Dr. Leo Kadehjian Posted December 21, 2021 Report Share Posted December 21, 2021 Just wondering why the bass bar is on the bass side and the soundpost on the treble side of the bridge. What acoustic reason is there for this arrangement given that the top and bottom plates are effectively symmetrical across the bouts. Only difference is where the upper and lower strings lie, and tension (force on the bridge should be effectively the same on both sides). Has anyone ever tried switching them while leaving the string arrangement as usual (as opposed to making an instrument for left-handed bowing, with upper string on left, lower string on right, and switching the bass bar and sound post positions accordingly, or rather leaving the sound post and bass bar as normal but simply changing the string arrangement)? Quote Link to comment Share on other sites More sharing options...
Dwight Brown Posted December 22, 2021 Report Share Posted December 22, 2021 The only time I have heard of them being switched is for a rare left handed player. DLB Quote Link to comment Share on other sites More sharing options...
chiaroscuro_violins Posted December 22, 2021 Report Share Posted December 22, 2021 / Quote Link to comment Share on other sites More sharing options...
FiddleDoug Posted December 22, 2021 Report Share Posted December 22, 2021 Here’s a guess, based on my science background. The soundpost has less mass, and probably a higher resonant frequency, which would work better with higher frequency from the treble bridge foot. The bass bar, along with the front plate (glued together as a unit) would have a lower frequency, would be better coupled to the bass bridge foot. Does that make any sense? Quote Link to comment Share on other sites More sharing options...
baroquecello Posted December 22, 2021 Report Share Posted December 22, 2021 I tried it on a cello (inverse string placement) the a string sound lost core and was out of focus, the c string got wolfy. It had terrible string reponse and not great sound. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted December 22, 2021 Report Share Posted December 22, 2021 We had decent results on a violin we switched over to lefty playing, by leaving the bass bar and soundpost in the "righty" position. Quote Link to comment Share on other sites More sharing options...
Bill Yacey Posted December 23, 2021 Report Share Posted December 23, 2021 3 hours ago, David Burgess said: We had decent results on a violin we switched over to lefty playing, by leaving the bass bar and soundpost in the "righty" position. My experience on the one violin I setup for left was much the same. Quote Link to comment Share on other sites More sharing options...
Mat Roop Posted December 23, 2021 Report Share Posted December 23, 2021 my guess is that the back is of relatively high density wood, making it more conducive for producing higher frequency vibrations... hence the soundpost under the treble side of the bridge will transmit the treble vibrations to the back. Conversely, the top is of lower density conducive to producing lower frequency vibrations and so the bass side of the bridge needs to transmit the bass frequencies to the top via the bass bar, and not to the back.... my 2 simplistic cents:) Quote Link to comment Share on other sites More sharing options...
jacobsaunders Posted December 23, 2021 Report Share Posted December 23, 2021 20 hours ago, David Burgess said: We had decent results on a violin we switched over to lefty playing, by leaving the bass bar and soundpost in the "righty" position. I had to fit a sound post on the “wrong” side for a left-hander once. Fitting the post on the wrong side is dead awkward, you feel like a cripple doing it Quote Link to comment Share on other sites More sharing options...
martin swan Posted December 24, 2021 Report Share Posted December 24, 2021 1 hour ago, jacobsaunders said: I had to fit a sound post on the “wrong” side for a left-hander once. Fitting the post on the wrong side is dead awkward, you feel like a cripple doing it Yes, it's kind of comical how hard it is to do ... also fitting a bridge the wrong way round. The worst is trying to play a violin strung left-handed. I can sort of manage Three Blind Mice with 10 minutes' practice, but am then incapable of playing a conventional violin for hours afterwards ... Quote Link to comment Share on other sites More sharing options...
Marty Kasprzyk Posted December 24, 2021 Report Share Posted December 24, 2021 If you just play in front of a mirror you will see everything is reversed left and right but that it doesn't change your sound at all. Quote Link to comment Share on other sites More sharing options...
Brad Dorsey Posted December 24, 2021 Report Share Posted December 24, 2021 6 hours ago, jacobsaunders said: I had to fit a sound post on the “wrong” side for a left-hander once. Fitting the post on the wrong side is dead awkward, you feel like a cripple doing it 2 hours ago, martin swan said: Yes, it's kind of comical how hard it is to do ... also fitting a bridge the wrong way round... I found the several occasions that I set up violins left-handed to be profoundly disorienting experiences. It seemed like some circuits in my brain got reversed, with the effect lasting for an hour or so. I drove somewhere after doing one and I felt like I was driving on the wrong side of the road. Quote Link to comment Share on other sites More sharing options...
