P J Lester Posted April 27 Report Share Posted April 27 I am wondering, is this dark area 'antiquing' or age related patina? Quote Link to comment Share on other sites More sharing options...
nathan slobodkin Posted April 27 Report Share Posted April 27 Need to see more of the violin. It certainly has a generous helping of rosin/ crud built up but may also have had an antiqued finish when new. Quote Link to comment Share on other sites More sharing options...
Andreas Preuss Posted April 27 Report Share Posted April 27 On some old violins the antiquing is rather simple. Markneukirchen makers used ‘Setzerbeize’ to be stomped into the still soft varnish, mostly around the edges. French makers made often ‘la moustache’ which is a blackened area between bridge and fingerboard. Yours could be the latter, but there is a chance that it has naturally enlarged with colophany dust and dust. Quote Link to comment Share on other sites More sharing options...
deans Posted April 27 Report Share Posted April 27 Yeah, I think its a combination of both. I believe a lot of the dings are "antiquing". Quote Link to comment Share on other sites More sharing options...
David Burgess Posted April 27 Report Share Posted April 27 12 hours ago, nathan slobodkin said: Need to see more of the violin. It certainly has a generous helping of rosin/ crud built up but may also have had an antiqued finish when new. Agreed. Quote Link to comment Share on other sites More sharing options...
