baroquecello Posted January 5, 2018 Report Share Posted January 5, 2018 Dear maestronetters, I recently had a very unpleasant experience with a relatively newly made violin by a relatively well known maker from a germany, which got a Sound post crack. It was discovered by another maker when he inspected the violin before starting a Sound optimisation. (which he didn't do then, ofcourse). The violin received a new top for half the usual Price, but now the new Sound post scares me, as it is clearly visible through the top, and, seen from outside, seems not to fit very well. After the inspecting lutier found the SP-crack, he checked the top thickness using one of those digital devices. It seemed the top in the SP-area had a thickness of about 2.7MM. I don't know what the thickness of the new top is, but I suspect it is similar, as the maker of the violin seems to have his theories about how to make a good sounding violin. (and he is not unsuccessful, many professionals Play his Instruments). Now to my question: for your own making or generally speaking, would you consider 2.7MM acceptable or too thin in the SP-area? What would your minimum and your maximum be and what is what you usually do? Quote Link to comment Share on other sites More sharing options...
David Burgess Posted January 5, 2018 Report Share Posted January 5, 2018 2.7 is in the ballpark of what one often sees, but I go more like 3.3. If the soundpost is "printing through" early on, that does suggest a poorly fitting post. Quote Link to comment Share on other sites More sharing options...
uncle duke Posted January 5, 2018 Report Share Posted January 5, 2018 48 minutes ago, baroquecello said: Now to my question: for your own making or generally speaking, would you consider 2.7MM acceptable or too thin in the SP-area? What would your minimum and your maximum be and what is what you usually do? Sorry to hear that and my opinion just based on what I've learned in the last few years is yes, 2.7mm sp area is or more than likely is, not thick enough. I'm not a professional maker, just a hobbiest - I can't see a pro here giving away what they'd do so you can have my opinion. I checked my plans for a Strad of some sorts and a D.G/ Maggini and their soundpost thickness areas are considerably thicker on paper. 4.41 or .174 for D.G. and the Strad just slightly thinner. That's not really thick when you see the belly rise relatively easy when it's soundpost setting time. I feel safe staying with those specs. Now if I could convince myself that I don't need 1.6mm thick outer bout areas all of the time I may just be able to get to the next level of making assuming there is a next level. good luck baroquecello edit- on a whim I went out and found a micrometer that was open already. Using intuition only I turned the adjustment to close the gap and stopped turning where I thought the best thickness for a soundpost thickness for a belly would be best. I stopped at .181 which equates to 4.59 mm. Quote Link to comment Share on other sites More sharing options...
kyproset Posted January 5, 2018 Report Share Posted January 5, 2018 The thickness of my 1857 Vuillaumes's SP area at the top is 2.4, 2-5mm and I was told it's way too thin, so I'd better be careful. Quote Link to comment Share on other sites More sharing options...
Torbjörn Zethelius Posted January 5, 2018 Report Share Posted January 5, 2018 A badly fit soundpost will crack any top. Quote Link to comment Share on other sites More sharing options...
duane88 Posted January 5, 2018 Report Share Posted January 5, 2018 1 hour ago, Torbjörn Zethelius said: A badly fit soundpost will crack any top. exactly! I hate to go under 3.0 on a new instrument, but have seen plenty, old and new, that are thinner and are just fine. Quote Link to comment Share on other sites More sharing options...
christian bayon Posted January 5, 2018 Report Share Posted January 5, 2018 I go around 3.2. Many contemporary instruments are way too thin (blame the Strad posters) and even not able to avoid the neck projection going down. Quote Link to comment Share on other sites More sharing options...
chungviolins Posted January 5, 2018 Report Share Posted January 5, 2018 This is my measurement: 3.5 mm KYC Quote Link to comment Share on other sites More sharing options...
David Burgess Posted January 5, 2018 Report Share Posted January 5, 2018 1 hour ago, christian bayon said: I go around 3.2. Many contemporary instruments are way too thin (blame the Strad posters) and even not able to avoid the neck projection going down. Genuine Strads too. On a multi-million dollar instrument, most owners won't protest too much about putting out a few thousand dollars occasionally. The expectation goes much differently with contemporary instruments. Quote Link to comment Share on other sites More sharing options...
Alex l. Reza Posted January 5, 2018 Report Share Posted January 5, 2018 I build pretty "stout" instruments and usually stay around 3.3-3.75 at sound post. I have seen many newer contemporary instruments with 1.9!!! and the edges down to nothing also. Makes me wonder how they would stand up over time. Quote Link to comment Share on other sites More sharing options...
JohnCockburn Posted January 6, 2018 Report Share Posted January 6, 2018 Is this turning into an organ swinging contest about who makes the thickest soundpost region? Quote Link to comment Share on other sites More sharing options...
arglebargle Posted January 6, 2018 Report Share Posted January 6, 2018 I don't graduate the soundpost area at all. Quote Link to comment Share on other sites More sharing options...
Melvin Goldsmith Posted January 6, 2018 Report Share Posted January 6, 2018 I put across grain laminate patch in there and keep it around 3.5mm.....kinda like what I know works Quote Link to comment Share on other sites More sharing options...
Guest Posted January 6, 2018 Report Share Posted January 6, 2018 3 minutes ago, Melvin Goldsmith said: I put across grain laminate patch in there and keep it around 3.5mm.....kinda like what I know works Do you use Maple or Spruce? Quote Link to comment Share on other sites More sharing options...
Melvin Goldsmith Posted January 6, 2018 Report Share Posted January 6, 2018 spruce All the top concert fiddles have a spruce laminate in the S P area... fact Quote Link to comment Share on other sites More sharing options...
Conor Russell Posted January 6, 2018 Report Share Posted January 6, 2018 I just make the whole thing out of plywood. And I can buy it at my local hardware. It's fab. Quote Link to comment Share on other sites More sharing options...
Stavanger Posted January 6, 2018 Report Share Posted January 6, 2018 Carved bassbar is so 1900. The new thing is carved soundpost. Quote Link to comment Share on other sites More sharing options...
Brad H Posted January 6, 2018 Report Share Posted January 6, 2018 9 minutes ago, Stavanger said: Carved bassbar is so 1900. The new thing is carved soundpost. Ha ha! At least you know the top of the sound post would fit! Quote Link to comment Share on other sites More sharing options...
kyproset Posted January 6, 2018 Report Share Posted January 6, 2018 So gents, what is the thinnest acceptable measurement for the SP area? Quote Link to comment Share on other sites More sharing options...
baroquecello Posted January 6, 2018 Author Report Share Posted January 6, 2018 8 hours ago, Melvin Goldsmith said: I put across grain laminate patch in there and keep it around 3.5mm.....kinda like what I know works is that 3.5 including the Laminate patch or dos that come on top of it? Quote Link to comment Share on other sites More sharing options...
uncle duke Posted January 6, 2018 Report Share Posted January 6, 2018 2 hours ago, kyproset said: So gents, what is the thinnest acceptable measurement for the SP area? Having a violin like yours first makes me think did Vuilluame make a Strad copy or a Del Gesu copy. Next would be did he copy another first class maker other than those two or did he make a violin following his own scheme. As for present day making maybe make an average of all the answers you have here above so far for an answer but not necessarily the answer. Grain line spacing, following a specific plan and the nature of the wood are probably why there's not just one answer for a soundpost area thickness. Maybe treat yours as a 450 year old instrument rather the a 200 year old instrument - be careful. Quote Link to comment Share on other sites More sharing options...
nathan slobodkin Posted January 6, 2018 Report Share Posted January 6, 2018 4 hours ago, kyproset said: So gents, what is the thinnest acceptable measurement for the SP area? The one that doesn't collapse or deform during the original owners lifetime, Sounds OK and doesn't crack unless it's in an accident or falls into the hands of some self invented set up scammer. Looking back through my records I have used anywhere from 2.7 to 3.3 for violins over the years with various archings, sizings and models. Feedback has been that my instruments are pretty low maintenance. Quote Link to comment Share on other sites More sharing options...
nathan slobodkin Posted January 6, 2018 Report Share Posted January 6, 2018 12 hours ago, Melvin Goldsmith said: I put across grain laminate patch in there and keep it around 3.5mm.....kinda like what I know works Melvin, I am assuming you are talking SP patch size. Does this allow you to make a thinner chest area than if you were blending away from a carved in thick area at the post? Is that why you do it? Quote Link to comment Share on other sites More sharing options...
Don Noon Posted January 6, 2018 Report Share Posted January 6, 2018 6 hours ago, kyproset said: So gents, what is the thinnest acceptable measurement for the SP area? Depends on who's doing the accepting. There is no set standard or stress calculation that will give "the" answer. It "should" also depend on the properties of the wood; high density with good crossgrain strength could be much thinner and give the same durability as much thicker, low-density splitty wood. I use a small maple patch to prevent denting, in addition to leaving the general area thicker. Normally ~3.2 plus the 0.5mm patch. Quote Link to comment Share on other sites More sharing options...
Michael_Molnar Posted January 6, 2018 Report Share Posted January 6, 2018 I feel that the SP patch ensures a better transfer of SP vibrations into the spruce plate fibers. Some makers complain that the maple patch can be slippery which lets the SP slide with time. So, I scuff mine up just a bit. Quote Link to comment Share on other sites More sharing options...
