Could use a little help reading some handwriting...
Okay, first there's a large brand saying:
"reproduzzione
antonius straduarius
andreas morelli"
...and below that is a label saying:
"andreas morelli
hand-made reproduction
antonius stradivarius
anno 1724"
...and on that label is written -- see the photo.  I can make out "violin" and "serial number 792" but what are the first and third words?
2 hours ago, Delabo said:
I think it says..................
"model violin style 1 (landolfi ?) 1792"
The fact that the writing is illegible and is written over the label indicates that it was probably inscribed through the f-hole with a pen after the violin was closed.
A pen would have to be under 5mm in thickness for you to be able to write through the f-hole and the result would be much messier than that! And you'd probably bugger the f-hole ...
Ok, agreed, it does sound improbable, So what is the better explanation ?
I considered "model" but nothing there looks like a "d."
I think the new suggestion of "master" is more likely. My apologies' for not reading your opening remarks and seeing that you already had "serial no 792". Where on earth I got "Landolfi 1792" from is anyone's guess. I need new glasses ! :lol:
