christian bayon Posted May 6, 2021 Report Share Posted May 6, 2021 Can we imagine Tesla or Mercedes engIneers spending all their time studying De Dion Bouton or Delahayes cars? It’s what I did for 45 years being a good boy in violin-making. My approach today is bit different, I started my career as military aircraft engineer, why not to go back to this way of thinking? And if it’s to take inspiration on Andrea Amati, Antonio Stradivari or Guarneri del Gésù, why not to copy the spirit, innovative, than the objects! Having now a more practical approach of the physical of violin. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted May 6, 2021 Report Share Posted May 6, 2021 Wow!! How does it sound? Quote Link to comment Share on other sites More sharing options...
Peter K-G Posted May 6, 2021 Report Share Posted May 6, 2021 Quote Link to comment Share on other sites More sharing options...
christian bayon Posted May 6, 2021 Author Report Share Posted May 6, 2021 14 minutes ago, David Burgess said: Wow!! How does it sound? Three concertmaster in European orchestra and a soloist are using this new shape with good results. Quote Link to comment Share on other sites More sharing options...
Jim Bress Posted May 6, 2021 Report Share Posted May 6, 2021 Wow, that's definitely something new. "I started my career as military aircraft engineer" That was a 20 year chapter in my life. Do the structure supports (for lack of a better name) allow you to make the plates thinner? Thanks for showing your work. -Jim Quote Link to comment Share on other sites More sharing options...
violins88 Posted May 6, 2021 Report Share Posted May 6, 2021 Double wow! Quote Link to comment Share on other sites More sharing options...
FiddleDoug Posted May 6, 2021 Report Share Posted May 6, 2021 Very different! Is the "bassbar" carbon fiber? And does it touch the cross support in the plate? Quote Link to comment Share on other sites More sharing options...
christian bayon Posted May 6, 2021 Author Report Share Posted May 6, 2021 53 minutes ago, Jim Bress said: Wow, that's definitely something new. "I started my career as military aircraft engineer" That was a 20 year chapter in my life. Do the structure supports (for lack of a better name) allow you to make the plates thinner? Thanks for showing your work. -Jim The final weight of my plate is not very different of a normal violin, just a little bit lighter. It’s more a different repartition of the material, more where the tension are and less where there is no need. Quote Link to comment Share on other sites More sharing options...
christian bayon Posted May 6, 2021 Author Report Share Posted May 6, 2021 30 minutes ago, FiddleDoug said: Very different! Is the "bassbar" carbon fiber? And does it touch the cross support in the plate? Yes, carbon fibre tube set in 3 spruce pieces. the bass bar doesn’t touch the cross support Quote Link to comment Share on other sites More sharing options...
jacobsaunders Posted May 6, 2021 Report Share Posted May 6, 2021 What does “Political Correctness” (or not) have to do with pointless messing around? Quote Link to comment Share on other sites More sharing options...
christian bayon Posted May 6, 2021 Author Report Share Posted May 6, 2021 Pointless? Quote Link to comment Share on other sites More sharing options...
GeorgeH Posted May 6, 2021 Report Share Posted May 6, 2021 Wow, very interesting - thanks for posting. Do you have any sound samples? Does it still use a conventional sound post? Any deviations from a conventional back plate? Quote Link to comment Share on other sites More sharing options...
Andreas Preuss Posted May 6, 2021 Report Share Posted May 6, 2021 Pretty cool. What is the weight of the finished fiddle? I mean in terms of aircraft engineering it should be as light as possible. (Guess why I am asking.) Quote Link to comment Share on other sites More sharing options...
Deo Lawson Posted May 6, 2021 Report Share Posted May 6, 2021 That's so cool! I want to play one. My gut reaction was sorta that it was another "improved bass bar" and an overcomplication, but I'd be happy to be surprised. Quote Link to comment Share on other sites More sharing options...
CaseyLouque Posted May 6, 2021 Report Share Posted May 6, 2021 So is there a reason to carve it in that way instead of just gluing in bracing similar to archtop guitar bracing? Quote Link to comment Share on other sites More sharing options...
jacobsaunders Posted May 6, 2021 Report Share Posted May 6, 2021 1 hour ago, christian bayon said: Pointless? Ok, I re-phrase, I don't get the point Quote Link to comment Share on other sites More sharing options...
christian bayon Posted May 6, 2021 Author Report Share Posted May 6, 2021 3 minutes ago, jacobsaunders said: Ok, I re-phrase, I don't get the point You don’t necessarily need. Quote Link to comment Share on other sites More sharing options...
christian bayon Posted May 6, 2021 Author Report Share Posted May 6, 2021 34 minutes ago, CaseyLouque said: So is there a reason to carve it in that way instead of just gluing in bracing similar to archtop guitar bracing? Cross grain wood would act very differently. Quote Link to comment Share on other sites More sharing options...
jacobsaunders Posted May 6, 2021 Report Share Posted May 6, 2021 5 minutes ago, christian bayon said: You don’t necessarily need. Phew, glad about that Quote Link to comment Share on other sites More sharing options...
avandesande Posted May 6, 2021 Report Share Posted May 6, 2021 Deformation eliminator sounds good, ditto for wolf notes, but what does a 'sound killer' do? Quote Link to comment Share on other sites More sharing options...
Violadamore Posted May 6, 2021 Report Share Posted May 6, 2021 5 hours ago, christian bayon said: I started my career as military aircraft engineer There's a surprising number of us here on MN who did that as part of our careers. Probably evidence that luthiers are naturally flighty........ I really like your design, BTW. Dieter Ennemoser in Austria is doing something vaguely similar, but claims acoustic reasons for it. 1 hour ago, CaseyLouque said: So is there a reason to carve it in that way instead of just gluing in bracing similar to archtop guitar bracing? Stress elimination, increased strength, crack prevention, smooth transmission of forces, simplified work-flow, lack of joints to fail, same reasons that many advanced modern aircraft frames and skin panels are milled from solid metal, rather than formed or assembled from pieces. The support structures and curved surfaces are literally carved in to begin with. It's a technically elegant approach, but usually too expensive to use in civilian applications. Quote Link to comment Share on other sites More sharing options...
Urban Luthier Posted May 6, 2021 Report Share Posted May 6, 2021 Fascinating Christian thanks for sharing! What are your design and engineering objectives? Increased response from a loudness perspective (projection)? Enhancing certain frequencies i.e. around 1K? strength vs weight? Other? Quote Link to comment Share on other sites More sharing options...
Don Noon Posted May 6, 2021 Report Share Posted May 6, 2021 Having fooled around with bracing and such in the past, I remain skeptical. In my view, non-uniformities in plate stiffness tend to also result in more non-uniformities in the sound spectrum, usually not good. If done well, maybe they can be not-too-bad. Quote Link to comment Share on other sites More sharing options...
Violadamore Posted May 6, 2021 Report Share Posted May 6, 2021 15 minutes ago, Don Noon said: Having fooled around with bracing and such in the past, I remain skeptical. In my view, non-uniformities in plate stiffness tend to also result in more non-uniformities in the sound spectrum, usually not good. If done well, maybe they can be not-too-bad. Sometimes you gotta just build a prototype to see how it flies, and violins are much harder to model computationally than winged things. I'm interested in seeing how well it works practically. IIRC, you've done a lot of that yourself. @christian bayon, do you have any performance videos? Quote Link to comment Share on other sites More sharing options...
jacobsaunders Posted May 6, 2021 Report Share Posted May 6, 2021 4 minutes ago, Violadamore said: see how it flies, Makes a change from asking what it sounds like Quote Link to comment Share on other sites More sharing options...
