keyboardclass
How to clean a label
You can dust it with a manual lens duster, which lightly puffs air.  An ear cleaning bulb would work, too.
You could try canned air, but go slow, and don't get too close.  Haven't tried.
Dust with a sable brush. This is a very light abrasive.
Alternately, try photographing, and manipulating the images.
yes with some mild manipulation Markneukirchen becomes Stradivarius
Well, he did most of his work there. :rolleyes:
Heat a handful of uncooked rice in a microwave until warm to the touch, pour it in through the f-holes, and swish it around for a few minutes. Flip it over and get the rice out the way it got in. Then spend a half hour trying to get that last goddamn grain to fall through the goddamn f-hole. Repeat as needed.
It does not need to be heated to work well, and I use a measured tablespoon of rice.
Personally, I would not put warm anything inside a violin.
17 hours ago, keyboardclass said:
How can I clean the label inside to make it readable without taking the top off?  Thanks in advance!
Do you have a photo of the label (pre-rice) ??
Would that include an inspection light?
No, but I am careful to avoid touching the interior with the lamp. I would not put warm rice inside a violin, but that is just me personally.
Good lighting is a must! My Luthier Lights generate very little heat, and give fantastic light for interior work, A USB endoscope is also a great accessory. This picture was taken using that combo.
Doug's interior lighting is the best I've run across, so far.
33 minutes ago, jacobsaunders said:
Haven't any of you got an air-compressor?:rolleyes:
Sure, but one needs to consider the use of high-velocity air judiciously, like the potential to blow off parts of poorly attached labels.
If dusting and a bright light doesn't help, you could see if you can read it under black light.  Who knows, the ink might glow bright green...
Peter Prier cautioned us to tell the customer that it was uncooked rice, relating many incidents of cooked rice being put into instruments.
I've ordered a USB endoscope but will have to wait 6 weeks as I'm away.  I should have said, you can barely see there's a label.  Just faint outlines of the paper.
On 2017/07/19 at 5:33 PM, keyboardclass said:
I've ordered a USB endoscope but will have to wait 6 weeks as I'm away.  - snip -
Hi keyboardclass - could you give some details of the one that you have selected.
Thanks edi
Oyedens 5.5mm 6 LED Waterproof Lens HD Endoscope Inspection Camera for Android /Windows 2000/XP/Vista/7
Real cheap I'm afraid so I thought I'd see what it does (probably not anything!).
