Rue Posted December 22, 2021 Report Share Posted December 22, 2021 https://store.bovedainc.com/collections/boveda-for-wood-instruments Humidity control. Quote Link to comment Share on other sites More sharing options...
MaryS Posted January 24 Author Report Share Posted January 24 Hello everyone, I am once again asking for Violin advice. This is in regards to the violin above. When it was finished being restored (to the best of my ability) it played fine, no buzzes or anything. Now, however, it has a pretty aggressive buzz on the E string. Specifically when playing F sharp. It goes away when playing G or A, but is present when playing open E and that F. I have checked the scoop and it appears to be correct and I'm not seeing any obvious bumps. Should I plane the fingerboard again or what other options do I have? I also checked the nut to see if maybe the string has too much wiggle room and that is in spec as well. Thank you in advance! Quote Link to comment Share on other sites More sharing options...
chiaroscuro_violins Posted January 24 Report Share Posted January 24 / Quote Link to comment Share on other sites More sharing options...
Brad Dorsey Posted January 24 Report Share Posted January 24 1 hour ago, MaryS said: …When it was finished being restored[,]…it played fine, no buzzes or anything. Now, however, it has a pretty aggressive buzz on the E string… Winter dryness could be shrinking the body wood in a way that raises the fingerboard, making the bridge too low. I’ve been seeing this recently as a cause of cello buzzes, but the same thing can happen to violins. If this is the cause, you need a higher bridge. What are your G and E string clearances at the wide end of the fingerboard? Quote Link to comment Share on other sites More sharing options...
GeorgeH Posted January 24 Report Share Posted January 24 Check your index finger fingernail for the F# problem. Quote Link to comment Share on other sites More sharing options...
MaryS Posted January 28 Author Report Share Posted January 28 On 1/24/2022 at 1:27 PM, Brad Dorsey said: Winter dryness could be shrinking the body wood in a way that raises the fingerboard, making the bridge too low. I’ve been seeing this recently as a cause of cello buzzes, but the same thing can happen to violins. If this is the cause, you need a higher bridge. What are your G and E string clearances at the wide end of the fingerboard? The G is at 5 and the E is at 3.8. Quote Link to comment Share on other sites More sharing options...
MaryS Posted January 28 Author Report Share Posted January 28 On 1/24/2022 at 4:05 PM, GeorgeH said: Check your index finger fingernail for the F# problem. I cut my nails to basically nubs (no white), so we are good there. That is a valid suggestion though, I've known many girls who have long nails and wonder why their violins do not sound good. Quote Link to comment Share on other sites More sharing options...
Rue Posted January 28 Report Share Posted January 28 Just on the fingernail topic...I actually don't know anyone who plays the violin with 'longer' nails - because...you can't! And since I started learning guitar...I have developed 'guitar fingers' on my left hand as well. The calluses have altered the way my fingertips look...and they are obviously different now when compared to the right hand. Quote Link to comment Share on other sites More sharing options...
pyrola_asarifolia Posted January 28 Report Share Posted January 28 My cello just developed an absolutely atrocious buzz that had me pull my hair in frustration. It does have an open seam, which apparently I'm going to glue myself with my luthier giving me a walkthrough (!) (closest luthier is 350 miles away, and I'm not going there during the Omicron spike). But just today it turned out that the problem was not there. It was an accumulation of re-solidified rosin dust that attached the tip of the wing of one f-hole to the opposite bit of wood of the belly. Wow. I took it out with a pair of nail clippers (as a spear) and a bit of sandpaper and buzz is gone. Quote Link to comment Share on other sites More sharing options...
MaryS Posted January 29 Author Report Share Posted January 29 19 hours ago, Rue said: Just on the fingernail topic...I actually don't know anyone who plays the violin with 'longer' nails - because...you can't! And since I started learning guitar...I have developed 'guitar fingers' on my left hand as well. The calluses have altered the way my fingertips look...and they are obviously different now when compared to the right hand. I've dealt out some heartbreaks with having to tell students that they have to take off their acrylic nails or that they have to cut them. I have found those students don't last very long....... Quote Link to comment Share on other sites More sharing options...
