balance there is achieved in better instruments. It is perfectly possible to make a useless instrument with "right arch", but other important factors incorrect. Arching itself does not make the sound. Violin sound and instrument stability is a balancing act of lots of factors.
Dennis J Posted September 11, 2023 Report Posted September 11, 2023 I would say that an ideal arching shape is the result of a purely functional, planned geometric approach. The basis of that is its height determined by the shape of the long arch, and inflection point positions between the upper and lower bouts. Fixing those is the only practical way to preplan an arching. And, if you can't preplan it, how can you lay down any innovation which supposedly will improve the instrument's performance? The Tally Ho video shows the formula or approach to the arching of that violin is totally uncharacteristic of traditional violin making. There is no smooth connection between the upper and lower bouts through the centre bout. There are ridges at each of the corners. Recurves around the upper and lower bouts are almost non existent. I would say it's a good example of how not to go about arching. It doesn't look right and probably isn't.
