Richard4u Posted August 9, 2022 Report Share Posted August 9, 2022 So, something odd happened when I was prepping my newest violin to be varnished. I started with the ground coat which I used washed linseed oil for. That was two coats rubbed very thin with a new tee-shirt from Target. Then, I decided on a whim to put the next coat which was teak oil. After it had dried in the light box, I put Old Wood's golden yellow refractive ground coat on the violin. But it didn't stay yellow. It turned into a cinnamon/light brown color. Has anyone else had something like this happen? Rich Quote Link to comment Share on other sites More sharing options...
FiddleDoug Posted August 9, 2022 Report Share Posted August 9, 2022 I'm far from an expert, but I always understood that the ground coat goes on first. I could be wrong about that as a generalization. I guess that that doesn't address the color change. Quote Link to comment Share on other sites More sharing options...
arglebargle Posted August 9, 2022 Report Share Posted August 9, 2022 Sounds like a much better ground color than golden yellow. Quote Link to comment Share on other sites More sharing options...
Mark Norfleet Posted November 13, 2022 Report Share Posted November 13, 2022 You probably should have used an old T-shirt which had been washed several times. Try again. Quote Link to comment Share on other sites More sharing options...
nathan slobodkin Posted November 13, 2022 Report Share Posted November 13, 2022 Had you used the golden ground stuff before? If not Golden Yellow can mean different things and as Argle said cinnamon brown is a good start for a nice finish. Quote Link to comment Share on other sites More sharing options...
DarylG Posted November 13, 2022 Report Share Posted November 13, 2022 Depending on the brand, "teak oil" could be any number of different things. Quote Link to comment Share on other sites More sharing options...
JacksonMaberry Posted November 14, 2022 Report Share Posted November 14, 2022 First, I want to agree that the cinnamon is a better base color to varnish on. Second, if you've read the directions for the OldWood product (I haven't) and then didn't follow them, then you're off into uncharted territory and I wish you luck. It does seem rather odd to me to oil, then oil again with a different one, then do any kind of ground. It's a bit like wearing a belt and braces at the same time. With a couple of exceptions, the great violin makers of old had a very difficult time keeping the rent paid, and probably finished as simply and quickly as possible. With that in mind, there are a lot of historically viable methods of grounding that can be done in one go. Edit: I've now read the OldWood instructions, and it's clear they've designed the stuff to be applied directly to the wood with a view to penetrating it a bit. So it can't quite do it's job as intended if you've already sealed with oil. Quote Link to comment Share on other sites More sharing options...
Michael Szyper Posted November 15, 2022 Report Share Posted November 15, 2022 It also is not the greatest idea to go lean over fat. Quote Link to comment Share on other sites More sharing options...
JacksonMaberry Posted November 15, 2022 Report Share Posted November 15, 2022 30 minutes ago, Michael Szyper said: It also is not the greatest idea to go lean over fat. I agree in general, but the rule totally breaks down when the fat is in the wood. I have tested this extensively. If the fat is even slightly film building then the rule applies. Quote Link to comment Share on other sites More sharing options...
Nick Allen Posted November 15, 2022 Report Share Posted November 15, 2022 I hope your oils were hear bodied or you had quite a bit of manganese or lead in them. Otherwise, you just perma-sogged your plates. I would suggest rubbing in some metal driers and sunning the bastard for several weeks to a few months to cure that finish. We generally put the leanest elements on the wood before anything else to prevent strange cracking or even shifting of the layers. I had luck with heat bodied linseed and a ton of manganese in the wood. But only a little bit burnished in with a linen cloth. Heat building kind of action. So most of it was buffed off. Then UV cabinet for a LONG time. Quote Link to comment Share on other sites More sharing options...
JacksonMaberry Posted November 15, 2022 Report Share Posted November 15, 2022 7 minutes ago, Nick Allen said: I hope your oils were hear bodied or you had quite a bit of manganese or lead in them. Otherwise, you just perma-sogged your plates. I would suggest rubbing in some metal driers and sunning the bastard for several weeks to a few months to cure that finish. We generally put the leanest elements on the wood before anything else to prevent strange cracking or even shifting of the layers. I had luck with heat bodied linseed and a ton of manganese in the wood. But only a little bit burnished in with a linen cloth. Heat building kind of action. So most of it was buffed off. Then UV cabinet for a LONG time. Nick, Manganese helps substantially with drying when used in a much smaller percentage than most metal driers, around 0.2% as Mn by mass. beyond that, it's doesn't actually work any better or faster. Just a heads up, because this toxic af and you don't want any more than you need. Quote Link to comment Share on other sites More sharing options...
Nick Allen Posted November 15, 2022 Report Share Posted November 15, 2022 14 hours ago, JacksonMaberry said: Nick, Manganese helps substantially with drying when used in a much smaller percentage than most metal driers, around 0.2% as Mn by mass. beyond that, it's doesn't actually work any better or faster. Just a heads up, because this toxic af and you don't want any more than you need. Yeah but I'll die faster so let's GOOOOOO!!! Quote Link to comment Share on other sites More sharing options...
Nick Allen Posted November 15, 2022 Report Share Posted November 15, 2022 But I didn't know that. I took the human nature route and figured more was more. Good to know. Thanks! Quote Link to comment Share on other sites More sharing options...
JacksonMaberry Posted November 15, 2022 Report Share Posted November 15, 2022 49 minutes ago, Nick Allen said: Yeah but I'll die faster so let's GOOOOOO!!! I mean, I feel this for sure man. Quote Link to comment Share on other sites More sharing options...
