Pearl0890
How to clean copper lapping
This is not a copper wire wrapping.  It is a tinsel wrap with silver (or nickel) plated copper winding on the thread.  In some places the plating has worn off exposing the copper, and in other places the plating and copper are both worn off exposing the thread.  This cannot be fixed by cleaning -- it can only be fixed by replacing it.
Try cleaning first with a fine copper brush. when that doesn't work or if it falls apart you can always replace it with nickel or silver wire.
A cautionary tale.  I have a bow that originally had a tinsel wrap that needed to be replaced.  It was replaced with silver wire during a re-hair. The silver wire changed the balance for the worse, IMO.  I had the bow re-wrapped in silk which restored the original balance.
mistake. A wire brush would destroy even fresh tinsel. And as Jim said, if you replace it with wire, the weight and balance of the bow will be different. Might be better, might be worse, but it will be different.
then what would you recommend :)
I cleaned a nickel coated copper lapping once with metal polish (cheap bow), what remained was the clear copper wire, but it doesn't look that bad. It did not had the gunk as in the picture though.
Yes, that is fine with ni coated copper, but this is tinsel. Not metal, but silk. You can't really clean it. If it is the orig. tinsel, I'll sometimes cover it with a clear barrier, but it isn't really reparable. It is fine silk thread.
