tool from Dictum
tartarine
18 hours ago, tartarine said:
Hi
About twenty years ago I bought this tool (see pictures)
I would like to buy a new one but don't seem to be able to locate a seller
Does anybody knows ?
thanIMG_3325.jpg.2573a000d360a359dfeff989471d1fd0.jpgIMG_3326.jpg.e073787255abee066e61df0c34364838.jpgk you for your help
What is that tool, and what is the purpose?
I've been making for around 50 years, and don't recall having ever needed or used a cutting tool shaped like that.
Is it used to cut the sides of the purfling channel?
https://www.fine-tools.com/japcarv1.html
Here you have the same in the set. Hm, you will have to find it in Japan, if you buy just one.
Woodcarving - in violin making process has no use. (or maybe you can cut purfling ends.. Maybe)
If you buy it from Japan or Europe.. You will pay a lot + import charges. Think about purchasing a grinder, find an steel rod and make it. (or a friend with grinder or milling machine)
would you know where in Japan? a friend of mine lives in Kyoto , he could order it for me there. do you know the name of the firm which makes them and sell them other than in set?
or may be a shop ?
thanks in advance
by the way it is also a very good carving tool to make netsuke
or may be a shop ?
thanks in advance
I have no idea. If you google Kawasei you will find everything that is available on internet.
Here you can buy just one (No 13 ) from ebay. I found it in 1 minute -- just google a bit...
yes I found that too but it is not what I am looking for. I don't want a wooden handle
1 hour ago, Hierony said:
Come to think of it it looks like a small skew chiesel with a knurled metal handle. Is the tip particularly good steel or you just like the size/heft of the metal handle?
the steel is the best ever of all my japanese tools, the iron grip, quite thin ( ca 10mm) makes possible to use it in all the positions, it is relatively short . I also have short chisels from Pfeil but the handle is to cumbersome to be used as the Japanese one . So I like all of it !!!!!
I know that there is a Japanese tool maker who makes tools to order. I don't know his name or his address
Contact Iida Tomohito and see how much it would be to have it made.
iida@japantool-iida.com
Jesse
