fiddlerjer
laying out the template
I am using the full-size drawing that Henry Strobel provides in Violin Making Step by Step. I'm wondering how I should approach tracing the outline onto aluminum. Is it just a matter of taping the drawing onto the metal and cutting around the outline with a sharp knife?
There are many ways to skin a cat.  If it were me I would use 3m 77 spray adhesive to glue a photocopy of the original onto the aluminum.  Cut out on the bandsaw and then file to the line.
Would the bandsaw need a special blade to cut metal? I guess aluminum is soft enough it should be like cutting through butter.
Yes, It will need a metal cutting blade.  The hook, set and number of teeth of a wood cutting  blade are too course, even for aluminum.  You could easily use stiff cardboard for a template.  Or formica.  I prefer aluminum.
I would have to disagree. Thin plate aluminum cuts just fine with a finer wood cutting blade.
If you put a metal cutting blade on the bandsaw, you would have to install a gearbox to slow it down considerably in order for the metal cutting blade to work.
Also, aluminum will gauld a really fine blade.
I have not tried to cut the aluminum that I use with a wood cutting blade but I have to admit I'm not keen on trying.  No galling yet.
The proof is in the pudding I see. So you don't have to gear down?
You can cut aluminum with standard bandsaw setup for wood. Frank Ford a notable guitar technician has quite a few pages with tips where he makes various fixtures out of aluminum using bandsaw.
Cutting thin aluminum would require slower feed to prevent chatter and I would use piece of plywood on the table for better support if fine details are going to be cut.
I prefer acrylic (pplexiglass) or PC for templates as you can see through when you are laying out plates, you can scribe center-lines on templates and see exactly where it is going...
Why not one of these? If there is no need for large-scale production, I prefer not to spoil the sharpness of my band saw blade by cutting aluminum. This guy has a nice set-up.
That is true. If you want to cut holes in the templates (like the turns of the scroll, or f-holes) you need to pre-drill holes and use fretsaw....
No sir.  Run of the mill Jet 16" single speed bandsaw with a metal cutting blade.  Takes me about 1 minute to change blades.  The only downside is the aluminum bits left behind.
On 6/7/2019 at 12:37 PM, MikeC said:
Aluminum that thin you could cut with scissors.   I would use tin snips.
Scissors works but have the bad habit of slightly bending the edge of the metal, not so good for making accurate templates.
Just my two cents.
Just my two cents.
I hadn't thought of that.  Good point.
Yes I have done this also, the 1/8" fine band saw blade works just fine. I also use 3M 77 spray glue to put the template on the sheet aluminum. Then on the opposite side of the aluminum, I glue a 1/4" door skin. This way the aluminum becomes mixed with wood shavings and it is easier to vacuum up, and safer to handle.
Just my two cents.
I concur, depending on available tooling though,a fellow could cut outside the line and file or sand to final shape.
Henry Srobel is not the best source of violinmaking knowledge.
Yes, you can. I've done it for around 50 years now
On 6/7/2019 at 7:09 AM, saintjohnbarleycorn said:
Nick  , did you find a template for the scroll with the holes cut out around the scroll , or did you just draw it your self thanks , kevin
Just my two cents.
Agreed. Scissors cutting aluminum are not the best method for copying outlines, unless one thinks they are. and doesn't mind the deviations.
