MikeC Posted August 5, 2017 Report Share Posted August 5, 2017 Being kind of a hack I probably shouldn't but someone asked me if I could do a repair. He said the back was coming loose. I asked is it off or just a little bit. He said just a little near the neck. I have not seen it and don't have pictures. If a back is coming off a little near the neck, I assume the button area. What would be the best way to clamp that? Assuming I can get some glue into it. He said it's about 100 years old so I'm assuming it's the typical early 1900s German type fiddle. Quote Link to comment Share on other sites More sharing options...
GeorgeH Posted August 5, 2017 Report Share Posted August 5, 2017 I would assume it is a seam, not the button. And I personally would never try to repair somebody else's violin, so I think the first clause of your first sentence is correct. Quote Link to comment Share on other sites More sharing options...
MikeC Posted August 5, 2017 Author Report Share Posted August 5, 2017 don't know if it's the center seam or if it's where it attaches to the ribs or button. If center seam then I definitely would not mess with it. Maybe I'll get a look at it sometime soon and if so, will post a picture. Quote Link to comment Share on other sites More sharing options...
deans Posted August 5, 2017 Report Share Posted August 5, 2017 If its just a seam separation its a relatively easy fix--for a luthier who has the right clamps. This is a repair that most shops dont charge a lot, so its well worth taking it in. Quote Link to comment Share on other sites More sharing options...
MikeC Posted August 5, 2017 Author Report Share Posted August 5, 2017 I'm not a shop though, just a home hobbyist. I may have to fabricate a custom clamp. Still haven't seen the fiddle yet though. Quote Link to comment Share on other sites More sharing options...
