500 - Internal server error.
Bob2
Why, whenever I try to do a search from the home page search box do I get.
There is a problem with the resource you are looking for, and it cannot be displayed.
I'm using the latest Chrome browser under an up to date Windows 10.
  • 5 months later...
  • 1 month later...
On 10/19/2019 at 6:17 PM, fb88vnasia said:
I was checked by screaming frog i see a lot off 500 error link, how can i fix? is it server problems?
The most common cause of the 500 error (Internal Server Error) is the incorrect syntax of the .htaccess file or the presence of unsupported directives in it. Most often it is enough to comment out the Options directive (for this you need to put a # at the beginning of the line), and the problem will disappear.
 Error 500 can also occur due to improper handling of CGI scripts.
