2blink Posted April 22, 2022 Report Share Posted April 22, 2022 My daughter's violin; the neck feels very dry. Difficult to describe; but it feels like it's gonna grow splinters sometime soon type of dry. Aside from adding water to the humidi-bar inside the case; what else can I do about it? Any potential oils I can put on it that won't harm it? Quote Link to comment Share on other sites More sharing options...
duane88 Posted April 22, 2022 Report Share Posted April 22, 2022 If the neck is varnished or finished it won't take any oil. You could lightly dampen a paper towel with a bit of olive oil and rub it into the neck. Let it sit for a few minutes, then do it again. Finish by burnishing it with a coarse cloth or very fine steel wool. Avoid getting oil anywhere else, and if you see a gap between the ebony of the fingerboard and the white wood of the neck, do not use oil as it will possibly interfere with the glue joint between the two. A violin maker wouldn't charge much to make the neck smooth and shiny...(says the violin maker) Quote Link to comment Share on other sites More sharing options...
Shunyata Posted May 23, 2022 Report Share Posted May 23, 2022 Use a little carnauba paste to polish the neck wood. You can buy this as a wood polish. Stay away from automotive carnauba waxes as they can have soaps or solvents in them. Quote Link to comment Share on other sites More sharing options...
RobP Posted May 31, 2022 Report Share Posted May 31, 2022 On 5/23/2022 at 10:26 AM, Shunyata said: Use a little carnauba paste to polish the neck wood. You can buy this as a wood polish. Stay away from automotive carnauba waxes as they can have soaps or solvents in them. Johnson's floor wax. It's widely available at most big box home stores and it's made for wood. Quote Link to comment Share on other sites More sharing options...
