Hopf violin id
Mat Roop
I recently read a description of an  identifiable feature of Hopf violins ..." its slightly "angular" upper bout
What is meant by "angular"?  ... is that the slight reduction of rib height from the upper blocks to the neck?
If so, is that peculiar to Hopf, primarily?
Cheers, Mat
The masses of the Dutzendarbeit fiddles with “Hopf” stamp, made by many artisans not necessarily named Hopf, supplied through wholesalers like G.A.Pfretschner et al had a squarish outline, which is probably what is meant. Funnily enough, if you go to the Museum in Markneukirchen and look at instruments made by a real person called Hopf, they aren’t really like that at all, so you should probably change your reading habits:)
What is meant by "angular"?…
I’ve most-often heard Hopfs described as “square-shouldered,” meaning that, in outline, the upper part of the upper bout has less curve than most violins and is perpendicular to the instrument centerline, and then at the “shoulders” the outline turns rather abruptly and becomes parallel to the centerline before turning in toward the C bouts.
Isn't that squarish outline and model the primary distinguishing features of the Dutzendarbeit fiddles from Klingenthal compared to similarly made violins from Markneukirchen?
27 minutes ago, GeorgeH said:
Care to elaborate? Are there any distinguishing features of the Dutzendarbeit fiddles from Klingenthal compared to cottage industry violins from Markneukirchen? Thank you.
If you are suggesting that the Dutzendarbeit with squarish shoulders are from Klingenthal, and the ones from Markneukirchen have roundish outlines and Bob’s your uncle, as an attribution approach, I would find that pretty lobotomised
I am asking a question, and not assuming nor suggesting an answer.
Are there any distinguishing features of the mass-produced fiddles from Klingenthal compared to cottage industry violins from Markneukirchen? If yes, could you elaborate on what those features are?
And I do not have an Uncle Bob. :)
The Vogtländische Dutzendarbeit of the last quarter of the 19th C used a more or less identical system of work throughout the area, and are thus impossible to divide up into each of the 27 or so towns/villages
30 minutes ago, reg said:
So why, Jacob, are some so very square and others rounded down but all from the same region?
Was it at the whim of the maker or just a prevailing fashion?
They come in all sorts of shapes and sizes, it would be naive to suppose each of the 30 odd towns/villages had their own exclusive shape.
Did the buyers make the decisions as to what models and/or shapes were to be made and how many?
In the states, the vast majority of cottage industry violins with "Hopf" stamped under the button have this square shoulder shape.
I think most of us define "Hopfs" based on the stamp. I suspect that these stamps have little to do with the intention of the makers, but were just randomly put on instruments by a middle man. Maybe they preferred to put the Hopf stamp on squarer fiddles and a "Glass" stamp on others. But thats really all they are - stamps.
