W.C. Posted November 21, 2020 Report Share Posted November 21, 2020 Recently when researching into different styles of violin corners, I have noticed a very typical wear pattern on many old violin corners, as shown in this picture: One can observe that the very tip of the corner is worn-off, and even making the purfling "curve" inwards toward the ribs. In some cases, if view from the side, would be something like this following picture, where the tip, or the "beesting" of the purfling joint can be seen looking from the side view (sorry for the quality of the photos, as I do not own any violins with such worn corners. These are sourced from the internet). It is actually quite hard to phrase my question... I am wondering, if any of these "curved purfling" traits (where the purfling extend all the way to the end of the corner to an extent that it is almost visible from the side) comes from a particular style of making? German? Or they are mostly likely just wear, and wouldn't be like this when they were new? Or an alternative question, do certain corner designs tend to wear off faster than the others (German vs Italian for example)? CLARIFICATION: I know for sure that the corner in the first of this post is worn-off, but I am just referring to similar pattern in all my questions. Do not limit your answers to my photos And on top of that, how well does "careful preservation" protect against corner wear? i.e. I have seen strads that have almost new corners (extreme example, Lady Blunt, or the Messiah if you would), but also some with very worn-off corners (i.e. Titan). Do they wear off that dramatically without proper care? Because of the old cases? Waiting to be educated! Thank you very much! Quote Link to post Share on other sites
jacobsaunders Posted November 21, 2020 Report Share Posted November 21, 2020 I think that the concept of “corners wearing” is overestimated. When playing a violin, putting it in it’s case, etc. I see no necessary process of gradual abrasion, rather some corners get smashed off with the bow ferrule or similar and others wouldn’t. Therefore one should ask oneself to what extent the corners (particularly when all 8 are the same) were originally made like that or not. Not every violin started life with sharp Messie style corners. Many were nice comfortably rounded off friendly looking ones Quote Link to post Share on other sites
W.C. Posted November 21, 2020 Author Report Share Posted November 21, 2020 4 minutes ago, jacobsaunders said: Not every violin started life with sharp Messie style corners. Many were nice comfortably rounded off friendly looking ones Thanks Jacob! This is exactly what I am looking for! Can we make any connections between this "rounded corner" design to any particular region, school, or even time period? Thanks! Quote Link to post Share on other sites
jacobsaunders Posted November 21, 2020 Report Share Posted November 21, 2020 I think you will find, that there isn’t one “rounded corner design”, but hundreds. Some corners are distinctive, for instance those I call “dead pig’s noses” which one can see for instance on some Leidolff instruments, which help instrument recognition, but one would have to write a book on the subject, and they are well nigh impossible to describe in words. Quote Link to post Share on other sites
David Burgess Posted November 21, 2020 Report Share Posted November 21, 2020 6 hours ago, W.C. said: Recently when researching into different styles of violin corners, I have noticed a very typical wear pattern on many old violin corners, as shown in this picture: One can observe that the very tip of the corner is worn-off, and even making the purfling "curve" inwards toward the ribs. In some cases, if view from the side, would be something like this following picture, where the tip, or the "beesting" of the purfling joint can be seen looking from the side view. I think that much of this sort of wear is an artifact of the violin rocking around in old-style poorly padded cases, back when roads were far from smooth. Or imitation of such wear. Quote Link to post Share on other sites
Andreas Preuss Posted November 21, 2020 Report Share Posted November 21, 2020 Instruments with a low bridge or a bridge tilted too much towards the treble side are more likely to get a worn upper treble side corners because it is getting 'bowed over'. (Or worse hit by the frog.) In some modern compositions there is a rapid change between bowed string and pizzicato (holding the bow) which seems to be a risky business for the upper treble side corner of a violin or viola. Speaking of very old instruments there might be a sort of erosion going on by rubbing corners over the cloth of the player when holding the instrument and other occasional contacts. At least I don't see any better explanation for worn corners on the back. Quote Link to post Share on other sites
Bodacious Cowboy Posted November 21, 2020 Report Share Posted November 21, 2020 20 minutes ago, jacobsaunders said: I think you will find, that there isn’t one “rounded corner design”, but hundreds. Some corners are distinctive, for instance those I call “dead pig’s noses” which one can see for instance on some Leidolff instruments, which help instrument recognition, but one would have to write a book on the subject, and they are well nigh impossible to describe in words. Ian Dury fan? Quote Link to post Share on other sites
W.C. Posted November 21, 2020 Author Report Share Posted November 21, 2020 34 minutes ago, jacobsaunders said: I think you will find, that there isn’t one “rounded corner design”, but hundreds Yes I think I can relate that. In my impression I do remember seeing more German violins with more rounded corners than the others? I may be wrong. 17 minutes ago, David Burgess said: I think that much of this sort of wear is an artifact of the violin rocking around in old-style poorly padded cases, back when roads were far from smooth 15 minutes ago, Andreas Preuss said: Speaking of very old instruments there might be a sort of erosion going on by rubbing corners over the cloth of the player when holding the instrument and other occasional contacts I think these two lines from David and Andreas are what I was looking for. Thanks! I think can assume those with well-preserved corners were either kept in better designed cases, or hardly travelled? Also, is "Rounding the corners" a typical thing makers would do when antiquing? (I don't infer to the process of making bench copies, where the maker usually just copy the traits of the original, but rather just a normal antiquing process) 15 minutes ago, Andreas Preuss said: Instruments with a low bridge or a bridge tilted too much towards the treble side are more likely to get a worn upper treble side corners because it is getting 'bowed over'. (Or worse hit by the frog.) In some modern compositions there is a rapid change between bowed string and pizzicato (holding the bow) which seems to be a risky business for the upper treble side corner of a violin or viola This is definitely a killer factor! I've seen those "C bout protection covers" on Amazon and find them sometimes useful during practice. Quote Link to post Share on other sites
jacobsaunders Posted November 21, 2020 Report Share Posted November 21, 2020 23 minutes ago, David Burgess said: I think that much of this sort of wear is an artifact of the violin rocking around in old-style poorly padded cases, back when roads were far from smooth. Or imitation of such wear. Should one distinguish between “wear” and straightforward “damage” I find that unlightly, particularly when all 8 corners are "worn" the same Quote Link to post Share on other sites
jacobsaunders Posted November 21, 2020 Report Share Posted November 21, 2020 18 minutes ago, Bodacious Cowboy said: Ian Dury fan? Quote Link to post Share on other sites
David Burgess Posted November 21, 2020 Report Share Posted November 21, 2020 1 minute ago, jacobsaunders said: Should one distinguish between “wear” and straightforward “damage” I find that unlightly, particularly when all 8 corners are worn the same Not all emulation of wear is of stellar quality. Quote Link to post Share on other sites
jacobsaunders Posted November 21, 2020 Report Share Posted November 21, 2020 1 minute ago, David Burgess said: Not all emulation of wear is of stellar quality. what is always of stellar quality? Quote Link to post Share on other sites
David Burgess Posted November 21, 2020 Report Share Posted November 21, 2020 12 minutes ago, jacobsaunders said: what is always of stellar quality? Mud bogging. Quote Link to post Share on other sites
Brad Dorsey Posted November 21, 2020 Report Share Posted November 21, 2020 24 minutes ago, jacobsaunders said: what is always of stellar quality? Stars. Quote Link to post Share on other sites
jacobsaunders Posted November 21, 2020 Report Share Posted November 21, 2020 To resurrect a serious discussion about violin corners; I post pictures of the 8 corners on an 1815 Widhalm violin as an example. Of course there is some (little) “wear”. All 8 corners are however eminently similar, and I would contend originally conceived so by Mr. Widhalm himself. I always used to have arguments with my father about this, since he had the lower and upper bouts outline and the centre bout outline just finish, and that was the corner. I find, a drawback with much “new making”, whereas the Widhalm corners almost look as if they grew like that, and have a character and charm of there own Quote Link to post Share on other sites
GeorgeH Posted November 21, 2020 Report Share Posted November 21, 2020 I was told by an expert that the French sharply squared their corners because they were essentially the first Europeans outside of Italy to study unworn Cremonese instruments, and they were trying to copy these instruments. As the sharp square corners of these instruments became worn and smooth over time, later makers copying them rounded their corners. Quote Link to post Share on other sites
jacobsaunders Posted November 21, 2020 Report Share Posted November 21, 2020 4 minutes ago, GeorgeH said: I was told by an expert that the French sharply squared their corners because they were essentially the first Europeans outside of Italy to study unworn Cremonese instruments, and they were trying to copy these instruments. As the sharp square corners of these instruments became worn and smooth over time, later makers copying them rounded their corners. sounds like BS to me Quote Link to post Share on other sites
David Burgess Posted November 21, 2020 Report Share Posted November 21, 2020 1 hour ago, jacobsaunders said: To resurrect a serious discussion about violin corners; I post pictures of the 8 corners on an 1815 Widhalm violin as an example. Of course there is some (little) “wear”. All 8 corners are however eminently similar, and I would contend originally conceived so by Mr. Widhalm himself. By the time Wihalm came around, there would have been many many worn violins to stylistically emulate in an imprecise sort of way. 1 hour ago, GeorgeH said: I was told by an expert that the French sharply squared their corners because they were essentially the first Europeans outside of Italy to study unworn Cremonese instruments, and they were trying to copy these instruments. As the sharp square corners of these instruments became worn and smooth over time, later makers copying them rounded their corners. Sounds quite plausible to me. Quote Link to post Share on other sites
jacobsaunders Posted November 21, 2020 Report Share Posted November 21, 2020 1 hour ago, jacobsaunders said: 33 minutes ago, David Burgess said: By the time Wihalm came around, there would have been many many worn violins to stylistically emulate in an imprecise sort of way. One can see (on the Widhalm example), since all 8 corners are of the same character, that they were created so, and they are not the result of 200 years of “wear”. If they were all the result of “wear” they would all be different. Otherwise it is tantamount to believing you can get two separate accidental dents in your car, exactly symmetrically, one on each side. One is tempted to ask if you believe in fairies. I think one should bear in mind that the Cremonese violins with the ugly sharp square corners are the exception rather than the rule. Quote Link to post Share on other sites
David Burgess Posted November 21, 2020 Report Share Posted November 21, 2020 20 minutes ago, jacobsaunders said: One can see (on the Widhalm example), since all 8 corners are of the same character, that they were created so, and they are not the result of 200 years of “wear”. If they were all the result of “wear” they would all be different. Right. That's why I chose the wording, "stylistically emulate (wear) in an imprecise sort of way". Quote Link to post Share on other sites
jacobsaunders Posted November 21, 2020 Report Share Posted November 21, 2020 17 minutes ago, David Burgess said: Right. That's why I chose the wording, "stylistically emulate (wear) in an imprecise sort of way". More important; do you believe in fairies or not? Quote Link to post Share on other sites
David Burgess Posted November 21, 2020 Report Share Posted November 21, 2020 1 hour ago, jacobsaunders said: More important; do you believe in fairies or not? Which type (or flavor) of fairy? Do the Heinzelmännchen fall into the fairy category? Quote Link to post Share on other sites
MarkBouquet Posted November 21, 2020 Report Share Posted November 21, 2020 3 hours ago, David Burgess said: Mud bogging. They’re not wearing masks! Quote Link to post Share on other sites
David Burgess Posted November 21, 2020 Report Share Posted November 21, 2020 I get it. You want them girls to move their shirts up to cover their faces, for medical reasons. Quote Link to post Share on other sites
duane88 Posted November 21, 2020 Report Share Posted November 21, 2020 59 minutes ago, MarkBouquet said: They’re not wearing masks! Sadly, that is the first thing I thought, too. Quote Link to post Share on other sites
