______ Posted May 6, 2018 Report Share Posted May 6, 2018 Hi guys. There's a violin listed in present Tarisio New York online auction: "AN ENGLISH VIOLIN BY THOMAS SMITH, LONDON, 1778" Since it looks strange to me - neck width at nut looks quite wide to me, purfling is a fake, as well as neck graft, head execution is rather poor - it makes me doubting if it's fully Thomas Smith violin. What do you think? Was it rule in that period for purfling to be fake? JM Quote Link to comment Share on other sites More sharing options...
martin swan Posted May 6, 2018 Report Share Posted May 6, 2018 A very fine English violin of the period. what are you comparing it to? Quote Link to comment Share on other sites More sharing options...
______ Posted May 6, 2018 Author Report Share Posted May 6, 2018 25 minutes ago, martin swan said: A very fine English violin of the period. what are you comparing it to? Hi Martin. Actually to this violin. What about fake purfling? And was neck graft imitation added somewhat later? Thank you. JM Quote Link to comment Share on other sites More sharing options...
martin swan Posted May 6, 2018 Report Share Posted May 6, 2018 also has what you call "fake" purfling ... The neck graft is genuine - not sure why you are so suspicious. Quote Link to comment Share on other sites More sharing options...
Digger Posted May 8, 2018 Report Share Posted May 8, 2018 Is the scroll somehow warped? The photo of the back of the violin makes the scroll look odd. Quote Link to comment Share on other sites More sharing options...
GeorgeH Posted May 9, 2018 Report Share Posted May 9, 2018 1 hour ago, Digger said: Is the scroll somehow warped? The photo of the back of the violin makes the scroll look odd. I was told that some makers soak their scrolls in water as they are carving them, and that this can cause this type of warp after they dry out. Quote Link to comment Share on other sites More sharing options...
Argon55 Posted May 9, 2018 Report Share Posted May 9, 2018 Other, more expert people should be able to confirm this, but if you mean the purfling is drawn on the violin, then I understand that this practice wasn't unusual in English violins in the 18th century Quote Link to comment Share on other sites More sharing options...
Ben Hebbert Posted May 22, 2018 Report Share Posted May 22, 2018 I'm very happy with the one on Tarisio. Smith's violins commonly have exquisite inked purfling, which is so good that you wonder if it would have been easier to just inlay them instead. However, there are elements of the carving of the edges that they forgo when ink purfling is applied. I also have a very fine example with purfling, and as a result it has the fine built up edges that you would expect on a genuine Stainer. It's evident that these must have been sold at two different qualities - fine and super fine. The varnish appears to be applied differently, so purfled ones seem thinner and more refined in the varnish but in both cases there seems to be an ingredient that oxidises, so they always end up rather muddy in colour. I would add that the button graft means that the violin has lost its pins at the top. The large one is a bit bigger than I expect, but Smith did use a pin system that resembles Cremonese on the whole. Quote Link to comment Share on other sites More sharing options...
