Jeff White
Kremona bass neck construction
I am trying to determine if the (previously broken) neck on this Eastern European bass has been doweled,pinned etc. I see the reinforcement in the neck in the pic. Do you think that this was factory, or done afterwards? Neck break is a little separated but holding and not flexing. Not sure if spline is the problem. Maybe I should check with uv to see if that’s touched up, or not
