saintjohnbarleycorn Posted September 13, 2022 Report Share Posted September 13, 2022 I am reworking a viola I made 30 years ago when I knew even less than I do now, I have been trying to find dinemsions of the neck, mine was way too short , along with some other things. I have found string lengths and fingerboard dimensions. but the under side length I cannot find. any help would be appreciated. thanks kevin Quote Link to comment Share on other sites More sharing options...
Dwight Brown Posted September 13, 2022 Report Share Posted September 13, 2022 If you can tell me what to measure I have a nice 16” Whedbee here. DLB Quote Link to comment Share on other sites More sharing options...
Davide Sora Posted September 13, 2022 Report Share Posted September 13, 2022 34 minutes ago, saintjohnbarleycorn said: I have found string lengths and fingerboard dimensions. but the under side length I cannot find. What do you mean by under side length? Quote Link to comment Share on other sites More sharing options...
deans Posted September 13, 2022 Report Share Posted September 13, 2022 Whatever the size of the instrument, I like when it follows the 2/3 rule. Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted September 13, 2022 Author Report Share Posted September 13, 2022 sorry the heel to the chin, and the nut to the end of neck, without the fingerboard , and nut to bridge length , I have found a few different lengths for nut to bridge . Quote Link to comment Share on other sites More sharing options...
Dwight Brown Posted September 13, 2022 Report Share Posted September 13, 2022 Heel to chin, 127.5 mm Nut to end of neck 167mm Nut to bridge 365mm (vibrating string length) if you want the dimensions from the top of the nut for the last two add 10mm This instrument is a Brothers Amati Model with a length of back of 408 mm. measurements taken with a Mitutoyo vernier caliper or a Starrett metric tape measure DLB Quote Link to comment Share on other sites More sharing options...
jacobsaunders Posted September 13, 2022 Report Share Posted September 13, 2022 13 minutes ago, Dwight Brown said: Heel to chin, 127.5 mm Nut to end of neck 167mm Nut to bridge 365mm (vibrating string length) I thought Americans used inches Quote Link to comment Share on other sites More sharing options...
Dwight Brown Posted September 13, 2022 Report Share Posted September 13, 2022 I was a science teacher. All science is taught in metric (SI) here. American Customary Measurement is a PITA! I wish we would change. Only the USA, Myanmar, and Liberia are left, and I think Myanmar uses Imperial which is different again! Would you believe that most American made cars use Metric fastenings. My Chevrolet Corvette is all metric and I know all of Tesla is Metric. DLB Quote Link to comment Share on other sites More sharing options...
nathan slobodkin Posted September 13, 2022 Report Share Posted September 13, 2022 2 hours ago, deans said: Whatever the size of the instrument, I like when it follows the 2/3 rule. Yup. 2/3 the stop length will usually be fine. Quote Link to comment Share on other sites More sharing options...
Davide Sora Posted September 13, 2022 Report Share Posted September 13, 2022 1 hour ago, saintjohnbarleycorn said: sorry the heel to the chin, and the nut to the end of neck, without the fingerboard , and nut to bridge length , I have found a few different lengths for nut to bridge . You forget to tell us what body size your viola is, and above all what the stop length is, which is decisive for the length of the neck if you want to keep 2:3 ratio. Some make the neck length 150 mm regardless of the length of the body stop, without respecting the 2:3 ratio, but I am not one of them Heel to chin: I wouldn't worry about this size, because if the chin is aligned with the nut (as it should be), if the back button is not exaggeratedly out of the ordinary, and if the neck length (nut to belly edge) is correct, the heel to chin distance will always be ok. Nut to bridge: i.e. string length. I think 370/375 mm it is the most frequently used measure, but it can vary, based on the previous measures. Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted September 13, 2022 Author Report Share Posted September 13, 2022 yes again sorry , its a 16" Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted September 13, 2022 Author Report Share Posted September 13, 2022 also thanks for the patience and answers Quote Link to comment Share on other sites More sharing options...
Davide Sora Posted September 13, 2022 Report Share Posted September 13, 2022 1 hour ago, saintjohnbarleycorn said: yes again sorry , its a 16" I'm the one who must apologize, I hadn't seen it was in the title Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted September 14, 2022 Author Report Share Posted September 14, 2022 ha I forgot I put it there too! thanks dwight !! Quote Link to comment Share on other sites More sharing options...
