Craig Cowing Posted November 2, 2020 Report Share Posted November 2, 2020 I have a cello that I think is American made ca. 18O0 and would like to get a dendro test done. Quote Link to post Share on other sites
FiddleDoug Posted November 2, 2020 Report Share Posted November 2, 2020 Probably not. You have to remember the dendrochronology is based of the growth of tree rings, and that growth is based on climate. I think that virtually all of the wood in Europe probably comes from an area less than 300 miles in diameter. That's about the size of New York State. Wood (spruce) in the US could probable come from anywhere from the mountains of the Carolinas to Maine, and then there's always the vast range of wood from the Rockies and other western mountains. There can be a lot of climate variation over those areas. Quote Link to post Share on other sites
BassClef Posted November 3, 2020 Report Share Posted November 3, 2020 https://www.oakislandcompendium.ca/blockhouse-blog/u-shaped-structure-dendrochronology-update Quote Link to post Share on other sites
Bruce Carlson Posted November 3, 2020 Report Share Posted November 3, 2020 On 11/2/2020 at 4:50 AM, Craig Cowing said: I have a cello that I think is American made ca. 18O0 and would like to get a dendro test done. Dendrochronology started in the States back in the early 1900's with the dating of ancient Indian and Incan ruins. Douglass was also an astronomer!! https://en.wikipedia.org/wiki/A._E._Douglass A number of north american master chronologies are available on the internet through the International Tree Ring Databank ITRDB run by the U.S. government https://www.ncdc.noaa.gov/data-access/paleoclimatology-data/datasets/tree-ring In addition look on Prof. Henri D. Grissino-Mayer's website for more information. https://www.ltrr.arizona.edu/~grissino/treering.htm Grissino Mayer can probably point you in the right direction or surely Peter Ratcliff who contributes to MaestroNet. Quote Link to post Share on other sites
Brad Dorsey Posted November 4, 2020 Report Share Posted November 4, 2020 Certainly people are doing dendrochronology research on American wood. Archeologists use the resulting information to date Indian sites. The real question is if the research can be of any use in dating American-made instruments. Unless you know where your wood was grown, I doubt that it can, because, as Doug notes, different areas require different reference chronologies. Quote Link to post Share on other sites
Bruce Carlson Posted November 4, 2020 Report Share Posted November 4, 2020 7 hours ago, Brad Dorsey said: Certainly people are doing dendrochronology research on American wood. Archeologists use the resulting information to date Indian sites. The real question is if the research can be of any use in dating American-made instruments. Unless you know where your wood was grown, I doubt that it can, because, as Doug notes, different areas require different reference chronologies. If you run through all the American chronologies and you get a significant date on your wood. It could suggest where it was cut. The dating of indian dwellings was in the first part of the last century and since then master chronologies for spruce and other similarly growing conifers have been compiled for areas all over the US and Canada. https://www.ncdc.noaa.gov/paleo-search/?dataTypeId=18 Obviously a lot of wood was imported from Europe so you may end up with a European date but in circa 1800 it may well be local wood. Personally I don't know of anyone who is compiling measurements for instruments made in north or south america. It would be great if someone could measure all the instruments in David Bromberg's collection. That would be a good start. Prof. Henri D. Grissino-Mayer was one of the scientists involved in the definitive dating of the 'Messiah'. Quote Link to post Share on other sites
Ratcliffiddles Posted November 4, 2020 Report Share Posted November 4, 2020 I'll have a go as soon as I receive suitable images...Some American instruments I have tested were definitely made with European wood, and I will run it against the US references I have. Quote Link to post Share on other sites
Craig Cowing Posted November 6, 2020 Author Report Share Posted November 6, 2020 On 11/4/2020 at 4:12 AM, Ratcliffiddles said: I'll have a go as soon as I receive suitable images...Some American instruments I have tested were definitely made with European wood, and I will run it against the US references I have. I'll send pics tomorrow! Quote Link to post Share on other sites
Craig Cowing Posted November 6, 2020 Author Report Share Posted November 6, 2020 On 11/3/2020 at 8:40 PM, Brad Dorsey said: Certainly people are doing dendrochronology research on American wood. Archeologists use the resulting information to date Indian sites. The real question is if the research can be of any use in dating American-made instruments. Unless you know where your wood was grown, I doubt that it can, because, as Doug notes, different areas require different reference chronologies. The back is definitely American Sycamore. The table could be either spruce or pine. The cello comes from the Moravian area outside Philadelphia so I would expect that it is made from wood from that region. Quote Link to post Share on other sites
David Burgess Posted November 6, 2020 Report Share Posted November 6, 2020 17 minutes ago, Craig Cowing said: The back is definitely American Sycamore. How have you determined that? Quote Link to post Share on other sites
Craig Cowing Posted November 6, 2020 Author Report Share Posted November 6, 2020 1 hour ago, David Burgess said: How have you determined that? It’s possible it is European or American beech also but is comparable to images of quarter sawn American sycamore which has distinctive figuring. I am also planning to take it to the hardwood dealer I go to to have them identify it. the thing that makes me think it’s American is the presence of a label from a Philadelphia music store that dates from the period 1829-37. I know others know more about this than I do but it seems unlikely anyone was importing cellos from. Europe at that time. They were too large and there were already luthiers making them in Eastern Pennsylvania. Quote Link to post Share on other sites
Craig Cowing Posted November 6, 2020 Author Report Share Posted November 6, 2020 I went to the hardwood dealer where I get much of my wood and showed the cello to one of the staff who is quite knowledgeable about woods. He is sure it is American Sycamore. I'll post pics tomorrow when I can take some good pics outside. Quote Link to post Share on other sites
David Burgess Posted November 6, 2020 Report Share Posted November 6, 2020 19 hours ago, Craig Cowing said: ...but it seems unlikely anyone was importing cellos from Europe at that time. They were too large and there were already luthiers making them in Eastern Pennsylvania. Many American makers have used imported wood, as do I. As far as shipping is concerned, the wood takes up much less space than a completed cello, and is not nearly as fragile. Quote Link to post Share on other sites
Craig Cowing Posted November 6, 2020 Author Report Share Posted November 6, 2020 29 minutes ago, David Burgess said: Many American makers have used imported wood, as do I. As far as shipping is concerned, the wood takes up much less space than a completed cello, and is not nearly as fragile. Sure, that happened all the time, in the past as now, just as 18th century American furniture makers used mahogany for some of their high end pieces because that's what the customer wanted. And, in your case, you use imported wood because you feel it is the best and it's what your customers want. Since this is identified as American Sycamore that takes imported wood out of the equation. Quote Link to post Share on other sites
David Burgess Posted November 6, 2020 Report Share Posted November 6, 2020 47 minutes ago, Craig Cowing said: Since this is identified as American Sycamore that takes imported wood out of the equation. Maybe, maybe not. What are the credentials of this wood dealer? Are all wood dealers equally qualified? Quote Link to post Share on other sites
Jerry Lynn Posted November 7, 2020 Report Share Posted November 7, 2020 On 11/5/2020 at 9:57 PM, Craig Cowing said: the thing that makes me think it’s American is the presence of a label from a Philadelphia music store that dates from the period 1829-37. I know others know more about this than I do but it seems unlikely anyone was importing cellos from. Europe at that time. They were too large and there were already luthiers making them in Eastern Pennsylvania. Celli from that time period made in the states are exceedingly rare, most were imported. I would start by just seeking out some general expertise... maybe even posting pictures here. If warranted, there are a few people in and around Philadelphia, and else where in PA whom are well acquainted with instruments made by people associated with the Moravian church. Quote Link to post Share on other sites
Craig Cowing Posted November 7, 2020 Author Report Share Posted November 7, 2020 14 hours ago, David Burgess said: Maybe, maybe not. What are the credentials of this wood dealer? Are all wood dealers equally qualified? I would imagine that not all wood dealers are not qualified. In this case, this is a highly professional company. They do high end interior work for clients around the Northeast. They are extremely qualified to make a call. They know their wood. Quote Link to post Share on other sites
Craig Cowing Posted November 7, 2020 Author Report Share Posted November 7, 2020 9 hours ago, Jerry Lynn said: Celli from that time period made in the states are exceedingly rare, most were imported. I would start by just seeking out some general expertise... maybe even posting pictures here. If warranted, there are a few people in and around Philadelphia, and else where in PA whom are well acquainted with instruments made by people associated with the Moravian church. I'm going to post pics soon. My problem is money. I know that appraisals are expensive, and right now, with COVID rising again, income is tenuous. I have been able to compare the body shape with pics of some Moravian instruments in Pennsylvania collections and there is a lot of similarity. Quote Link to post Share on other sites
Jerry Lynn Posted November 7, 2020 Report Share Posted November 7, 2020 56 minutes ago, Craig Cowing said: I'm going to post pics soon. My problem is money. I know that appraisals are expensive, and right now, with COVID rising again, income is tenuous. I have been able to compare the body shape with pics of some Moravian instruments in Pennsylvania collections and there is a lot of similarity. Instruments in the Moravian archive in Bethlehem and elsewhere look very much like their European counterparts... Where are you located? Quote Link to post Share on other sites
Craig Cowing Posted November 7, 2020 Author Report Share Posted November 7, 2020 48 minutes ago, Jerry Lynn said: Instruments in the Moravian archive in Bethlehem and elsewhere look very much like their European counterparts... Where are you located? Sure. The luthiers learned their trade at home and came here so they made instruments that looked like Bohemian/Saxon instruments. The difference, if it exists at all, would be in the materials used. This cello looks Bohemian but is made with American wood. I'm in CT and BC I would take a couple of days off, pack the cello up and drive a few hours to that part of PA and do the tour. Obviously that ain’t going to happen any time soon unfortunately. pics later today when I can devote some time to it. Quote Link to post Share on other sites
Craig Cowing Posted November 7, 2020 Author Report Share Posted November 7, 2020 Here are pics. Some didn’t upload for some reason so I’ll have to resize them on the computer. Quote Link to post Share on other sites
Wood Butcher Posted November 7, 2020 Report Share Posted November 7, 2020 The back, ribs and scroll look very much like beech. Quote Link to post Share on other sites
jacobsaunders Posted November 7, 2020 Report Share Posted November 7, 2020 If someone walked into my shop with that, I would speculate that it came from somewhere like Ischl or Goisern Quote Link to post Share on other sites
Craig Cowing Posted November 7, 2020 Author Report Share Posted November 7, 2020 15 minutes ago, jacobsaunders said: If someone walked into my shop with that, I would speculate that it came from somewhere like Ischl or Goisern Bohemian? I honestly don’t know. I don’t have to have it an American instrument. If it was made in Bohemia and brought over in the 1830’s which I can document, that’s good too. To be honest I’m more interested in its age. How old do you think it is? More pics soon. I’m wondering about the lack of purfling in particular. Is that a marker at all? Quote Link to post Share on other sites
jacobsaunders Posted November 7, 2020 Report Share Posted November 7, 2020 24 minutes ago, Craig Cowing said: Bohemian? I honestly don’t know. I don’t have to have it an American instrument. If it was made in Bohemia and brought over in the 1830’s which I can document, that’s good too. To be honest I’m more interested in its age. How old do you think it is? More pics soon. I’m wondering about the lack of purfling in particular. Is that a marker at all? Ischl and Goisern are in the Salzkammergut, between Salzburg and Linz in Austria. Not Bohemia. The use of beech would also be consistent with cheaper work from there, as is the lack of purfling. If so, I would guess the age as early 19th C. Quote Link to post Share on other sites
