scordatura Posted September 17, 2020 Report Share Posted September 17, 2020 I had occasion to turn a right handed violin over to lefty for a student that due to a handicap has to play lefty. Meaning, change the order of strings and flip the bridge. A couple of observations. The G and D strings were by far the most affected by the change with the G more affected. They sounded narrow and lacked sonority. The A was not changed that much. The E lacked brilliance but had a wider, rounded quality that was kind of pleasing. It did lose focus and brilliance to a degree. After working on and playing the violin, I had this strange feeling of feeling "off". A kind of dizziness and confusion. I did not expect this. It is still there even an hour later. Not sure if it is good to retrain or shock the brain on occasion! Playing lefty gives me empathy for beginners. Quote Link to comment Share on other sites More sharing options...
dpappas Posted September 17, 2020 Report Share Posted September 17, 2020 Out of curiosity, did you move the bass bar and sound post positions? That would certainly play a role in the frequency response. Quote Link to comment Share on other sites More sharing options...
scordatura Posted September 17, 2020 Author Report Share Posted September 17, 2020 1 minute ago, dpappas said: Out of curiosity, did you move the bass bar and sound post positions? That would certainly play a role in the frequency response. No I didn't. Ideally that should be done. I thought it was an interesting condition to examine the roles of the soundpost and bar. Quote Link to comment Share on other sites More sharing options...
Brad Dorsey Posted September 17, 2020 Report Share Posted September 17, 2020 42 minutes ago, scordatura said: ...After working on and playing the violin, I had this strange feeling of feeling "off". A kind of dizziness and confusion. I did not expect this. It is still there even an hour later... I have experienced the same thing on the two or three occasions that I set up violins to be played left handed. After doing one, my next task was rehairing a bow, and it seemed that the bow was somehow left handed. After the rehair I drove a car and had an odd sensation that I was driving on the wrong side of the road. Setting up a violin to be played left handed somehow reverses some brain circuitry, and it takes a while for the effect to dissipate. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted September 17, 2020 Report Share Posted September 17, 2020 43 minutes ago, scordatura said: I had occasion to turn a right handed violin over to lefty for a student that due to a handicap has to play lefty. Meaning, change the order of strings and flip the bridge. I will suggest that as far as the bridge goes, much more would need to be done than "flipping" it, starting with at least refitting the feet to their new positions, while also adjusting the lean angle, if enough wood remains to do so. Quote Link to comment Share on other sites More sharing options...
Marty Kasprzyk Posted September 17, 2020 Report Share Posted September 17, 2020 Were the string notches in the nut changed? Quote Link to comment Share on other sites More sharing options...
FiddleDoug Posted September 17, 2020 Report Share Posted September 17, 2020 Sometimes, the treble side of the fingerboard is slightly lower than the bass side, This might mean that the string clearances with the old bridge wouldn't be correct. The bowing angles might also be a little different. Quote Link to comment Share on other sites More sharing options...
scordatura Posted September 17, 2020 Author Report Share Posted September 17, 2020 I realize that in an ideal sense a new bridge and nut should be fitted/adjusted. That goes without saying. This situation necessitated a quick change to a school instrument. I am fully aware and trained in instrument setup. I just thought that it would be interesting to note the change in sound. For the record the symmetry of the top arch is quite symmetrical with little or no lifting of the post side. Therefore the feet are well mated to the top. When I get some time I will cut a new bridge and nut. Quote Link to comment Share on other sites More sharing options...
scordatura Posted September 17, 2020 Author Report Share Posted September 17, 2020 1 hour ago, Brad Dorsey said: Setting up a violin to be played left handed somehow reverses some brain circuitry, and it takes a while for the effect to dissipate. Definitely. Very strange and unanticipated. Quote Link to comment Share on other sites More sharing options...
Geigenbauer Posted September 17, 2020 Report Share Posted September 17, 2020 2 hours ago, scordatura said: The G and D strings were by far the most affected by the change with the G more affected. They sounded narrow and lacked sonority. The A was not changed that much. The E lacked brilliance but had a wider, rounded quality that was kind of pleasing. It did lose focus and brilliance to a degree Interesting observations. Thank you for sharing! Quote Link to comment Share on other sites More sharing options...
Shunyata Posted September 17, 2020 Report Share Posted September 17, 2020 Try shaving with the other hand. Just as disconcerting! Anything that requires fine motor movement will have the same effect. Quote Link to comment Share on other sites More sharing options...
pjham Posted September 17, 2020 Report Share Posted September 17, 2020 With regards to the pegs, did having the 'G' peg lower than the 'E' peg get in the way of the index finger or was there still plenty of clearance? Quote Link to comment Share on other sites More sharing options...
Marty Kasprzyk Posted September 17, 2020 Report Share Posted September 17, 2020 7 hours ago, scordatura said: I had occasion to turn a right handed violin over to lefty for a student that due to a handicap has to play lefty. Meaning, change the order of strings and flip the bridge. A couple of observations. The G and D strings were by far the most affected by the change with the G more affected. They sounded narrow and lacked sonority. The A was not changed that much. The E lacked brilliance but had a wider, rounded quality that was kind of pleasing. It did lose focus and brilliance to a degree. After working on and playing the violin, I had this strange feeling of feeling "off". A kind of dizziness and confusion. I did not expect this. It is still there even an hour later. Not sure if it is good to retrain or shock the brain on occasion! Playing lefty gives me empathy for beginners. You were still bowing with your right hand or did you switch that too? Quote Link to comment Share on other sites More sharing options...
Don Noon Posted September 17, 2020 Report Share Posted September 17, 2020 9 hours ago, scordatura said: The G and D strings were by far the most affected by the change with the G more affected. They sounded narrow and lacked sonority. The A was not changed that much. The E lacked brilliance but had a wider, rounded quality that was kind of pleasing. It did lose focus and brilliance to a degree. After working on and playing the violin, I had this strange feeling of feeling "off". A kind of dizziness and confusion. I did not expect this. It is still there even an hour later. Not sure if it is good to retrain or shock the brain on occasion! Playing lefty gives me empathy for beginners. Due to the bass bar and sound post, the bass bridge foot moves vertically mostly at low frequencies, and the treble foot mostly moves at the higher frequencies. If bowing was parallel to the top on all strings, it probably wouldn't make much difference which way you strung the violin. However, there is significant vertical string force due to the inclination of the bow, so there is more G string force going into bass bar and more E string force going into the soundpost... normally. Reverse it, and you get worse low end on the G and worse high end on the E. Interesting reaction to playing backwards. Similar to how humans adapt to inverted images with "upside down goggles". I don't think beginning players would have this reaction, as they have not developed the solid frame of reference for playing one way the another, and therefore wouldn't have the dislocation of adapting to something at odds with "normal". Quote Link to comment Share on other sites More sharing options...
matesic Posted September 18, 2020 Report Share Posted September 18, 2020 7 hours ago, Don Noon said: I don't think beginning players would have this reaction, as they have not developed the solid frame of reference for playing one way the another, and therefore wouldn't have the dislocation of adapting to something at odds with "normal". I disagree, but we've been here very recently! Quote Link to comment Share on other sites More sharing options...
scordatura Posted September 18, 2020 Author Report Share Posted September 18, 2020 13 hours ago, Marty Kasprzyk said: You were still bowing with your right hand or did you switch that too? I did both ways which probably increased the brain "short circuit". Quote Link to comment Share on other sites More sharing options...
scordatura Posted September 18, 2020 Author Report Share Posted September 18, 2020 15 hours ago, pjham said: With regards to the pegs, did having the 'G' peg lower than the 'E' peg get in the way of the index finger or was there still plenty of clearance? Good point. In first and more so half position I did feel the old G/new E peg. Quote Link to comment Share on other sites More sharing options...
scordatura Posted September 18, 2020 Author Report Share Posted September 18, 2020 18 hours ago, Shunyata said: Try shaving with the other hand. Just as disconcerting! Anything that requires fine motor movement will have the same effect. I have done that as I have over the last few years been suffering from golfer's and tennis elbow... Quote Link to comment Share on other sites More sharing options...
scordatura Posted September 18, 2020 Author Report Share Posted September 18, 2020 12 hours ago, Don Noon said: I don't think beginning players would have this reaction, as they have not developed the solid frame of reference for playing one way the another, and therefore wouldn't have the dislocation of adapting to something at odds with "normal". Good point but beginners definitely have another form of disorientation e.g. where do I put my fingers/hands! When I have taught strings classes for music education students that have string players, I ask them to play lefty on their main instrument to give them empathy for beginners. Try it. It Is very humbling!!! Quote Link to comment Share on other sites More sharing options...
Alma Posted September 18, 2020 Report Share Posted September 18, 2020 18 hours ago, pjham said: With regards to the pegs, did having the 'G' peg lower than the 'E' peg get in the way of the index finger or was there still plenty of clearance? I sawed the head off the E peg on my first conversion to lefty violin! Quote Link to comment Share on other sites More sharing options...
Marty Kasprzyk Posted September 18, 2020 Report Share Posted September 18, 2020 14 hours ago, Don Noon said: If bowing was parallel to the top on all strings, it probably wouldn't make much difference which way you strung the violin. However, there is significant vertical string force due to the inclination of the bow, so there is more G string force going into bass bar and more E string force going into the soundpost... normally. Reverse it, and you get worse low end on the G and worse high end on the E. I think the vertical G string forces going into the bass bridge foot are the same as the vertical E string forces going into the treble foot. So reversing the strings wouldn't change these forces. Quote Link to comment Share on other sites More sharing options...
Don Noon Posted September 18, 2020 Report Share Posted September 18, 2020 17 minutes ago, Marty Kasprzyk said: I think the vertical G string forces going into the bass bridge foot are the same as the vertical E string forces going into the treble foot. So reversing the strings wouldn't change these forces. The point is that the frequency content of the input of the G and E is different, and the frequency response at each foot is different. Normally the frequency input and response is matched fairly well; reverse it, and it's not. Quote Link to comment Share on other sites More sharing options...
David Burgess Posted September 18, 2020 Report Share Posted September 18, 2020 3 hours ago, Don Noon said: The point is that the frequency content of the input of the G and E is different, and the frequency response at each foot is different. Normally the frequency input and response is matched fairly well; reverse it, and it's not. I have done only one or two experiments with reversing only the strings, but the fiddles seemed to sound and play (aside from hand-to-peg clearance) very much like they did before. I do get why in theory, this shouldn't be so. Just passing along my findings. Quote Link to comment Share on other sites More sharing options...
Alma Posted September 18, 2020 Report Share Posted September 18, 2020 1 hour ago, David Burgess said: I have done only one or two experiments with reversing only the strings, but the fiddles seemed to sound and play (aside from hand-to-peg clearance) very much like they did before. I do get why in theory, this shouldn't be so. Just passing along my findings. I have no qualifications other than playing three fiddles and one viola converted to lefty, and I noticed the same- --no change after re-stringing. I had one violin built left-handed from scratch, and again, wondered why the bass bar had to be on a certain side...? Quote Link to comment Share on other sites More sharing options...
Don Noon Posted September 18, 2020 Report Share Posted September 18, 2020 5 hours ago, David Burgess said: I have done only one or two experiments with reversing only the strings, but the fiddles seemed to sound and play (aside from hand-to-peg clearance) very much like they did before. Do you play as well lefty as righty? How can you judge the difference in the instrument vs the difference in your playing? I roughtly estimate that the low-frequency coupling to the G string is 50% higher in the normal position vs. in the E position, which should give an observable difference of 1-3 dB depending on whether it is bow power or bow force amplitude that matters. That should be noticeable, but not gigantic. Higher frequencies would have a different change, depending on which bridge foot is most sensitive to the frequency, and this could mask the stronger effect on the lowest frequencies. Quote Link to comment Share on other sites More sharing options...
