twcellist
Gut E string for full size 5 string cello
Does anybody have experience with a Gut E string for a full size cello? From what I seem to understand the traditional 5 string cello is a cello piccolo, which is anywhere from a 1/2 size to 3/4 size cello. As such the gut E strings available for cello are at a vibrating length of 64-67 cm. However, a full size cello vibrating length is 69 cm. I've asked around with regards to fitting a gut E string onto a full size cello and most people I have talked to have concerns about the strings snapping. So I wonder if anybody makes a gut E to handle a 69 cm vibrating length.
As recommended in the other thread, contact a string maker.  They'll get you what you need.  (I was going to recommend you contact Damien Dlugolecki, but his website says he's semi-retired.)
So,
https://aquilacorde.com/en/
http://torostrings.it/english/index.html
or call up Gabriela Guadalajara and see what she recommends.
On 11/19/2019 at 7:55 AM, Tom Fid said:
I second that recommendation - they were quick to respond when I needed weird strings for my cornerless Chanot.
Thanks. I did contact Damien actually and he said his E string would "probably not" work on a full size cello. So yeah... it looks like if I want to go full size they'll have to be custom strings.
