Cincitaipei Posted March 10, 2022 Report Share Posted March 10, 2022 I bought a Jackson Gulden violin and had it shipped to family. I am planning on it being a "summer project." Depending on the condition, I may just put new strings and maybe a new tailpiece on it, but otherwise I may also play around with the bridge, nut or more radical interventions. I also may put a lower bridge on it and try it as a fiddle. I am curious about the varnish. Is the black on the front and bouts part of the company's varnish, or is it from years of rosin? I am wondering if it will clean up more or if this was their style? Is it worth messing with, or will I likely just make things worse? Quote Link to comment Share on other sites More sharing options...
Brad Dorsey Posted March 10, 2022 Report Share Posted March 10, 2022 The light and dark areas of this violin are antiquing, with the light areas imitating where varnish would have worn off of an old instrument and the dark areas imitating dirt and rosin accumulation. I think that this violin is very clean. I think that the Jackson-Guldan mass-production methods included a sprayed-on very durable finish, which I suspect could be safely cleaned with alcohol. If you want to do this, first try it under the chinrest and make sure you're not taking off the finish before proceeding to other areas. Alcohol should not be used to clean most violins, because it will remove many varnishes. Quote Link to comment Share on other sites More sharing options...
Cincitaipei Posted March 10, 2022 Author Report Share Posted March 10, 2022 This is very helpful. I know that these violins don't have the best reputation, but hoping it will be fun to play with. It looked like it may be potentially playable at least. If I wanted to touch up bare spots on the violin (under the bridge, chipped areas) do you have any thoughts on an appropriate material would be? (I am curious what this alcohol friendly coating is!) Thank you for the help! Quote Link to comment Share on other sites More sharing options...
J-G Posted March 10, 2022 Report Share Posted March 10, 2022 That's a pretty different look from the varnish on my Jackson (now long gone). Quote Link to comment Share on other sites More sharing options...
Brad Dorsey Posted March 10, 2022 Report Share Posted March 10, 2022 7 hours ago, Cincitaipei said: …If I wanted to touch up bare spots on the violin[,]…do you have any thoughts on [what] an appropriate material would be?… No matter what type of varnish was originally on the instrument, almost all violin varnish touch-up is done by applying alternating layers of colored pigments and thin coats of clear spirit varnish. Quote Link to comment Share on other sites More sharing options...
Cincitaipei Posted June 13, 2022 Author Report Share Posted June 13, 2022 Belatedly replying to say that it I feel like it is a decent violin. I have some helicore heavy tensions on it with the original tailpiece (no tuners) and it is quite loud. It is polishing up pretty well. I bought a tailpiece with tuners that should arrive tomorrow. For touch up there are a couple of scraped parts on edges, but I probably won't deal with them yet. The pegholes also seem to be fairly worn with pegs sticking out a half centimer. I'm not sure what to do about that. I'm getting peg compound and hoping the new tailpiece will slow wear and tear. I'm also trying to figure out what to do with the case, whether to just toss it and buy a new one or save it if I resell it or try some type of treatment (which would probably be sanding it down and a recoating of some type). Right now the original coating is pealing. It definitely will do for a fiddle for the kids when we're visiting family. Thank you for the earlier advice here. Quote Link to comment Share on other sites More sharing options...
Cincitaipei Posted June 13, 2022 Author Report Share Posted June 13, 2022 The case it came with is a GSB and apparently they were manufactured 1880-1920ish, so I am wondering if this is an earlier Jackson Gulden. Based on the appearance I figured it would be a post-war instrument. The violin seems a little on the lighter side, which I think is probably a good sign. Quote Link to comment Share on other sites More sharing options...
brokenbow Posted June 13, 2022 Report Share Posted June 13, 2022 That instrument needs nothing more than violin/guitar polish. Alcohol may damage lacquer finishes--and lacquer is a good possibility with sprayed on finishes of mid century instruments. Naptha is a better choice for cleaning of soiled lacquer finishes--this violin is not soiled. Guldan not Gulden Quote Link to comment Share on other sites More sharing options...
baroquecello Posted June 13, 2022 Report Share Posted June 13, 2022 Good chance is the pegs were never properly fit. You could saw off the extending end and finish it in a nicer way. If the pegs dont turn well, before using peg done, give then and the peg holes a good clean, so that guck, that may be deforming the pegs or the hole, is first removed. If that doesnt help, give the peg a couple of fast turn and feel if heat is generated on the pegs where they touch the pegbox. It should bevequally warm on both sides. Often the thicker end makes contact, but the thin end doesnt. If that is the case, you can improve fit by ever so slightly sanding the side that makes contact, thus locally decreasing thickness. Really minute amounts of material should be removed untol both sides make contact. Then peg dope and it should be good to go. Quote Link to comment Share on other sites More sharing options...
Al Cramer Posted June 16, 2022 Report Share Posted June 16, 2022 Just to add to Brad Dorsey's last comment -- -- and writing as a complete non-pro -- I've had good results fixing damaged finishes on instruments using watercolors and spirit varnish. For watercolors, a basic 12-pan set of Winsor-Newton colors is all you need. For varnish, I use Behlen spirit varnish, thinned down with denatured alcohol. Also you need nice squirrel hair brushes. It takes a while to get the hang of restoration (it's all about multiple layers) but if you take some time to mess around on scrap surfaces it's pretty amazing what you can do. One of my big goals in life was to become an incredibly successful art-forger: never realized that goal, but restoring violin finishes has been almost as satisfying. Quote Link to comment Share on other sites More sharing options...
