Hank
Help identifying old violin
Need some identification. It’s been sitting around our house for awhile, decided to finally check what it could be. After doing some quick research, I figured out that guarnerious violins can be expensive. It was also in this case, not sure if authentic. Let me know what you guys think.
Hi Hank.
I think some better photos would be helpful. Here is the link for the stickied thread about photos used for id purposes. Also I'm curious if you could type out everything the label contains as it's not totally visible. I hope you're able to get some answers.
On 11/5/2019 at 8:31 AM, DelViolino said:
Hi Hank.
Thanks for the reply, I have just posted an updated version. When it gets approved by a mod it should be up
I don’t think you need to worry too much about it being expensive. Whoever wrote the label with a biro, was trying to indicate that it was a Guarneri model, not that it was an original Guarneri. Although in reality, it looks nothing like a Guarneri anyway.
