Arsalan Posted September 14, 2022 Report Share Posted September 14, 2022 Hello everyone, Is there anyone who knows , where to buy some quality ferrules , the regular one that LV has or making them out of a piece of brass pipe , is not what I want , I am looking to find something for example like what E A Berg or …. Used for the chisels … really appreciate if someone can help on this … thanks Quote Link to comment Share on other sites More sharing options...
Wood Butcher Posted September 14, 2022 Report Share Posted September 14, 2022 Depends where you live, as to what might be available. Brass tubing is the obvious choice, but finding the right internal and external diameter is very unlikely. I think if you know someone at a machine shop, they might be able to turn one out of some brass bar, to the specs you need. Quote Link to comment Share on other sites More sharing options...
Dwight Brown Posted September 14, 2022 Report Share Posted September 14, 2022 https://www.leevalley.com/en-us/shop/tools/workshop/tool-maintenance/30021-brass-ferrules Robert Sorby HF16B Set of 10 Each 16 mm / 5/8 Inch Solid Brass Ferrules for Custom Lathe Tool or Chisel Handles maybe this? DLB sorry, I didn’t get the LV in your original post. Quote Link to comment Share on other sites More sharing options...
Mark Norfleet Posted September 14, 2022 Report Share Posted September 14, 2022 11 hours ago, Wood Butcher said: Depends where you live, as to what might be available. Brass tubing is the obvious choice, but finding the right internal and external diameter is very unlikely. I think if you know someone at a machine shop, they might be able to turn one out of some brass bar, to the specs you need. Yes, having what you would like to have made is probably your best bet if you can find an amused cooperative machinist or have a friend with the right tools at home. Brass is the easiest and there's no need to find tubes of the right sizes as they can readily be made from solid material. That said, the Berg gouges you recently posted photos of do not have ferrules... Quote Link to comment Share on other sites More sharing options...
David Burgess Posted September 14, 2022 Report Share Posted September 14, 2022 OP, there's both new and discarded metal tubing all over the place. For a chisel ferrule, the type of metal won't matter that much. You could even take a piece of discarded copper water line, or discarded iron gas line, cut off a section with a hacksaw, and file the end of the wooden handle down to fit the inside diameter of the ring. Not nearly as pretty as something Norfleet would fabricate, but quite adequate for getting down to business. Quote Link to comment Share on other sites More sharing options...
Jim Bress Posted September 14, 2022 Report Share Posted September 14, 2022 +1 to DB. Copper tubing is what I used for the gouge handles I’ve made. Quote Link to comment Share on other sites More sharing options...
FenwickG Posted September 14, 2022 Report Share Posted September 14, 2022 I use copper tubing for larger handles and brass cartridge cases for small handles. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted September 14, 2022 Report Share Posted September 14, 2022 2 hours ago, FenwickG said: I use copper tubing for larger handles and brass cartridge cases for small handles. I hadn't thought of brass cartridge cases. Neat idea. Available in lots of different sizes. Quote Link to comment Share on other sites More sharing options...
Dwight Brown Posted September 14, 2022 Report Share Posted September 14, 2022 39 minutes ago, David Burgess said: I hadn't thought of brass cartridge cases. Neat idea. Available in lots of different sizes. I don’t know if they are strong enough but empty shotgun shells would offer some bigger ones. DLB Quote Link to comment Share on other sites More sharing options...
Andrew tkinson Posted September 15, 2022 Report Share Posted September 15, 2022 Hello, I hope I don't incur anyone's wrath if I suggest that if you are making handles for old chisels or gouges you do not always need to go to the complication of adding a ferrule. Here are some very old - probably over 150 years old - well used gouges with some user made octagonal handles. Admittedly the handles may be a bit younger but they are still quite ancient and I think they have a rather attactive design in way the facets are taken around the end I think if you are not levering or using a mallet with your chisels and fit the tapered tang carefully - a bit like the way I would fit a nail to a violin neck if I ever get around to it - using perhaps three different drill sizes to bore the handle to accomodate the tang's taper and then using the tang itself to ream the hole so the handle can be carefully tapped on the last few mm (or a sixteenth of a Cremonese inch?) Here is a nice big old 1 3/4" gouge which, when I acquired it, had the double ferruled handle loosely fitted which I carefully removed. To make a new big long handle I took a nice bit of rippled beech I got from the woods many years ago, which I had been saving for something nice, shown below the gouge Here is the finished handle after I had fitted it and rubbed it with some linseed oil, the other handle I made of some plain beech I hope nobody objects to this slightly contrary contribution, I freely admit I am no expert and I know from observation there are some on this site that do not suffer ferrules gladly! Quote Link to comment Share on other sites More sharing options...
Rico Suave Posted September 15, 2022 Report Share Posted September 15, 2022 8 hours ago, David Burgess said: I hadn't thought of brass cartridge cases. Neat idea. Available in lots of different sizes. .45 ACP is a convenient size for small and medium sized handles. I file or grind down the rim for a smooth rounded transition. 1/2" copper pipe end caps work for lager handles Quote Link to comment Share on other sites More sharing options...
Dennis J Posted September 15, 2022 Report Share Posted September 15, 2022 Using brass or steel of the right gauge or thickness is important. Standard brass tubing is usually quite thick and has no flexibility which can be a problem when fitting ferrules to turned handles. I agree that ferrules may not be necessary for chisels and carving gouges particularly smaller ones. Tapered twist drills are available to bore holes for tangs. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted September 15, 2022 Report Share Posted September 15, 2022 17 hours ago, Rico Suave said: .45 ACP is a convenient size for small and medium sized handles. I file or grind down the rim for a smooth rounded transition. But didn't Clint Eastwood use .44 magnum for his ferrules? Quote Link to comment Share on other sites More sharing options...
Rico Suave Posted September 15, 2022 Report Share Posted September 15, 2022 3 hours ago, David Burgess said: But didn't Clint Eastwood use .44 magnum for his ferrules? Maybe, but a Luthier's got to know his/her limitations. T Quote Link to comment Share on other sites More sharing options...
