Original Sound of Stradivarius
GerardM
Do we know what an original Stradivarius sounded like? The messiah violin is that still in the same condition  as when Stradivarius finished it? We’re the instruments original graduations altered when the necks were reset. Just curious when I hear people talk about the sound of Stradivarius and if he came back would he recognises the sound of his violins. Thanks G
  • Replies 176
Probably similar to a baroque set up fine violin, given that it has proper time correct strings and a bow. The pitch may have been different. I do not know what the correct pitch would be in Cremona at that time. Could have been both higher or lower pitch than today.
Was the original neck the same weight?
1 hour ago, GerardM said:
[...]if he came back would he recognises the sound of his violins.
IMO, definitely not.
On a side note I was thinking why the transformation of the original baroque setup to modern setup was in most cases successful, and in a good percentage of his output absolutely exceptional for the sound.
Huh?
Howdya know that?
20 minutes ago, sospiri said:
1. Nobody living has ever played it?
2. Because it's got a soundpost crack?
Assuming that you are referring to the Messiah Strad, it is not in original condition, and the neck, while somewhat original,  has been highly modified and tweaked.
And yes, no one living has played it in its original condition, unless they are well past their 150th birthday.
Not particularly important, exept for a shorter string length, which does matter. The bridge and strings are important. The shorter and ligter fingerboard is probaly not important.
I know this bcause I have done a transition like that and measured each step from violin to a Hardangerfiddle. The neck is very different then more pegs and weight, but I doubt that anyone could hear the differences it made to the instrument response.
Ya don't shaaay.
If I was to make a Strad original style neck, what should I model it on? Are there plans that I could follow?
Scaled down Medici Tenor?
Okay...just pondering...
But when Strad made a violin, baroque style (shorter neck/different angle), with gut strings, played at ~415 Hz, ~360 years ago...
There's no way we could know what it sounded like. Right?
I am sure you can figure out this on your own. My replies are to the original question. What did the Strads sound like originally?
Maybe something from Sacconis book can be used?
They sounded better. More tone, less volume.
1 hour ago, sospiri said:
Dey shounded jush great when dey wash foysht made dontcha tink?
How would either you or I know, unless we have solid and reliable contact with the spiritual realm, or time travel?
Most of my income has come from time-travel back to Stradivari's time, selling toilet paper. It was a hot commodity back when people mostly used their hands, their sleeves, the hems of their skirts, or an erect middle finger. ;)
My best guess is: more quiet, maybe a little more annoying high frequency, assuming that the original bridge design has a higher in plane resonance. The lighter and shorter bassbar - I do not know. Grandpa and I have used short low bars for years. Maybe it makes the fiddle a little deeper sounding on the lows.
I do not know how the original strings looked, if they were overwound some of them or not. Certinly the plain gut E-string may sound and play different.
There are elements of this on the hardanger fiddle. E.g the shorter stringlength, gut strings on two or three strings. A flatter and slightly lower bridge. We tune them higher though than the standard pitch.
We can guess that they sounded a lot like a good baroque violin.
But the OP questions are a touch whacky.  Obviously we aren't time travelers, so can't actually experience how they sounded back then.  No, there weren't any records for us to hear.  No, centuries old violins aren't unaged or unchanged.  There is no violin today that we can assume sounds exactly as it did then.
Take a Strad or other and put in good baroque setup. That's the best estimate we can make.
But we can know that Strad violins were successful in his lifetime.  It didn't take huge amounts of aging for the youger Amati generations to compete with the older, nor for Strad to compete with the older Cremona instrument.
The "original condition" was when it was just made.  Aside from modifications, it is also now over 300 years old.  If you want to hear what they sounded like, have a good maker make an accurate copy with new wood.  Depending on the wood choice and skill of the maker, it might sound OK, but it won't sound like a 300 year old Strad (which can be better or worse, depending on the instrument and its state of health).
