Bill Merkel Posted December 10, 2022 Report Share Posted December 10, 2022 10 hours ago, Don Noon said: The idea is to still have it hand-carved, but with a smooth pattern to start with. I've seen scrolls by one or two people on here who let the machine do practically all of the work, and they are bad, worse than a human who'd read a book would do. Probably the CNC could be tuned up to do an artistic job, but they're satisfied with the result they have is the problem. It's a problem of poor artistic taste; bad cutting by computer replacing bad cutting by hand. Quote Link to comment Share on other sites More sharing options...
Andreas Preuss Posted December 10, 2022 Author Report Share Posted December 10, 2022 12 hours ago, Bill Merkel said: I've seen scrolls by one or two people on here who let the machine do practically all of the work, and they are bad, worse than a human who'd read a book would do. Probably the CNC could be tuned up to do an artistic job, but they're satisfied with the result they have is the problem. It's a problem of poor artistic taste; bad cutting by computer replacing bad cutting by hand. There are different approaches for using CNC. It is certainly not a good idea to let the machine do everything to the end. The best way using CNC is to get your neck block roughed out and finish everything by hand. I know some makers doing scrolls like this. Regardless, there is also a completely different approach possible where the design of the scroll is adopted to how the machine works. This is similar to modern design products and the result wouldn’t be anything like a classical scroll. Quote Link to comment Share on other sites More sharing options...
BarryD Posted February 17 Report Share Posted February 17 On 12/10/2022 at 5:04 PM, Andreas Preuss said: There are different approaches for using CNC. It is certainly not a good idea to let the machine do everything to the end. The best way using CNC is to get your neck block roughed out and finish everything by hand. I know some makers doing scrolls like this. Regardless, there is also a completely different approach possible where the design of the scroll is adopted to how the machine works. This is similar to modern design products and the result wouldn’t be anything like a classical scroll. I would like to have a name or two. This is what Im trying to do but am having trouble getting the CNC design and CAM working correctly. Quote Link to comment Share on other sites More sharing options...
Urban Luthier Posted February 17 Report Share Posted February 17 @Don Noondoes a very fine job of using CAM with traditional hand work as did our late colleague @Michael_Molnar. Telling machines to do what you want them to and actually getting them to do it right, is not easy. Quote Link to comment Share on other sites More sharing options...
