Michael Szyper‘s Bench
Finally I decided to start a bench thread. I would like to begin with a few things that I like most - my selfmade bench and what I call ‚violin scrub plane‘.
With this plane I can remove large quantities of wood in a short time. The blade is 5mm thick made of laminated white paper steel. Since I made it I hardly touch any chisel or gouge.
The bench is made out of a one piece ash wood and Iron feet from an early 20 century industry table.
  • Replies 56
15 hours ago, Rue said:
LOVE your table!
Looks like a lively work space as well.
Thanks a lot for the nice words! BTW, the workshop was an old 4-room attic from the 40‘s, decided to make my new workshop out of it and spent almost the whole last year there to finish it ;) was a true pain.
Moving to violin making, this is the latest violin work:
Congratulations on your beautiful new workspace and bench.
I'm sure the light and feel of it will make a positive difference in your work and attitude.
That little scrub plane looks like a real gem.
I made a similar but larger and cruder version for bass work and I stopped using
gouges also.
Where did you find that thick blade ?
gouges also.
Thank you! I took a Japanese chisel with 22 mm width and cut it off in a waterbath to avoid burning of the steel. Since I am at the limit with my 22 mm plane, i could not imagine to use a larger one for scrub work. I made also a 30 mm version but never finished it because the smaller one satisfied me completely since I can take shavings up to 2 mm by one stroke (mainly in spruce, maple a bit less). The plane was not my idea - Peter Westerlund showed it to me.
  • 5 months later...
  • 4 weeks later...
57 minutes ago, Jim Bress said:
Good deep color.  I know you’ve talked about your varnish in another thread, but I haven’t had my morning coffee yet. What kind of varnish did you make?
Thank you Jim. The ground coat is a mix of 1:1 sandarac oil varnish and cooked colophony varnish. The other 2 coats are simply the colophony varnish.
The Sandarac oil varnish gives the ground a lot of depth - so far I like the result more than a colophony ground coat which can get a bit ,muddy‘ if used with a pore filler.
