David Burgess Posted December 5, 2020 Report Share Posted December 5, 2020 3 hours ago, Mark Norfleet said: Which is no doubt enhanced by the factor by which that friend's sense of humor is warped. Tee hee. Quote Link to comment Share on other sites More sharing options...
Moroni Larson Posted December 6, 2020 Report Share Posted December 6, 2020 Quote Link to comment Share on other sites More sharing options...
Mat Roop Posted December 11, 2020 Report Share Posted December 11, 2020 So here is a simple one that works pretty good... latex tubing in the end of a standard syringe... fill with hot glue press down gently to seal around the edges and with the plunger force glue into cracks. Had occasion to use it again this morning ... worked like a charm and thought I would share... Cheers, Mat Quote Link to comment Share on other sites More sharing options...
Andreas Preuss Posted December 12, 2020 Author Report Share Posted December 12, 2020 12 hours ago, Mat Roop said: So here is a simple one that works pretty good... latex tubing in the end of a standard syringe... fill with hot glue press down gently to seal around the edges and with the plunger force glue into cracks. Had occasion to use it again this morning ... worked like a charm and thought I would share... Cheers, Mat If I understand this correctly, with the rubber plug the amount of glue being pressed out can be controled better? I suppose you heat the glue in the syringe directly in the water bath. Quote Link to comment Share on other sites More sharing options...
catnip Posted December 12, 2020 Report Share Posted December 12, 2020 16 hours ago, Mat Roop said: fill with hot glue press down gently to seal around the edges Are you glue sizing the edges so that it becomes harder so that you can scrape the channel without tear out? If so why not a brush? Not sure what you mean by sealing the edges" Quote Link to comment Share on other sites More sharing options...
Wood Butcher Posted December 12, 2020 Report Share Posted December 12, 2020 25 minutes ago, catnip said: Are you glue sizing the edges so that it becomes harder so that you can scrape the channel without tear out? If so why not a brush? Not sure what you mean by sealing the edges" He's using it to force glue into fine cracks, not for purfling like you seem to be thinking. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted December 12, 2020 Report Share Posted December 12, 2020 5 hours ago, Andreas Preuss said: If I understand this correctly, with the rubber plug the amount of glue being pressed out can be controled better? The rubber tubing at the end creates a seal when pressed against the wooden part, allowing the syringe to apply high hydraulic pressure to the crack. I do something similar, but mine uses an O ring at the end. It's described and pictured in The Strad article I wrote about ten years ago. It's a little tricky to use though, because the rubber wants to slide around on the glue, so best to practice on some scrap first. Quote Link to comment Share on other sites More sharing options...
Mark Norfleet Posted December 12, 2020 Report Share Posted December 12, 2020 I’ve done a similar thing using vacuum on a cracked free plate that I couldn’t flex much. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted December 12, 2020 Report Share Posted December 12, 2020 36 minutes ago, Mark Norfleet said: I’ve done a similar thing using vacuum on a cracked free plate that I couldn’t flex much. Neat. What did you use to gasket between the fiddle and the vacuum tube? Quote Link to comment Share on other sites More sharing options...
Mark Norfleet Posted December 12, 2020 Report Share Posted December 12, 2020 17 minutes ago, David Burgess said: Neat. What did you use to gasket between the fiddle and the vacuum tube? I have what looks like a flat, fairly firm suction cup that has a hole in the back to connect to the tubing. It came with a complete Mityvac hand vac set I found on the road near Shar years ago. I use a vacuum pump with a bleed valve while doing such things though. Come to think of it, I've also used that technique while regluing the center section of back center joints without opening the instruments. I also reinforced the joints with linen. I can think of two violas I've done that on 20+ years ago that are played hard and doing fine. The not very open center joints were causing enough discontinuity of plate vibration that the sound suffered significantly. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted December 12, 2020 Report Share Posted December 12, 2020 38 minutes ago, Mark Norfleet said: I have what looks like a flat, fairly firm suction cup that has a hole in the back to connect to the tubing. It came with a complete Mityvac hand vac set I found on the road near Shar years ago. I use a vacuum pump with a bleed valve while doing such things though. Come to think of it, I've also used that technique while regluing the center section of back center joints without opening the instruments. How did you do that? Where did the vacuum cup go and where was the glue applied (and how)? Quote Link to comment Share on other sites More sharing options...
Don Noon Posted December 12, 2020 Report Share Posted December 12, 2020 A low-tech method I have used for getting glue into cracks: put a bead of glue over the crack, cover it with tape, and squish it in with fingers. The tape has to be bigger than the glue bead (to seal at the edges), and the tape can't be too sticky as to lift off varnish when removed. Probaby too risky for a high-value instrument. Quote Link to comment Share on other sites More sharing options...
Mat Roop Posted December 12, 2020 Report Share Posted December 12, 2020 4 hours ago, David Burgess said: The rubber tubing at the end creates a seal when pressed against the wooden part, allowing the syringe to apply high hydraulic pressure to the crack. I do something similar, but mine uses an O ring at the end. It's described and pictured in The Strad article I wrote about ten years ago. It's a little tricky to use though, because the rubber wants to slide around on the glue, so best to practice on some scrap first. Thanks David... you explain better than I! If you know which issue of the Strad your article is in... I'd love to read it (I have a bunch of old issues). 2 hours ago, Mark Norfleet said: I have what looks like a flat, fairly firm suction cup that has a hole in the back to connect to the tubing. It came with a complete Mityvac hand vac set I found on the road near Shar years ago. I use a vacuum pump with a bleed valve while doing such things though. Come to think of it, I've also used that technique while regluing the center section of back center joints without opening the instruments. I also reinforced the joints with linen. I can think of two violas I've done that on 20+ years ago that are played hard and doing fine. The not very open center joints were causing enough discontinuity of plate vibration that the sound suffered significantly. I have, for a long time, thought about the concept that is used to fill stone chips in windshields... easy enough to use on an opened violin, but how to use it on an assembled instrument? Guess I'm not inventive enough. Quote Link to comment Share on other sites More sharing options...
Mat Roop Posted December 12, 2020 Report Share Posted December 12, 2020 9 hours ago, Andreas Preuss said: If I understand this correctly, with the rubber plug the amount of glue being pressed out can be controled better? I suppose you heat the glue in the syringe directly in the water bath. Yes... the glue is contained mostly within the rubber tubing area and it slides easily along the crack... but it is a careful balance between downward pressure of the tubing the end of the syringe against the violin finish and the pressure of forcing glue out of the syringe. I heat the syringe with the hot water from the bath, then draw in the glue and apply to the preheated crack. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted December 12, 2020 Report Share Posted December 12, 2020 3 hours ago, Mat Roop said: Thanks David... you explain better than I! If you know which issue of the Strad your article is in... I'd love to read it (I have a bunch of old issues). February 2005. I think it's been long enough that I can post a PDF version of it, although the photos in the PDF version aren't of very high quality. http://www.burgessviolins.com/Strad glue article.pdf Quote Link to comment Share on other sites More sharing options...
Woodland Posted December 12, 2020 Report Share Posted December 12, 2020 I made this hand-cranked disc sander this fall out of 1/2” Baltic birch plywood. It’s no Alberti design, but it didn’t cost $900 either, more like $20 in materials. Still tweaking it. Quote Link to comment Share on other sites More sharing options...
Jim Bress Posted December 13, 2020 Report Share Posted December 13, 2020 2 hours ago, Woodland said: I made this hand-cranked disc sander this fall out of 1/2” Baltic birch plywood. It’s no Alberti design, but it didn’t cost $900 either, more like $20 in materials. Still tweaking it. That’s pretty cool! Quote Link to comment Share on other sites More sharing options...
David Burgess Posted December 13, 2020 Report Share Posted December 13, 2020 10 hours ago, Woodland said: I made this hand-cranked disc sander this fall out of 1/2” Baltic birch plywood. It’s no Alberti design, but it didn’t cost $900 either, more like $20 in materials. Still tweaking it. Nice. What is the purpose of the second wheel on the crank side? Quote Link to comment Share on other sites More sharing options...
Andreas Preuss Posted December 13, 2020 Author Report Share Posted December 13, 2020 13 hours ago, Woodland said: I made this hand-cranked disc sander this fall out of 1/2” Baltic birch plywood. It’s no Alberti design, but it didn’t cost $900 either, more like $20 in materials. Still tweaking it. There we go, another cool idea. Btw adding weight (ideally a ribbon of lead around it) to the wheel would give it a bit more punch once you have accelerated it. One might also think about adding a gear to get a higher speed. This one risks to land on my tool wish list for self made tools. Thanks for posting! Quote Link to comment Share on other sites More sharing options...
Woodland Posted December 13, 2020 Report Share Posted December 13, 2020 15 hours ago, David Burgess said: Nice. What is the purpose of the second wheel on the crank side? The second wheel on the crank side is just that, the crank. Originally the handle was just a piece of dowel mounted directly on the disk, necessitating the disc. I later added a crank handle with rotating know directly to the hub. The crank disc also is something the axle affixes too. Between each disc I made large leather washers impregnated with beeswax and mineral oil. The sanding disc cuts square however there is a bit of play in it. If I end up remounting the discs I would clamp them together against the washers more firmly (while the glue was drying on the axle) to remove the play, but that would make it slightly harder to turn. I considered gearing the crank for higher speeds, but I just decided to keep it simple and low speed, this is more about convenience and "precision" rather than speed. Quote Link to comment Share on other sites More sharing options...
Don Noon Posted December 13, 2020 Report Share Posted December 13, 2020 That's nice... but it needs a motor Here are a couple of disc sander/grinders I put together. The most recent one uses the motor, disc, switch, and miter hardware from a cheapo Harbor Freight belt/disc sander. The discs are inexpensive diamond discs, held on with magnets. While I primarily made this to sharpen carbide lathe tools (which it does fantastically), I have also been finding it very useful for other things as well. (That's my peg lathe in the background). This second one I made some time ago, using an ancient Bodine gearmotor (low RPM) that I accumulated from who-knows-where in prehistoric times. The disc plate I had to fabricate myself, and uses stick-on sanding discs. It is primarily for soundposts.. the angle can be set to a precise angle, and the sled traveles in a groove at a very slight angle to the disc, so the length can be adjusted very precisely. I also use it to trim saddle ends, setting the angle to zero . Quote Link to comment Share on other sites More sharing options...
Jeff White Posted December 13, 2020 Report Share Posted December 13, 2020 4 hours ago, Don Noon said: That's nice... but it needs a motor Here are a couple of disc sander/grinders I put together. The most recent one uses the motor, disc, switch, and miter hardware from a cheapo Harbor Freight belt/disc sander. The discs are inexpensive diamond discs, held on with magnets. While I primarily made this to sharpen carbide lathe tools (which it does fantastically), I have also been finding it very useful for other things as well. (That's my peg lathe in the background). . Don, do you just get the "inexpensive diamond discs" and put rare earch magnets on the other side of the aluminum drive plate , to hold it on? Quote Link to comment Share on other sites More sharing options...
Don Noon Posted December 13, 2020 Report Share Posted December 13, 2020 30 minutes ago, Jeff White said: Don, do you just get the "inexpensive diamond discs" and put rare earch magnets on the other side of the aluminum drive plate , to hold it on? Yes, I drilled some holes in the aluminum disk and glued in round rare earth magnets. I noticed that searching for diamond "disk" works a lot better than "disc", and they're only a few dollars on eBay. Quote Link to comment Share on other sites More sharing options...
Jeff White Posted December 13, 2020 Report Share Posted December 13, 2020 Don, thanks. Yeah, that'll work well, looks like they are only around $7 a wheel on ebay. Quote Link to comment Share on other sites More sharing options...
arglebargle Posted December 14, 2020 Report Share Posted December 14, 2020 12 hours ago, Don Noon said: That's nice... but it needs a motor Here are a couple of disc sander/grinders I put together. The most recent one uses the motor, disc, switch, and miter hardware from a cheapo Harbor Freight belt/disc sander. The discs are inexpensive diamond discs, held on with magnets. While I primarily made this to sharpen carbide lathe tools (which it does fantastically), I have also been finding it very useful for other things as well. (That's my peg lathe in the background). This second one I made some time ago, using an ancient Bodine gearmotor (low RPM) that I accumulated from who-knows-where in prehistoric times. The disc plate I had to fabricate myself, and uses stick-on sanding discs. It is primarily for soundposts.. the angle can be set to a precise angle, and the sled traveles in a groove at a very slight angle to the disc, so the length can be adjusted very precisely. I also use it to trim saddle ends, setting the angle to zero . All that to fit a sound post? Obviously not, but the hand cranked disk is another level of tool. I don't know if you have ever used an Alberti sander (or Woodlands awesome knockoff) but they are sublime. Quote Link to comment Share on other sites More sharing options...
