vathek Posted August 29, 2021 Report Share Posted August 29, 2021 This is a very nice German gold mounted vintage bow. Wood is straight grained and it looks like quality materials were used. I'm curious to know if it has any elements that can pin it down to a possible maker (possibly Siefert?). There are no pins in the adjuster. The adjuster has a split in one of the gold covers and I wonder whether I should send it to a bow maker or if a jeweler could do it. There are no string repair shops in my area. Quote Link to comment Share on other sites More sharing options...
Brad Dorsey Posted August 29, 2021 Report Share Posted August 29, 2021 I think it needs a bow maker’s attention. I doubt that a jeweler would have the necessary skills and equipment. Quote Link to comment Share on other sites More sharing options...
vathek Posted August 29, 2021 Author Report Share Posted August 29, 2021 Thanks Brad. Any suggestions? There is no one near here who can do it. Quote Link to comment Share on other sites More sharing options...
Brad Dorsey Posted August 29, 2021 Report Share Posted August 29, 2021 My only suggestion is to check the AFVBM roster for bow makers who do restorations. Quote Link to comment Share on other sites More sharing options...
PhilipKT Posted August 30, 2021 Report Share Posted August 30, 2021 @jezzupe is an expert Quote Link to comment Share on other sites More sharing options...
jezzupe Posted August 30, 2021 Report Share Posted August 30, 2021 6 hours ago, PhilipKT said: @jezzupe is an expert bows, no, I've certainly worked with gold , I think the question or challenge is can it be braised on the spot and then leveled down or will complete disassembly be required , something tells me the later is the safest and probably only way to go to repair the screw without doing damage. and frying the stick..."ya we were able to close up that gap, the stick caught fire but boy that seam sure is closed up" on a more serious note, I do think that with the screw removed from the stick and the spacer shielded and isolated that gold solder could be braised on and then leveled and polished fairly easily, for the flat part, the little crimp and detail at the end, that would be hard to blend in Quote Link to comment Share on other sites More sharing options...
Brad Dorsey Posted August 30, 2021 Report Share Posted August 30, 2021 When I said the job was beyond the capabilities of a jeweler, I was thinking of making a new ring. But perhaps a jeweler would be able to remove the split ring, solder the split and put it back on. I suggest you show it to a jeweler. The straightness of the split suggests that the original solder joint has separated. Quote Link to comment Share on other sites More sharing options...
PhilipKT Posted August 30, 2021 Report Share Posted August 30, 2021 9 hours ago, jezzupe said: bows, no, I've certainly worked with gold , I think the question or challenge is can it be braised on the spot and then leveled down or will complete disassembly be required , something tells me the later is the safest and probably only way to go to repair the screw without doing damage. and frying the stick..."ya we were able to close up that gap, the stick caught fire but boy that seam sure is closed up" on a more serious note, I do think that with the screw removed from the stick and the spacer shielded and isolated that gold solder could be braised on and then leveled and polished fairly easily, for the flat part, the little crimp and detail at the end, that would be hard to blend in Aren’t you the expert bow repairman? Did I mistake your for someone else? Quote Link to comment Share on other sites More sharing options...
vathek Posted August 30, 2021 Author Report Share Posted August 30, 2021 Thanks for the replies. I think this may have happened due to wood expansion and contraction under the ring. No thoughts on who may have made the bow? I guess another option would be just to leave it as is. Quote Link to comment Share on other sites More sharing options...
fiddlecollector Posted August 30, 2021 Report Share Posted August 30, 2021 should be a relatively easy repair removing the ring , soldering ,tidying up carefully especially the collar area and refitting it. Quote Link to comment Share on other sites More sharing options...
jezzupe Posted August 30, 2021 Report Share Posted August 30, 2021 2 hours ago, PhilipKT said: Aren’t you the expert bow repairman? Did I mistake your for someone else? `nope,yup,...but you leave it with me and I'll have that bow shootin' arrows in no time. Quote Link to comment Share on other sites More sharing options...
Rothwein Posted August 30, 2021 Report Share Posted August 30, 2021 Philip, you may be thinking of Triangle Strings, who at least on this forum have been quiet so as not to be accused of advertising. Quote Link to comment Share on other sites More sharing options...
duane88 Posted August 30, 2021 Report Share Posted August 30, 2021 I see a Grand Adam that has had that very same crack in the gold ring since who knows when, at least the 2001 Tokyo Exhibit. Hasn't gone anywhere yet. Unless it is moving when you tighten the bow, I'd be tempted to leave it, and if it is, I'd be tempted to suggest a replacement button and conserve the one we see. Quote Link to comment Share on other sites More sharing options...
Wood Butcher Posted August 30, 2021 Report Share Posted August 30, 2021 36 minutes ago, Rothwein said: Philip, you may be thinking of Triangle Strings, who at least on this forum have been quiet so as not to be accused of advertising. Or equally could be thinking of @fiddlecollector, who knows a hell of a lot about bows. Quote Link to comment Share on other sites More sharing options...
PhilipKT Posted August 30, 2021 Report Share Posted August 30, 2021 Jerry Pasiwics Is the guy I was thinking of, triangle strings.com. He’s not on maestronet much anymore, but he’s the expert boat repair guy, he’s posted often about detailed wood repair, and I’m just assuming that he can handle the metal work as well. Quote Link to comment Share on other sites More sharing options...
PhilipKT Posted August 30, 2021 Report Share Posted August 30, 2021 43 minutes ago, Rothwein said: Philip, you may be thinking of Triangle Strings, who at least on this forum have been quiet so as not to be accused of advertising. Yes, that’s exactly what I was thinking of. And he doesn’t post here very much anymore, and I was trying to find his email address. I also garbled the spelling of his last name, but there’s enough there for you to proceed if you wish Quote Link to comment Share on other sites More sharing options...
Rothwein Posted August 30, 2021 Report Share Posted August 30, 2021 10 minutes ago, Wood Butcher said: Or equally could be thinking of @fiddlecollector, who knows a hell of a lot about bows. Point taken, it's just easier to spell that than... Quote Link to comment Share on other sites More sharing options...
FiddleDoug Posted August 30, 2021 Report Share Posted August 30, 2021 Josh Henry is also a very talented bow person. https://www.fineviolinbows.com/ Quote Link to comment Share on other sites More sharing options...
Jeff White Posted August 30, 2021 Report Share Posted August 30, 2021 Any bowmaker in your area (or where you are comfortable mailing it) who is used to making bows with with gold (most all better makers) can easily handle this (As FC said). I'm not sure if Jerry P does much gold soldering, but it wouldn't surprise me and he would do a good job. I do this all the time on silver (pull the ring, solder, clean up and....), but not on gold. I would just pull it off and run it next door to the jeweler and have him solder it. You really don't want a jeweler removeing that ring and messing with your button. Quote Link to comment Share on other sites More sharing options...
Jeff White Posted August 30, 2021 Report Share Posted August 30, 2021 11 minutes ago, FiddleDoug said: Josh Henry is also a very talented bow person. https://www.fineviolinbows.com/ Agreed, Josh will do a good job for them. I know Rodney Mohr does Gold work on his bows and is quite good (ohio). Quote Link to comment Share on other sites More sharing options...
martin swan Posted August 30, 2021 Report Share Posted August 30, 2021 Very few bowmakers who use gold are confident about repairing/soldering gold on account of the low temperature required. I give this kind of work to our local jeweller/watch repairer - he always does a great job. Quote Link to comment Share on other sites More sharing options...
vathek Posted August 31, 2021 Author Report Share Posted August 31, 2021 The split is stable so it's not going anywhere but I'm beginning to think even tho this may be a basic procedure, it could be more pricey since gold is involved so I just may leave as is.. Quote Link to comment Share on other sites More sharing options...
nathan slobodkin Posted August 31, 2021 Report Share Posted August 31, 2021 19 hours ago, martin swan said: Very few bowmakers who use gold are confident about repairing/soldering gold on account of the low temperature required. I give this kind of work to our local jeweller/watch repairer - he always does a great job. Unless your jeweler is smarter that the ones around my area I would take the ring off first rather than giving him the bow. Also make sure they file and hand polish the repair rather than using an electric buffing wheel which is likely to soften the corners of the facets. Quote Link to comment Share on other sites More sharing options...
fiddlecollector Posted August 31, 2021 Report Share Posted August 31, 2021 21 hours ago, martin swan said: Very few bowmakers who use gold are confident about repairing/soldering gold on account of the low temperature required. I give this kind of work to our local jeweller/watch repairer - he always does a great job. Martin its temperature when soldering is slightly higher than sterling silver. Ive never had any problem soldering gold.Though it is a little tricker since cadmium fluxes/solders were banned which worked great and at a slightly lower temp but now well known to give off nasty fumes. Quote Link to comment Share on other sites More sharing options...
martin swan Posted August 31, 2021 Report Share Posted August 31, 2021 4 hours ago, nathan slobodkin said: Unless your jeweler is smarter that the ones around my area I would take the ring off first rather than giving him the bow. Also make sure they file and hand polish the repair rather than using an electric buffing wheel which is likely to soften the corners of the facets. of course ... 2 hours ago, fiddlecollector said: Martin its temperature when soldering is slightly higher than sterling silver. Ive never had any problem soldering gold.Though it is a little tricker since cadmium fluxes/solders were banned which worked great and at a slightly lower temp but now well known to give off nasty fumes. OK thanks for the clarification - I wonder why people are reluctant. I had a very nice Prell in gold with a split in the button just like the OP's bow. Couldn't get any of my go-to bow restorers to touch it ... Quote Link to comment Share on other sites More sharing options...
