Jimmyjoe Posted November 5, 2022 Report Share Posted November 5, 2022 Hello there...I was looking some information in this forum, but I could't fine it. Basically: 1) Which one is the best way to store hide glue when you open the original plastic bag? 2) May I keep the hide glue when I have heated it once, and use it again? Thanks! Quote Link to comment Share on other sites More sharing options...
nathan slobodkin Posted November 5, 2022 Report Share Posted November 5, 2022 As long as the glue is kept dry it will last indefinitely. I keep mine in either glass bottles or ziplock plastic bags. You can definitely reheat the glue a couple times if you keep it in a refrigerator between heating. it will actually be strongest on the second heating and will go down in strength after that. Quote Link to comment Share on other sites More sharing options...
Jluthier Posted November 5, 2022 Report Share Posted November 5, 2022 I am coming to the end of my Behlen hide glue purchased in 1987, stored of course in dry form but without any special climate control. I tested it for joint failure recently; the joint was stronger than the wood. Quote Link to comment Share on other sites More sharing options...
Jimmyjoe Posted November 6, 2022 Author Report Share Posted November 6, 2022 Thanks Nathan and Jluthier for the information. Quote Link to comment Share on other sites More sharing options...
Alma Elder Posted November 8, 2022 Report Share Posted November 8, 2022 Quote Link to comment Share on other sites More sharing options...
Davide Sora Posted November 8, 2022 Report Share Posted November 8, 2022 52 minutes ago, Larry F said: I bought twenty pounds 30 years ago of good powdered hide glue, and keep it in a big plastic container with a screw on lid. Its as good today as the day I bought it. One of the indisputable advantages of hide glue over any other glue Quote Link to comment Share on other sites More sharing options...
Kevin_D Posted December 1, 2022 Report Share Posted December 1, 2022 (edited) On 11/6/2022 at 2:35 AM, Jimmyjoe said: Hello there...I was looking some information in this forum, but I could't fine it. Basically: 1) Which one is the best way to store hide glue when you open the original plastic bag? 2) May I keep the hide glue when I have heated it once, and use it again? Thanks! For the first question, it depends on the type of glue. Elmers is pretty solid, so I would keep it in the bag. For other types of glue, the best thing to do is to put it in the fridge. The next question is a little tricky to answer, so I'll give you a slightly different answer. Basically, you only want to heat up your glue once. I guess the point of heating it is to allow it to flow more evenly, which is definitely a good reason to heat it. But the act of heating creates more surface area, more area that the glue can gel. This means that the glue becomes less durable, and will eventually fail. If you do heat it up, I would keep the glue in a bag, and keep it in the cooler for a few days. Edited December 1, 2022 by Kevin_D Quote Link to comment Share on other sites More sharing options...
FiddleDoug Posted December 2, 2022 Report Share Posted December 2, 2022 4 hours ago, Kevin_D said: For the first question, it depends on the type of glue. Elmers is pretty solid, so I would keep it in the bag. For other types of glue, the best thing to do is to put it in the fridge. The next question is a little tricky to answer, so I'll give you a slightly different answer. Basically, you only want to heat up your glue once. I guess the point of heating it is to allow it to flow more evenly, which is definitely a good reason to heat it. But the act of heating creates more surface area, more area that the glue can gel. This means that the glue becomes less durable, and will eventually fail. If you do heat it up, I would keep the glue in a bag, and keep it in the cooler for a few days. You’re way off base on most of what you said! Elmer’ glue is a liquid, not a solid, and comes in a bottle, not a bag. The OP specifically asked about hide glue. Hide glue is gelled at room temperature, and must be heated to even get it to flow. Hide glue solution/gel can be reheated and used several times. Keep it in the fridge between uses. Heating creates more surface area? What are you talking about? If you want to talk about molecular weight of the collagen chains, yes, long term heating, especially at higher temperatures can break down the chain length, and reduce the strength. Quote Link to comment Share on other sites More sharing options...
Don Noon Posted December 2, 2022 Report Share Posted December 2, 2022 I just glued the top on a violin using glue I mixed up 2 years ago, and stored on a shelf in the shop, unrefrigerated. I have heated it a few times. To prevent mold, I have a bottle of water with a bromine tablet in it, and use that water to lightly wet the top of the glue after it has gelled. Works great. However, for something where I'd want maximum strength (like a neck), I'd mix up fresh glue. Quote Link to comment Share on other sites More sharing options...
