cello with romberg bevel fingerboard
 A cello I have has a Romberg bevel fingerboard and the string height above the bevel is a hair under 10mm .  I'll be putting steel strings on it and wondering if there is a standard way of approaching the bridge to adjust for the bevel .
Thanks for any comments  and info .
1 hour ago, nathan slobodkin said:
Duane,
I think he is asking if there is a different way to measure string height when there is a bevel.
VBW,
Romberg or not you measure  from thee under side of the string to the finger board surface. Normal for steel strings would be about 7 mm under the C.
Thank you. I've never seen this before so it through me a bit.
