catnip Posted August 31, 2018 Report Share Posted August 31, 2018 As this summer comes to an end there is nothing on the bench other than one violin that is drying in the sun after varnishing. But I will be starting a new violin back from a gorgeous piece of wood that has been aging for several years. I have been collecting wood for the past 15 years and I have never seen such figure in wood. I have a paper template that I can move around which allows me select which part of the board will give the best figure. I purposely have not identified the wood because I don't think it has ever been used for a violin. You are allowed to guess what it is. Quote Link to comment Share on other sites More sharing options...
Wood Butcher Posted August 31, 2018 Report Share Posted August 31, 2018 Mahogany? Quote Link to comment Share on other sites More sharing options...
catnip Posted August 31, 2018 Author Report Share Posted August 31, 2018 You guessed it! Used a lot for guitars Quote Link to comment Share on other sites More sharing options...
Guest Posted September 1, 2018 Report Share Posted September 1, 2018 Nice wood John! I'm also planning to build a five string from some Honduran Mahogany I have... rings like a bell. I hope you post some photos here on your bench when you start. Will it be a 5 string? What will you use for a neck? Quote Link to comment Share on other sites More sharing options...
catnip Posted September 1, 2018 Author Report Share Posted September 1, 2018 For the neck I plan to use some quartered Caro-Walnut (gun stock) that I have that closely matches the look and feel of this piece . Quote Link to comment Share on other sites More sharing options...
catnip Posted September 5, 2018 Author Report Share Posted September 5, 2018 I decided to make a new mold for this violin based on the 1709 Viotti. I did some research in my books and files and found that I have two different Viotti. One from 1709 based on the G form ( thanks Addie) and has a one piece back; the other from 1718, also known as "Arnold Rose" has a two piece back and is smaller. For this mold I printed out the image from UK_RAM website on 11" x 14" paper and took it to Staples and enlarged it to 358 mm on 11" x 17" paper. Split it down the middle and took the right half as my template. Spray glued it to 1/8" Baltic plywood and cut and sanded to the outline. Then reduced the outline by 3.7 mm (which is to outside of the purfling line) and further reduced to corners by 2 mm. I taped this template to 2 pieces of 1/2" Baltic plywood and rough cut the outline on the bandsaw. I taped all the pieces together and using a router trim bit finished the outline exactly so that length was 358 mm with half widths of 80.8 / 51.8/ 100.5. This will give me the approx desired width ( UB/ CB/ LB) of 161 / 103 / 201 mm Now its just a matter of gluing the two halves together and marking with drill holes where the cutouts will be. Here the form is glued with the half template. Note: this method does not use centered guide pins. The locating pins are in the upper and lower bouts shown a green circled dots. Its almost done. I just have to drill out the large clamping hole, varnish and label the form. I learned this quick method from article S. Ovington wrote. It takes roughly about 3 hours to make a new form with two coffee breaks. Quote Link to comment Share on other sites More sharing options...
catnip Posted September 9, 2018 Author Report Share Posted September 9, 2018 Here is the finished form Quote Link to comment Share on other sites More sharing options...
Jim Bress Posted September 9, 2018 Report Share Posted September 9, 2018 Nice. I like your labeling of demensions. Is the lower bout with correct? -Jim Quote Link to comment Share on other sites More sharing options...
catnip Posted September 9, 2018 Author Report Share Posted September 9, 2018 I number the blocks from from #1 to #6 and include the approx. block heights. Those other dimensions are for rib lengths and (lining lengths). I use block numbers as a reference when I cut the ribs so that I don't flip the grain pattern which is easy to do. I also sequentially number the ribs as I rip them from the stock so that I can use the best sequential pair for grain matching at the end block Quote Link to comment Share on other sites More sharing options...
Jim Bress Posted September 9, 2018 Report Share Posted September 9, 2018 Oh ok. Sounds like a good system for limiting waste. Quote Link to comment Share on other sites More sharing options...
catnip Posted September 10, 2018 Author Report Share Posted September 10, 2018 Ribs and linings installed. Looking forward to carving the back now. Quote Link to comment Share on other sites More sharing options...
Nick Allen Posted September 10, 2018 Report Share Posted September 10, 2018 2 hours ago, catnip said: Ribs and linings installed. Looking forward to carving the back now. You make those clamps? Quote Link to comment Share on other sites More sharing options...
FoxMitchell Posted September 11, 2018 Report Share Posted September 11, 2018 Fanciest lining clamps I've ever seen! Quote Link to comment Share on other sites More sharing options...
catnip Posted September 11, 2018 Author Report Share Posted September 11, 2018 Yes, I made them. I never liked the clothes pegs with extra elastics, since you can only do one side at a time. I tried some cheap plastic G clamps but it was easy to strip the threads. Then I made some wooden G clamps but sometimes (not often) the leg of the clamp would break. So finally I found some aluminum C channel and added the little plastic insert. These clamps work really well for me. Quote Link to comment Share on other sites More sharing options...
Nick Allen Posted September 11, 2018 Report Share Posted September 11, 2018 1 hour ago, catnip said: Yes, I made them. I never liked the clothes pegs with extra elastics, since you can only do one side at a time. I tried some cheap plastic G clamps but it was easy to strip the threads. Then I made some wooden G clamps but sometimes (not often) the leg of the clamp would break. So finally I found some aluminum C channel and added the little plastic insert. These clamps work really well for me. Those are really neat little guys. Quote Link to comment Share on other sites More sharing options...
catnip Posted September 13, 2018 Author Report Share Posted September 13, 2018 Rough outside arching done. I have just finalized the overhang by temporarily gluing the back to the form. Tomorrow I will remove the top, finalize the edge ledge and then start on the purfling. This mahogany was pretty chippy under the small finger planes because of the figure. Quote Link to comment Share on other sites More sharing options...
catnip Posted September 14, 2018 Author Report Share Posted September 14, 2018 The purfling edge (ledge) has been finalized to 4 mm for the most part. I leave the button a little thicker (4.2 mm) and the corners at 4.5 mm. Quote Link to comment Share on other sites More sharing options...
catnip Posted September 17, 2018 Author Report Share Posted September 17, 2018 Purfling groove laid out and cut. Corners finished and purfling glued. Outside longitudinal and cross archings almost completed. I like to revisit the arching over a few days with a fresh eyes. The plate weighs 275 gm at just under 16 mm. The next step is to do the inside graduations. Quote Link to comment Share on other sites More sharing options...
catnip Posted October 2, 2018 Author Report Share Posted October 2, 2018 Took a two week break to redo the front steps. I still have to re-install the railings but I needed to have functional steps as soon as possible. The previous steps were destroyed by carpenter ants which I have addressed with some home recipes of borax and sugar. Each stringer was custom fit to the ground with a template with a hinged bottom then planed to fit using a cardboard test strip. Looking forward to getting back to working on violins. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 8, 2018 Report Share Posted October 8, 2018 Is this mahogany fiddle going to be a 4 or 5 string? Please continue posting photos and especially a sound sample when completed. I'm very interested in your project and making a 5 string from my mahogany stash. Quote Link to comment Share on other sites More sharing options...
catnip Posted October 11, 2018 Author Report Share Posted October 11, 2018 I finally finished my front steps and now I can get back to the mahogany violin. This will be a regular 4 string violin. I have made three 5 String violins. Quote Link to comment Share on other sites More sharing options...
FoxMitchell Posted October 11, 2018 Report Share Posted October 11, 2018 48 minutes ago, catnip said: I finally finished my front steps and now I can get back to the mahogany violin. This will be a regular 4 string violin. I have made three 5 String violins. Pretty! On 9/17/2018 at 11:13 AM, catnip said: Purfling groove laid out and cut. Corners finished and purfling glued. What glue did you use here? Quote Link to comment Share on other sites More sharing options...
catnip Posted October 12, 2018 Author Report Share Posted October 12, 2018 I decided to take a picture before I started gluing to document the process. Using this method there is no time to take pictures. You have to work quickly because the hot glue will swell the groove. There are other methods to glue purfling but this is the method I am most comfortable with. It is fast and efficient. I also compress the purfling using a homemade press similar to what Peter Westerlund uses. Quote Link to comment Share on other sites More sharing options...
Rue Posted October 12, 2018 Report Share Posted October 12, 2018 Love the new stairs! Quote Link to comment Share on other sites More sharing options...
