Vion Posted October 14, 2021 Report Share Posted October 14, 2021 Another one from the collection! What can you tell me about this violin? Came in an 19th century wooden violin case. I think the violin is much older, tho. Any idea of the possible maker? Also, i se that the f-hole is changed, why is that? Thank you, Maestronet! Quote Link to comment Share on other sites More sharing options...
Blank face Posted October 14, 2021 Report Share Posted October 14, 2021 19th century seems right to me. It’s a built on the back construction with an unusually deeply fluted scroll (maybe overworked), but nonetheless (West)Bohemian in my eyes. I can see no alterations to the ff, the shape is very common for this origin. What was altered was more probably the varnish. Unfortunately the long bottom post crack and the revarnishing is reducing the value dramatically. Quote Link to comment Share on other sites More sharing options...
Wood Butcher Posted October 14, 2021 Report Share Posted October 14, 2021 It’s just the nicks on the soundholes that have been changed. The soundholes are the original shape otherwise. Quote Link to comment Share on other sites More sharing options...
Blank face Posted October 14, 2021 Report Share Posted October 14, 2021 15 minutes ago, Wood Butcher said: It’s just the nicks on the soundholes that have been changed. The soundholes are the original shape otherwise. I would rather guess that the actual are the original nicks, because they are (roughly) in the mid of the f, while the other, extremely way down, were a kind of failed experiment and therefore filled again later. Quote Link to comment Share on other sites More sharing options...
GeorgeH Posted October 14, 2021 Report Share Posted October 14, 2021 It looks to me kind of like a piece of wood was added to the bass f to replace the lower wing. Quote Link to comment Share on other sites More sharing options...
BassClef Posted October 14, 2021 Report Share Posted October 14, 2021 5 minutes ago, GeorgeH said: It looks to me kind of like a piece of wood was added to the bass f to replace the lower wing. This looks like a correct assessment to me. Possibly the f hole notches were unusually low to begin with so someone crudely filled them in and moved them higher to conform to the “standard” aesthetic. Quote Link to comment Share on other sites More sharing options...
Vion Posted October 14, 2021 Author Report Share Posted October 14, 2021 (edited) Do you think it is worth going to the luthier and repairing it? What do you belive it should cost me and what do you think it is worth repaired? Also i want to tell you it has light construction. Compared to two other bohemian violins i own, it is very light. Do you think it will have good sound? Edited October 14, 2021 by Vion Quote Link to comment Share on other sites More sharing options...
GeorgeH Posted October 14, 2021 Report Share Posted October 14, 2021 39 minutes ago, Vion said: Do you think it is worth going to the luthier and repairing it? Personally, I don't. The sound post crack in the back by itself makes it essentially worthless. It is impossible to predict if "it will have good sound," but you would be better off spending your money on a violin in good repair that you can play. Quote Link to comment Share on other sites More sharing options...
Mat Roop Posted October 15, 2021 Report Share Posted October 15, 2021 2 hours ago, Vion said: Do you think it is worth going to the luthier and repairing it? What do you belive it should cost me and what do you think it is worth repaired? Also i want to tell you it has light construction. Compared to two other bohemian violins i own, it is very light. Do you think it will have good sound? Worth going to a luthier for an opinion... but I suspect they will say no to repair. Cost.. way more than its worth! Quote Link to comment Share on other sites More sharing options...
Gtone Posted October 15, 2021 Report Share Posted October 15, 2021 Is this loosely based on a Stainer? Also Vion can you see linings and blocks? 3 hours ago, Blank face said: 19th century seems right to me. It’s a built on the back construction with an unusually deeply fluted scroll (maybe overworked), but nonetheless (West)Bohemian in my eyes. I can see no alterations to the ff, the shape is very common for this origin. What was altered was more probably the varnish. Unfortunately the long bottom post crack and the revarnishing is reducing the value dramatically. Blankface, is the uneven back plate join significant for this region.West Bohemia could this have pine blocks instead of linings? seems wonky, the ribs! and maybe no corner blocks, based on Vions' comments of being light. Thanks Quote Link to comment Share on other sites More sharing options...
Blank face Posted October 15, 2021 Report Share Posted October 15, 2021 5 hours ago, Gtone said: Is this loosely based on a Stainer? Also Vion can you see linings and blocks? Blankface, is the uneven back plate join significant for this region.West Bohemia could this have pine blocks instead of linings? seems wonky, the ribs! and maybe no corner blocks, based on Vions' comments of being light. Thanks The uneven back joint is evidence of an uneven reglueing, but not of any particular school. Also the model isn’t a copy of anything, neither Stainer nor something else. I’m not sure what you are meaning with pine blocks instead of linings, but some much older schools than this used such blocks. The OP here I would expect to have pine linings; the wonkyness has more to do with the hastyness of the construction on the back, corner blocks were added (or weren’t) later with this method in any case. Quote Link to comment Share on other sites More sharing options...
Gtone Posted October 15, 2021 Report Share Posted October 15, 2021 2 hours ago, Blank face said: The uneven back joint is evidence of an uneven reglueing, but not of any particular school. Also the model isn’t a copy of anything, neither Stainer nor something else. I’m not sure what you are meaning with pine blocks instead of linings, but some much older schools than this used such blocks. The OP here I would expect to have pine linings; the wonkyness has more to do with the hastyness of the construction on the back, corner blocks were added (or weren’t) later with this method in any case. Yes I couldn't see the neck joint at the top plate so I thought it may be a through neck. I was thinking older because I had been reading something Jacob Saunders and Yourself were talking about, Steiger.I know you said west Bohemia,wasn't doubting you,just following my nose. Thanks Blankface for following up. Quote Link to comment Share on other sites More sharing options...
martin swan Posted October 15, 2021 Report Share Posted October 15, 2021 12 hours ago, Blank face said: I would rather guess that the actual are the original nicks, because they are (roughly) in the mid of the f, while the other, extremely way down, were a kind of failed experiment and therefore filled again later. Agree, maybe the violin in its original form has a short stop ...? Quote Link to comment Share on other sites More sharing options...
