Why arching shape?
reguz
  • Replies 259
1 minute ago, Peter K-G said:
We know that a flat top plate on a violin would collapse
unless it has support bracing, and they don't predict anything, they influence things in a unpredictable way, however the more instruments one makes the more predictable the unpredictability becomes
Explain for us why the the instrument collapse
Just now, Peter K-G said:
Because that's what happens when you put pressure on a flat top box with flexible sides. A pyramid like top would push outwards
You are wrong simplay because you cannot measure any downward going movement
The arch resists the downward pressure of the strings on the bridge as well as the lengthwise squeeze on the top and stretch on the back. Flat topped fiddles have been tried as well as just about every form of arch one can imagine. After a few centuries, a consensus has been reached about what sort of arch tends to give what sort of sound. If you want to ignore all of the experience accumulated since Andrea Amati started making violins nearly 500 years ago, feel free! Do try making a flat violin and if it works better than Stradivari or Guarneri arching, the world will make a beaten path to your door!
You write but do not snything at all, Do you?
I'm perfectly right in the context of what I ment and by choice of words and I can prove it over and over again. You simply interpreted something completely  different from what I wrote
Just now, jezzupe said:
Um, I assume you live in a house....the floor is plywood, yes? if so the plywood is supported by joists, if not, what do you think will happen when you put that grand piano in the middle of the room?
Jezzupe, What is supportiong the floor in your explaination. Answrr on that question!!
Peter I asked a question but you do not give a technical answer. Give a technicalö answer,please!
As I said, joists, which are supported usually by simpson 835 joist hangers nailed in with structural teco nails that are nailed into the rim joist.
and are you drunk or just insane? because you know if its the insane thing, that would be normal, I have found that the violin is an insanity magnet like no other object in the world.
A violin top is like the arch of a Roman bridge or the top of a catedral, it is not that Amati did it 500 years ago, the romans did the same more than 2000 years ago.
The arched top distributes the preassure to the sides without the need of other interna intermediate supporting structures.
Do the test: put weight on a violin top and on a guitar / ukelele top and tell us which one collapses first.
Juan Tavira
Michael, does the downward pressure of the strings move the center part downward. Explain why and when at what stage there arise equilibrium. The instrument does not become havier.
Juan Tavira
Tell us where you support the violin, please do this
Juan Tavira
Tell us where you support the instrument, and explain why?
Juan Tavira
Explain for us why you must support in order producing downward movement.
