chungviolins
Bass Bar Clamps
Hmm, Benjamin pls pm me.
Thanks,
If any one wants to make these clamps, I'll give a detailed drawings and instruction.
KYC
PS: If more than one member ask for it, I'll post it here.
On 1/9/2018 at 1:30 AM, carl1961 said:
nice and sturdy, just have to be careful so you don't crush the top.
This cannot happen even if you try very hard.
BB, before shaping, is 4 times thicker than typical top thickness, which makes it at least 50 times (!) stronger than the top, so no matter how hard you clmap it's not going to happen.
I made a counter jig for the clamping, but I ended up not using it, for all practicality it wasn't needed. (See below pics )
I'm attaching drawings and pics here, hope it is easy to figure out if you want to make them.
If you have any Qs , pls PM me.
Materials : Clamp : I used Herdim repair clamp 50 x 80 mm
             When you drill a hole in the clamp, file it slightly hollow so that drill bit doesn't stray. ( clamp Herdim to a piece of wood when drilling )
                    Rod A : carbon fiber   .787 " x .196 "   (20 x 5.0 mm)
                    Rod B : carbon fiber   .325 " x .187 "   (8.3 x 4.8 mm)
https://goodwinds.com/carbon/solid-flat.html#
                Metal screw (H) : stainless steel #4-32, 1/2 inch
                Washer (G) : stainless steel washer for  #4-32 screws
               Anchor rod (D) : plastic vn tail gut, this stabilize the small piece ( prevent rotation )
               C : tap or drill smaller hole and force 4-32 screw tight
               F :  cork 2mm thick ( outside 2 layers )
               H : 4-32 screws are attached but free to move 5° in  every direction
              E : this stabilize the main rod to stay in the right angle (90°), shouldn't be tight,  snug, free to move around
Glue : super glue (thin, like Krazy glue), also size the  cut end with super glue
Cutting caron fiber rods : bandsaw or handsaw, make sure it doesn't splinter in the endgrain, if it happens , fix it w/superglue.
Koo Young Chung
PS : If you make these clamps and used, pls post here tell me how it went, thanks.
The measurements above are for vn, you can extrapolate them for va.
You need one bigger one and two small ones for violin BB.
The stabilizers (E) are for easy clamping, you can align it with one hand bc it doesn't swivel free.
KYC
Saintjohn, Tommy : I hope you make these and try, thanks.
One more detail..
When you glue the small piece (12 mm ) to the  piece E, make sure the small piece align parallel with the clamp frame, more or less.
KYC
