Adrian Lopez Posted November 25, 2020 Report Share Posted November 25, 2020 In Johnson & Courtnall's The Art of Violin Making the authors suggest that in order to test the fit of a new peg one should spin the peg in the peg box and touch the peg against one's lips to make sure both ends of the peg are equally warm where they touch the peg box. I tried this and found it difficult to detect any heat with my body, so I figured I'd use my infrared camera (FLIR ONE Pro) to gauge the temperature. You can see at first glance in the last two pictures that the peg does not have good contact with the left peg box wall, so I will need to shim the peg in the shaper or adjust the blade to better match the reamer's taper. I'm sure most of you have your own approaches to this and they work well for you, but I thought I'd share this just in case anybody finds it useful or interesting. The scroll and peg box before spinning the peg: The peg, scroll, and peg box after turning the peg a few times: The peg removed from the peg box, showing only one side getting warmer: Quote Link to comment Share on other sites More sharing options...
Andreas Preuss Posted November 25, 2020 Report Share Posted November 25, 2020 Looks like overkill to me. It I s possible to adjust pegs to hard or too soft and get the infrared camera result right. For smoothest turning the hole must be smooth (can't be measured with infrared) and I try to get a pinch more pressure on the side of the peg head. Quote Link to comment Share on other sites More sharing options...
Nick Allen Posted November 25, 2020 Report Share Posted November 25, 2020 I'm in agreement with Andreas. It's super easy to tell where it's touching simply by looking at where the peg is burnishing and getting shiny. You can assess the pegbox the same way. Quote Link to comment Share on other sites More sharing options...
Adrian Lopez Posted November 25, 2020 Author Report Share Posted November 25, 2020 8 hours ago, Andreas Preuss said: Looks like overkill to me. It I s possible to adjust pegs to hard or too soft and get the infrared camera result right. For smoothest turning the hole must be smooth (can't be measured with infrared) and I try to get a pinch more pressure on the side of the peg head. This is only meant to substitute for the specific trick described in Johnson & Courtnall where you touch the peg to your lips. If you don't do that or you don't need anything more precise then of course there would be no point to the IR camera. Luthiers have managed to do without infrared cameras literally for centuries so it's not like this is really necessary, but I find it an interesting visualization and a possible aid. It's not intended to be the sole method by which the fit of the pegs is judged. Quote Link to comment Share on other sites More sharing options...
Adrian Lopez Posted November 25, 2020 Author Report Share Posted November 25, 2020 16 minutes ago, Nick Allen said: It's super easy to tell where it's touching simply by looking at where the peg is burnishing and getting shiny. J&C recommend that too. Quote Link to comment Share on other sites More sharing options...
Marty Kasprzyk Posted November 25, 2020 Report Share Posted November 25, 2020 12 hours ago, Adrian Lopez said: In Johnson & Courtnall's The Art of Violin Making the authors suggest that in order to test the fit of a new peg one should spin the peg in the peg box and touch the peg against one's lips to make sure both ends of the peg are equally warm where they touch the peg box. I tried this and found it difficult to detect any heat with my body, so I figured I'd use my infrared camera (FLIR ONE Pro) to gauge the temperature. You can see at first glance in the last two pictures that the peg does not have good contact with the left peg box wall, so I will need to shim the peg in the shaper or adjust the blade to better match the reamer's taper. I'm sure most of you have your own approaches to this and they work well for you, but I thought I'd share this just in case anybody finds it useful or interesting. The scroll and peg box before spinning the peg: The peg, scroll, and peg box after turning the peg a few times: The peg removed from the peg box, showing only one side getting warmer: Looks great! If you play the instrument for a while does it show if any areas warm up? This might be another way of doing modal analysis. Quote Link to comment Share on other sites More sharing options...
FiddleDoug Posted November 25, 2020 Report Share Posted November 25, 2020 5 minutes ago, Marty Kasprzyk said: Looks great! If you play the instrument for a while does it show if any areas warm up? This might be another way of doing modal analysis. Exactly how hard do you play your instrument to make them heat up? Quote Link to comment Share on other sites More sharing options...
Adrian Lopez Posted November 25, 2020 Author Report Share Posted November 25, 2020 16 minutes ago, Marty Kasprzyk said: If you play the instrument for a while does it show if any areas warm up? This might be another way of doing modal analysis. I haven't tried it, but I doubt the camera is quite that sensitive. Quote Link to comment Share on other sites More sharing options...
Guglielmus Carinius Posted November 25, 2020 Report Share Posted November 25, 2020 12 minutes ago, FiddleDoug said: Exactly how hard do you play your instrument to make them heat up? Quote Link to comment Share on other sites More sharing options...
MANFIO Posted November 25, 2020 Report Share Posted November 25, 2020 Oh, I am afraid I will not be able to fit pegs again.... Quote Link to comment Share on other sites More sharing options...
Adrian Lopez Posted November 25, 2020 Author Report Share Posted November 25, 2020 28 minutes ago, MANFIO said: Oh, I am afraid I will not be able to fit pegs again.... Why's that? Quote Link to comment Share on other sites More sharing options...
Marty Kasprzyk Posted November 25, 2020 Report Share Posted November 25, 2020 2 hours ago, Adrian Lopez said: I haven't tried it, but I doubt the camera is quite that sensitive. I've seen a thermal image of a guitar being played but I never seen one done on a violin. Damping causes heat generation so it might be interesting to see where it occurs. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted November 25, 2020 Report Share Posted November 25, 2020 17 hours ago, Andreas Preuss said: Looks like overkill to me. I think the infrared images are kinda cool. Not everyone learns in the same way, or processes information in the same way. I'm some sort of weird mish-mash between a traditionalist, and a techo-nerd. Think I've benefited from both, slightly more than I've been harmed by either. Quote Link to comment Share on other sites More sharing options...
Andreas Preuss Posted November 26, 2020 Report Share Posted November 26, 2020 10 hours ago, Adrian Lopez said: This is only meant to substitute for the specific trick described in Johnson & Courtnall where you touch the peg to your lips. If you don't do that or you don't need anything more precise then of course there would be no point to the IR camera. Luthiers have managed to do without infrared cameras literally for centuries so it's not like this is really necessary, but I find it an interesting visualization and a possible aid. It's not intended to be the sole method by which the fit of the pegs is judged. Agree. I am just making this point because some violin making novices might get the wrong idea about fitting pegs properly from the beginning. Quote Link to comment Share on other sites More sharing options...
duane88 Posted November 26, 2020 Report Share Posted November 26, 2020 Subject your post patches and chest patches to a CT scan. That might be enlightening. Quote Link to comment Share on other sites More sharing options...
