Arsalan Posted November 26, 2022 Report Share Posted November 26, 2022 Hi everyone does anyone knows , where to get those mill size ,,, other than international violin ... to receive them faster and maybe better price thanks in CANADA Quote Link to comment Share on other sites More sharing options...
Don Noon Posted November 26, 2022 Report Share Posted November 26, 2022 You can find some on eBay, but you have to be careful as most of the bits are the diamond-cut style for PC boards, not what you want. From China, inexpensive and decent, but watch out for shipping times. You can also get micro endmills from MSC Direct, decent prices and in the US. If it has to be from Canada, search around for a distributor of Accupro bits. Quote Link to comment Share on other sites More sharing options...
charliemaine Posted November 26, 2022 Report Share Posted November 26, 2022 I use RobbJack endmills, Tom Croen sells them in pairs. Here: https://tomcroenviolins.com/tools/pricing/ Quote Link to comment Share on other sites More sharing options...
GoPractice Posted November 26, 2022 Report Share Posted November 26, 2022 16 hours ago, charliemaine said: I use RobbJack endmills, Tom Croen sells them in pairs. Here: https://tomcroenviolins.com/tools/pricing/ Which gives one the advantage for the recommended cut and feed rates. Worth the price of admission? Quote Link to comment Share on other sites More sharing options...
charliemaine Posted November 26, 2022 Report Share Posted November 26, 2022 3 hours ago, GoPractice said: Which gives one the advantage for the recommended cut and feed rates. Worth the price of admission? Don't understand. Quote Link to comment Share on other sites More sharing options...
Arsalan Posted November 29, 2022 Author Report Share Posted November 29, 2022 On 11/25/2022 at 7:06 PM, Don Noon said: You can find some on eBay, but you have to be careful as most of the bits are the diamond-cut style for PC boards, not what you want. From China, inexpensive and decent, but watch out for shipping times. You can also get micro endmills from MSC Direct, decent prices and in the US. If it has to be from Canada, search around for a distributor of Accupro bits. Thank you very much Don Quote Link to comment Share on other sites More sharing options...
Arsalan Posted November 29, 2022 Author Report Share Posted November 29, 2022 On 11/25/2022 at 7:43 PM, charliemaine said: I use RobbJack endmills, Tom Croen sells them in pairs. Here: https://tomcroenviolins.com/tools/pricing/ Thank you Charlie Quote Link to comment Share on other sites More sharing options...
Arsalan Posted November 29, 2022 Author Report Share Posted November 29, 2022 Just now, Arsalan said: Thank you very much Charlie , Quote Link to comment Share on other sites More sharing options...
Arsalan Posted November 29, 2022 Author Report Share Posted November 29, 2022 On 11/25/2022 at 7:06 PM, Don Noon said: You can find some on eBay, but you have to be careful as most of the bits are the diamond-cut style for PC boards, not what you want. From China, inexpensive and decent, but watch out for shipping times. You can also get micro endmills from MSC Direct, decent prices and in the US. If it has to be from Canada, search around for a distributor of Accupro bits. Don I have a dremel and the biggest shank size I can use is 3.2 mm ... what do tools you use to be able to fit 4 mm shank ? The eBay link you sent , is 4 mm shank ... thank you again Quote Link to comment Share on other sites More sharing options...
Don Noon Posted November 29, 2022 Report Share Posted November 29, 2022 4 hours ago, Arsalan said: Don I have a dremel and the biggest shank size I can use is 3.2 mm ... what do tools you use to be able to fit 4 mm shank ? The eBay link you sent , is 4 mm shank ... thank you again Sorry, I didn't read down in the description where it said the shank was 4mm. Most of these micro mills are 1/8" shank, which is what I use. My Dremel has 1/8" and 1/4" collets, but I use the bits on my CNC which has a wide selection of collets. I see there is a 4mm collet that apparently fits some Dremels, but you'd have to be sure it fits your model. I wouldn't bet on it, but maybe you can locate one somewhere. Quote Link to comment Share on other sites More sharing options...
Thomas Coleman Posted November 29, 2022 Report Share Posted November 29, 2022 I buy mine from Kodiak Cutting tools. They are cheaper than International but not by much. https://www.kodiakcuttingtools.com/viewproducts/carbide-end-mills-2-flute-micro-square-end-miniature-decimal-size-end-mills&parttohighlight=5444318 They come in decimal inch size but this can easily be converted to your metric requirements. Their part number 5444318 0.055" is an equivalent to 1.4mm. The 0.051" is equivalent to 1.3mm. One thing I like about Kodiak is that they come in 1/1000 increments so you can really dial in a fit if you need. Quote Link to comment Share on other sites More sharing options...
Don Noon Posted November 29, 2022 Report Share Posted November 29, 2022 16 minutes ago, Thomas Coleman said: I buy mine from Kodiak Cutting tools. I bought some from them too. I forgot about them. Good source. Quote Link to comment Share on other sites More sharing options...
charliemaine Posted November 29, 2022 Report Share Posted November 29, 2022 Thanks Thomas. Quote Link to comment Share on other sites More sharing options...
Rico Suave Posted November 30, 2022 Report Share Posted November 30, 2022 Or perhaps Zoro.com - the retail side of Graingers They frequently send 10-20% off coupons if you create an account. Free shipping at $50 (U.S. Orders) https://www.zoro.com/search?q=1.3mm end mill&fqc%3Acategory=z2%2F2%2F9549 https://www.zoro.com/search?q=1.4mm end mill&fqc%3Acategory=z2%2F2 I recently purchased spherical washers for use with a CBN Grinding wheel https://www.zoro.com/te-co-spherical-washer-fits-bolt-size-58-in-steel-black-oxide-finish-42704/i/G1871317/ Quote Link to comment Share on other sites More sharing options...
