choumichou
Violin finger tapes : Help beginner
Hello everyone,
I have just bought a 4/4 mendini violin, i am trying to self-learn some basics for the moment.
I tuned the violin and placed the finger tapes according to the positions on this link http://myviolinlessons.blogspot.com/2011/08/how-to-put-violin-tapes.html
I am sure i measured correctly from the bottom line on the fingerboard
 1. 36mm    2. 67mm  3. 79mm  4. 110 mm
(what is confusing is that some sources give other measurements)
The problem is when i put my finger on the tapes , bow on a string and listen on different tuners it doesn't give  the right note .
For example on A string bowing with finger on tape 2 (67mm) must sound C#   . I get the correct C# sound at 63mm.
It's very confusing because i don't think each violin has its own positions. It means a violinist has to memorize positions for each different violin ????!!!
Here is a picture of the violin : (i removed tape 1 and 4)
https://imgur.com/a/MTU2l
Thank you anyway
Edited by choumichou
I placed mine using the tuner and that seemed to work. In tune with the tuner is better than my ears and I couldn't find an internet guide like the one you had. I wonder if how/where you place fingers has an effect, and how this changes among specific violins (i.e. should not apply to fractionals, which would need different guides).
Violins may vary just a little bit but not much. Depends on the construction and setup. It would eventually become much easier to play on different violins once you get a hold of it. If the quality of setup is good, then you don't need to adjust too much.
Remember that the way you place your finger combined with the width of your fingertips also contributes to what note is played.
Do you have the measurement of the scale length? Please see belowmeasure_violin_scale_length.jpg
Even the article says the placement may not be exact.  your finger tip is not an exact point either so could vary one way or the other.  also is it the front or back edge of the tape or the center of the tap that should be at that measured location?     what I did is make small diamond shaped piece of tape and put it on the side of the finger board with the point a the exact location.  But still it's not exact,  depends on how well tuned each sting is.    Finally I took the tape markers off and just find the right note by ear.    I'm just a beginner too.
A ready-made fingerboard sticker (from music shops, ebay, amazon etc). is that it is flat, whereas pieces of tapes cause the finger to be not quite flat.
Personally I think fingerboard tapes are a terrible idea. However, I have just bought a fingerboard sticker for someone close to me who is beyond certain that she knows better than I do what she needs in order to learn the violin, so there is no point in arguing, and I am not going to repeat my views here.
The pitch sounds the vibration of the string between the bridge and the highest place on the fingerboard that your finger allows it to vibrate-it is not the middle of your finger. The use of tapes is never more than an approximation to help you develop and your brain to remember how to "block" your finger positions. If you use the tapes when playing some of the early pieces in Suzuki Book 1 (with familiar tunes) it can help you set up your hand properly - but ultimately you always have to depend on your ears. The tapes should be removed as soon as  you have learned where all 4 fingers go to be in tune. Actually, when I had to tape fingerboards for students, I never taped the 4th finger. I figured that by the time the students got to using their 4th fingers it was time to remove all the tapes "and set them free."
The vibrating string length (distance from nut to bridge) and the string clearance above the fingerboard all affect the placement of the tapes.
A beginner only needs two tapes: one for the first finger and one for the third finger. Depending on the scale, the second finger is placed either just after the first finger tape or just before the third finger tape. Once you can play in tune without looking at the tapes, you might add a fourth finger tape and remove the other two.
Here is a method that works well for me:
Tune the violin.
Using your fingernail to stop the E string, pluck the E string until your tuner registers an F#. Make sure you stop the string to the fingerboard. Use a pencil against your fingernail to scribe a mark on the fingerboard.
Repeat the procedure on the E string but this time make a mark for an A.
Now repeat the procedure on the G string but this time place a mark at an A for the first finger, and a C for the third finger.
I recommend white, low tack drafting tape, or paper artist tape. This stuff is easy to position and leaves very little residue when removed.
A width of 3mm to 6mm (1/8" to 1/4") works well. The wider tape is a little easier to see while playing.
Slide a piece of paper under the strings and stick one end of the tape to the paper. Hold the other end of the tape up against the strings and use the paper to pull the tape across the fingerboard.
Position the tape so that the G and E string marks are covered by the center of the tape. Press down and trim tape to the edge of the fingerboard.
I'm a relative beginner to playing the violin myself, having started about 7 months ago. I have been playing guitar for 20-odd years though.
My teacher didn't have me use finger-tapes or markers of any kind, and I must say I'm quite glad. I think that not using tapes or markers allows you to place your fingers as they want to be instead of trying to focus on an edge or contact point to coincide with the tape.
Most of the time my first position playing is now quite adequately in tune, however, I can't imagine how useful any sort of marker would have been for very long as the difference in being in tune and out of tune is incredibly slight. I can play a note that sounds almost perfectly in tune and then throw it noticeably out of tune by altering the position of my wrist slightly, never mind the finger.
I think, as people trying to the learn the violin, this is just a hurdle we have to overcome over time (and mostly with our ears rather than our eyes).
Progress feels slow, but if you keep correcting it does happen!
Going a little off-topic ... maybe this will help you (now or eventually) do without tapes.
Be sure you have good strings on the violin.  If you have decent strings, you should hear sympathetic vibrations from neighboring strings.  For example, playing D on the A string will cause the open D string to vibrate an octave lower than the string you are playing.  You listen for the vibrations, and that will help you play in tune without looking at your fingers.
Low-end strings from major makers will likely be better than what came on your Mendini.  Something like Preludes or Tonicas don't cost a fortune but will vibrate sympathetically.
Also you can look at your tuner to know whether you are playing in tune, another way to do without tapes.
