Jimlad Posted September 2, 2022 Report Share Posted September 2, 2022 For what it is worth - I remember about 50 years ago reading a specification clause that said " ... bolts shall be boiled in linseed oil.." Quote Link to comment Share on other sites More sharing options...
Davide Sora Posted September 2, 2022 Report Share Posted September 2, 2022 3 hours ago, Jimlad said: For what it is worth - I remember about 50 years ago reading a specification clause that said " ... bolts shall be boiled in linseed oil.." Bolts? Maybe some sort of anti-rust treatment? Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted September 5, 2022 Report Share Posted September 5, 2022 Quote Link to comment Share on other sites More sharing options...
Davide Sora Posted September 5, 2022 Report Share Posted September 5, 2022 1 hour ago, Michael_Molnar said: Thanks Michael. But damn, cooked at 400 °, if it is celsius I thought that the linseed oil should be burned completely. Well, not for violins... Quote Link to comment Share on other sites More sharing options...
Bill Yacey Posted September 5, 2022 Report Share Posted September 5, 2022 I guess we need to consider " When the ancient texts speak of boiled linseed oil, do they mean literally boiled, or simply heated to an arbitrary temperature? Boiled seems more like an absolute term. Quote Link to comment Share on other sites More sharing options...
Davide Sora Posted September 5, 2022 Report Share Posted September 5, 2022 37 minutes ago, Bill Yacey said: I guess we need to consider " When the ancient texts speak of boiled linseed oil, do they mean literally boiled, or simply heated to an arbitrary temperature? Boiled seems more like an absolute term. I think your second guess is more likely, boiled I think it was anciently used simply to mean heated over a fire or some source of heat. This is an interesting article on temperature control systems before the thermometer came into common use: https://recipes.hypotheses.org/11275 Quote Link to comment Share on other sites More sharing options...
Michael Szyper Posted September 6, 2022 Report Share Posted September 6, 2022 17 hours ago, Davide Sora said: Thanks Michael. But damn, cooked at 400 °, if it is celsius I thought that the linseed oil should be burned completely. Well, not for violins... My sandarac oil varnishes can reach 380°C and the result are quite fine. Nevertheless, I don't see a reason to boil the linseed oil for itself in these high temperatures. Quote Link to comment Share on other sites More sharing options...
JacksonMaberry Posted September 6, 2022 Author Report Share Posted September 6, 2022 7 hours ago, Michael Szyper said: My sandarac oil varnishes can reach 380°C and the result are quite fine. Nevertheless, I don't see a reason to boil the linseed oil for itself in these high temperatures. Lemme see your sandarac! I've only played with sandarac oil varnish once, and in cooking the resin in little batches, it was the batches that reached 350° and higher that actually cooked into oil. Anything lower would not incorporate. Really blast from the past seeing this thread! I have learned an awful lot since then. Quote Link to comment Share on other sites More sharing options...
