Best knife for purfling
Crimson0087
4 hours ago, Crimson0087 said:
There are probably much better options than these.
I have struggled with single bevel knives, overall preferring double beveled options.  This may not be the experience of others though.
My current go to purfling channel knife is shown below.  The blade is 8mm wide and the profile is the same on both sides.  This seems to produce a tidy result.
Edited by John Harte
Correct the blade width dimension
I prefer interchangeable blades, they have the advantage that they can be sharpened and modified quickly in different ways (single or double bevel, rounded point, sharp point, different blade shape, etc.) until we find the one that suits us. It's not as fancy as John Harte's (which by the way has a very cool blade shape) but this is what I use, strictly double bevel:
The linked knives look too wide and fat to me for purfling work.  I suppose you could taper them down to a good working dimension, but that's just grinding away a lot of metal, leaving a long sharp edge, most of which is only there to cut your fingers.
I only have to cut the corner tips, and my choice for that is a scalpel.  The "best knife" (for me) for rest is a carbide min-endmill.
For $7 on Amazon: scalpel + blades
The Madinter knife you have shown is 2 mm thick and that is what a lot of those marketed as luthier's knives are. Not ideal for trimming purfling channels.
That is why disposable blades or long thin blades about .6 mm thick near the point work better.
Hock makes one specifically for the Chicago violin making school.
https://www.hocktools.com/products/knives/knife-blanks-for-violin-schools.html
Who knows how their catalog will change with the Lee Valley acquisition. I’ve had my eye on it but I decided to hold out for one from John Schmidt (violin88). Only problem is it looks like he won’t be operational in New Zealand for at least a few more months.
Edit: After some thought, I’m not sure if the purfling blade from Hock is for a purfling knife or for the purfling marker. I assume it’s a knife because it seems to line up with some of the dimensions recommended by Brian Derber, and it’s listed with other knife blanks.
In the interests of full disclosure, I should come clean and mention that I often use the same knife handle as Davide with a #11 scalpel blade for cutting the bee sting point recess.  My main weird looking knife was inspired by Spidlen's purfling knife illustrated in the August 2005 Strad magazine.  It works well in both spruce and maple with the shape being particularly useful if you want to make a pushing cut through harder spruce grain lines etc..  I've tried lots of different options.  At the end of the day it comes down to what you can get to do everything you want with the least amount of grief involved.
I have discovered an alternative to exacto and seems *so far* to be less likely to snap at the tip.
I picked mine up from a local hardware store.
It is also thinner than exacto/excel blades ive tested.
My hock knife is 1.5mm
Exacto and Excel I have around  0.55-0.57mm
OLFA blades i tested were all 0.44mm *but all from same batch*
 It also has a smaller holder that I find more comfortable others might not like the smaller holder.
https://www.amazon.com/OLFA-AK-1-Standard-Knife-Blades/dp/B0006SJAXE/ref=pd_lpo_1?pd_rd_w=nP7ov&content-id=amzn1.sym.116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_p=116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_r=FS66A761XDW6W4PD69ZR&pd_rd_wg=bQchy&pd_rd_r=1df11d3e-3f06-46b9-94eb-83d91b517f87&pd_rd_i=B0006SJAXE&psc=1
2 minutes ago, CaseyLouque said:
I have one of these also, got it at Lowe's the big box store.  I haven't used it yet though.
Why do they call it a big box store. I've never seen any big boxes for sale there.
I too am in the scalpel camp, Swann-Morton, easy to get cheap, lethal sharp interchangeable blades. As you said, the "best knife" for me that I've used for this purpose so far. Only downside is they are not the most comfortable shape.. But then I guess they really were just designed for soft tissue :)
