Phun tunes Posted May 10, 2017 Report Share Posted May 10, 2017 I have a cello I just bought used. It was hardly played. Probably because of the buzzing. Have not played since High School and trying it again. I have played guitar for years and work on my own instruments. Familiar with basic guitar setup. On this cello it does not buzz on open strings. When fretting the A and somewhat D string in first or second position it buzzes very bad. I attached two pictures. In the first I used a straight edge and there is light between the straight edge & fingerboard from just below the nut to the top of the body. In the second picture my finger is where the straight edge again makes full contact with the fingerboard. This leads me to believe the neck or fingerboard is warped? Or is scooped wrong? Or something else? Or bridge is too low? I didn't pay much for this cello (though I found it was close to its new price) and don't want to put much money into it as I don't know if I will play it much. Just wanted to try cello again. Thanks for any help or info. Paul Quote Link to comment Share on other sites More sharing options...
MarkBouquet Posted May 10, 2017 Report Share Posted May 10, 2017 Fingerboard surface concavity is necessary and normal. The maximum concavity is at the center of the string length, not the center of the fingerboard. For a 4/4 cello it should be 0.9mm under the A string, and 1.5mm under the C string. As to the cause of your buzzing, I don't think you've given us enough information to tell. Quote Link to comment Share on other sites More sharing options...
Phun tunes Posted May 10, 2017 Author Report Share Posted May 10, 2017 Thanks for the response. Please let me know what other information I need to provide. 2" above the center of the A string length is the least concavity. It is a high spot of the fingerboard. The string height at the center of the length is 3.5mm. Maybe the .9mm you gave is for the nut height? Am confused. And it is 6mm at the end of the fingerboard. I can't take this to a shop because I can't drive for a while because of my health and meds. Just would like to figure this out while I am stuck home. Quote Link to comment Share on other sites More sharing options...
FoxMitchell Posted May 10, 2017 Report Share Posted May 10, 2017 1 hour ago, MarkBouquet clearsky said: The maximum concavity is at the center of the string length, not the center of the fingerboard. For a 4/4 cello it should be 0.9mm under the A string, and 1.5mm under the C string. Since we're on this subject, what is the standard scoop (or concavity) on violins? Quote Link to comment Share on other sites More sharing options...
MarkBouquet Posted May 10, 2017 Report Share Posted May 10, 2017 I think everyone should get "Useful Measurements For Violin Makers," by Henry Strobel. It's inexpensive and worth every penny, whether your a maker, player, or teacher. But since you apparently don't have it already, the numbers for 4/4 violin are 0.5 mm under the E string, and 0.7mm under the G. Quote Link to comment Share on other sites More sharing options...
Phun tunes Posted May 10, 2017 Author Report Share Posted May 10, 2017 2 hours ago, MarkBouquet clearsky said: But since you apparently don't have it already, the numbers for 4/4 violin are 0.5 mm under the E string, and 0.7mm under the G. I have a cello. Quote Link to comment Share on other sites More sharing options...
Davide Sora Posted May 10, 2017 Report Share Posted May 10, 2017 As for guitar set up, try to check your fingerboard with shorter straightedges (8, 3 and 2 inches long) to locate bumps where the string buzz. A long straightedge does not give much indication on local undulations on the fingerboard that may cause the buzz, regardless of the total amount of scoop. Quote Link to comment Share on other sites More sharing options...
MarkBouquet Posted May 10, 2017 Report Share Posted May 10, 2017 2 hours ago, Phun tunes said: I have a cello. Yes, and my first post had measurements for cello. Then FoxMitchell asked about violins. My reply that you quoted was for him. Quote Link to comment Share on other sites More sharing options...
JacksonMaberry Posted May 11, 2017 Report Share Posted May 11, 2017 It's not too pricey to have the fingerboard dressed by a luthier. That's probably you best way forward, as there are a whole host of things that can cause an instrument to buzz - loose lining, cracks, separation, etc. Best of luck! Quote Link to comment Share on other sites More sharing options...
