Help with id please
Vion
Hi, do you know what violin is this? Why is it signed inside, aside from the label ( the label is mostly worn off, and it says 1729, the signature, dated 1967, maybe is from a luthier). Do you recognize the label or the signature. Also sorry for any mistakes, english is not my first language.
Thank you for your help!
Assuming that you have it, and that you can string it up, how does it sound?  :)
1 hour ago, Vion said:
Hi again! Is this crack dangerous? Should i get it fixed right away? The soundpost is fallen, also, but the violin is not under tension.
Yes you should get this fixed immediately, you just can’t use the violin like this.
The crack looks clean, and this is the best for a good repair. Once rosin and dirt get into the crack, it’s harder to repair, and may not hold as long.
