murray kuun Posted July 7, 2021 Report Share Posted July 7, 2021 I've always fitted to top before the back. I cannot remember why, must be the old (roneo'd) book I used in the beginning (before youtube). Is that the accepted way or does it not matter? I ask because one of the luthiers I follow on IG, fits the back first. Quote Link to comment Share on other sites More sharing options...
Wood Butcher Posted July 7, 2021 Report Share Posted July 7, 2021 I think you’ll find most fit the back first, as this is the way taught in schools. Quote Link to comment Share on other sites More sharing options...
uncle duke Posted July 7, 2021 Report Share Posted July 7, 2021 Based on what I have observed here I see most who do do it that way ensure themselves of a visually correct neck set into the lower pocket area. Quote Link to comment Share on other sites More sharing options...
Brad Dorsey Posted July 7, 2021 Report Share Posted July 7, 2021 I've never made a violin, but I've set lots of necks. It seems to me that one advantage of gluing the top first would be easier neck setting. The neck can be set without worrying about fitting it to the back button and then it is planed flush with the block. Some makers do it this way. Quote Link to comment Share on other sites More sharing options...
Wood Butcher Posted July 7, 2021 Report Share Posted July 7, 2021 1 hour ago, Brad Dorsey said: I've never made a violin, but I've set lots of necks. It seems to me that one advantage of gluing the top first would be easier neck setting. The neck can be set without worrying about fitting it to the back button and then it is planed flush with the block. Some makers do it this way. In theory there is an advantage, providing that you don’t need to push the ribs around a bit, to get the correct overhang. Otherwise, your carefully set neck is going to have a very different reading by the time it’s all together. With the body assembled first, you are setting the neck to a stable structure, and have greater control over the outcome. Quote Link to comment Share on other sites More sharing options...
nathan slobodkin Posted July 7, 2021 Report Share Posted July 7, 2021 2 hours ago, Wood Butcher said: In theory there is an advantage, providing that you don’t need to push the ribs around a bit, to get the correct overhang. Otherwise, your carefully set neck is going to have a very different reading by the time it’s all together. With the body assembled first, you are setting the neck to a stable structure, and have greater control over the outcome. Definitely. Quote Link to comment Share on other sites More sharing options...
