Violin ID please
______
Hello guys.
Here I got another 4/4 violin.
Measurements are: LOB 358, widths: 164, 105, 204, stop 195mm.
I tried to snap all the details required.
All corner blocks (managed to picture lower cc only, upper are same).
What are your thoughts?
As usual I am having trouble seeing much from photos but it looks to me like the scroll is finished under the throat and I am not seeing a meeting of the ribs on the rather broad face of the rib corners. Also the varnish looks softer than what I would expect on lesser MK work. I'll be interested to see what others think of this one. My first impression of this wood is American maple but again I can't see well enough from the pictures to be sure.
Yup Sir, I've just noticed some of them are slightly out of focus what I can fix this evening.
Also forgot to mention that varnish has got some cracelure. Will try to show it on photos.
1 hour ago, martin swan said:
To me this also looks like a better grade of Markneukirchen instrument
Agree. The rib joints a bit more cut back and the scroll fluting a bit deeper carved than usual. The thick craquelature is probably part of the antiquing.
2 hours ago, jacobsaunders said:
One should note that for a common or garden “usual” it has several unusual features, also a strange outline. One wonders to what extent it has been manipulated after the fact, or if it is one of those that Beer called “copies”
I have also noticed that strange outline myself at some point holding it in front of my face but it was easy to do while having it closer than a beer mug.
It is not easy to catch it by those poor photos only, wow. Never stop wondering how sharp eye you've got professor!
What bothers me is a Hamlet - like question: to open it or not to open it, since imho it is going to be opened anyway in spite of nasty and all - the - way - long crack through soundpost area which is poorly repaired and not patched nor cleated.
Thus I would be able to see and picture inside work before handing it to a good restorer.
It might be something like a „Großstadtgeige“ - big city violin with a certain relationship to Markneukirchen. The inside work and mitred rib joints are indicating that the ribs were made using a mould, while the shape of the scroll and the antiquing are quite typical for Markneukirchen work. So if it will be opened anyway due to the large soundpost crack the OP might look for an inscription or hidden signature. This might be the only way to find out more.
I'm seeing the C bout rib feathered in not mitered  which would be Mittenwald style, of course the corner blocks aren't. As to the scroll, it has a delta but the carving appears to go completely in, how is that Markneukirchen style
